Old 7th December 2007, 09:04   #16
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by DirtyDan View Post
Check the tranny oil level first before you do anything.
I had an oil leak due to the shifter oil seal breaking off. Since i did not have the time to get it replaced, i topped up the oil las saturday & it consumed half a litre of oil. Could that have been the root cause ?
When did you last change your gear oil?
I can't say correctly, but it should have been done some 7 months back.
Yeah, i have been charged for it, so it should have been done (in April 2007)
My mechanic's suggestion was to replace the oil seal & top up the oil level & see what happens. He is sure that the sound will go away. Hope he is right.
Old 7th December 2007, 09:35   #17
tsk1979's Avatar
Thanked: 16,421 Times
Change the oil(not just topup) after fixing seal and see how things are.
Old 7th December 2007, 14:43   #18
DirtyDan's Avatar
Thanked: 776 Times
Default Yea it could be
Oil level.......Could that have been the root cause ?
Yes, this could be the problem. Let's hope so
Old 11th December 2007, 09:55   #19
Thanked: 21 Times
Hi, I have an issue with my Esteem Clutch, its becoming hard day by day. Recently gaved it for service highlighting the issue. The mechanic was informing that the clutch cable is to be serviced. Asked them to go ahead, but even after doing that, still i have the same problem.
Can anyone please help on this
ckmraja is offline   Reply With Quote
Old 2nd January 2008, 14:27   #20
Thanked: 451 Times
UPDATE :
I changed the oil seal & as suggested i changed the oil too, but the problem still continued. Took the car to an ex-Electra mechanic(on headers' suggestion) who has set up a nice workshop near my house . He was able to pin point the problem immediately.
The gear shift rod was bent which was pushing the gears out of alignment (as far as i understood). So he had to align the gears & changed the shift rod & my esteem is back in good shape.
Old 2nd January 2008, 14:48   #21
benbsb29's Avatar
Thanked: 4,277 Times
John, how long did the process take, and also how much were you charged for the same?
Old 2nd January 2008, 14:57   #22
Thanked: 451 Times
he first changed the shift rod alone (1 day) & gave back the car for me to use during christmas. Then he took another day to do the rest. The total cost came up to Rs.3,651 which included new oil (changed to better grade) & new bosch wipers.
Old 2nd January 2008, 19:06   #23
n_aditya's Avatar
Thanked: 2,779 Times
Glad that the GB issue is sorted out for you John. Me going to pop in to that garage for a this weekend. Want to get the electricals checked.
Originally Posted by esteem_lover View Post
... & new bosch wipers.
That was due for some time now right? Come rain and I am looking forward to the review on them wipers. My wipers are long overdue for replacement. How much for a set?
Old 2nd January 2008, 20:32   #24
Thanked: 20 Times
Glad that your gear shift problem has been sorted out. Gear shifts play a great role in providing driving comfort, esp in city.
It's been a learning for me. The gear shift rod will be checked in future, if I ever face difficulty in shifting.
Jeep is offline   Reply With Quote
Old 2nd January 2008, 21:15   #25
yasw_anth's Avatar
UPDATE :
wher in chennai ? reliable mechanic ?
yasw_anth is online now   Reply With Quote
Old 2nd January 2008, 23:29   #26
nitrous's Avatar
Thanked: 285 Times
OT:
Dont tell me u're going there to change ur headlight bulb.Lol.
Arrey. I've used them on my car. Wonderful stuff. Replacing the blades is the simplest DIY. Cost around 350-400.
*hmm...must get a pair for myself when I replace my windshield*
Between koyembedu and vadapalani, on the 100ft road,opp. Radha Park Inn.
Btw, whats wrong with ur car?
Old 3rd January 2008, 14:12   #27
n_aditya's Avatar
Originally Posted by nitrous View Post
OT: Dont tell me u're going there to change ur headlight bulb.Lol.
No nitrous. Just going to check it out.
Old 3rd January 2008, 14:49   #28
Thanked: 2,469 Times
Hey,
Change your Gearbox oil and pls use 30 gms of Boric acid(Carrom Board Powder) with that, You'll feel a lot more difference with that,
Your humming noise will drasticly reduce and no after effects with that, My M-800, Matiz and My VW are running fine with this combination for almost 1 yr.
Old 3rd January 2008, 19:43   #29
Thanked: 451 Times
The bosch wipers cost me Rs.356 or 365, not sure of the exact price. They are super good, only my windshield has quite a few scratches.
OT:
That would work out to approximately 50% of the cost of your windshield.
Old 3rd January 2008, 21:31   #30
yasw_anth's Avatar
@ nitrous anna
my car has clocked ~89000kms and showing her age.. therz seems to be fault in everything :(( suspension(tire scraping),gearbox(hard),accelerator(cables) :(
Fast street drive : Modded Esteem with reworked head, short-ratio gearbox, ECU etc. garrett_t16 Modifications & Accessories 22 16th November 2012 07:59
esteem engine starting trouble leaves me baffled!!! adityapd Technical Stuff 47 10th July 2008 12:17
Bullet gearbox trouble nakedflame Technical Stuff 3 8th January 2008 10:06
Esteem Gearbox Trouble bruce Technical Stuff 3 15th October 2007 21:22
