| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hello, I post this thread to highlight a problem i have been facing in my car for months and that has been giving me headache and sleepless nights. The problem is related to the fan belt in my car. Complete details and history below. Please suggest on possible causes and remedies. In November last year, i was on my way to Wayanad with my car (Ford Ikon 1.6). 80km from Bangalore, there is a place called Maddur on the Bangalore-Mysore highway. I was travelling at around 110kmph when all of a sudden i saw i hump on the road. Before i hit the brakes, it was too late. I hit the hump so hard that the engine fell off from where it was fitted in the chassis. And right below the engine, the driveshaft also came out as result. I called up Cauvery Ford and they promplty towed my car away to the workshop after 4 hours of waiting. I had to get the driveshaft replaced and the engine fitted back to where it was. But since then i have been seeing a noticeable gap between the bonnet and the grille. I am not sure if it was caused due to this impact. But thats not a major worry. The problems started occuring when once on the way back from office, my fan belt just shredded off and came off. I called up Cauvery Ford again and they replaced the fan belt with a new one. They also mentioned that my fan belt assembly is mis-aligned and hence might have to replace the whole thing. He also said that it can wait some more time (may be 2 months) before that can be changed. Unfortunately, the next day on the way to office, the fan belt was shred into 2 again. This time i called up Metro Ford as my office was closer to their workshop. I had to get the whole fan belt assembly replaced and had to fit another fan belt. (2 in 2 days ) Surprisingly the above incident happened almost 4 months after the incident on Mysore Road. The problem seemed to have been rectified. But recently, i have started to get issues with the fan belt again. This time, the fan belt just slipped off when i was running at speed of 80-90 at around 1.5k-2k rpm. One peculiar thing that i noticed this time was that there was no visible damage to the fan belt. But there was a trail of engine oil all along. I went to a local workshop this time just to fit back the fan belt and i asked them some reasons of why that happened. They said chances are that it may happen if there are small dust particles sticking to the fan belt, but they ignored the fact of the trail of oil behind the car and also on the fan belt. This happened to me almost 4 times in one week. Another mechanic mentioned that oil from the engine was leaking on to the fan belt assembly and hence causing the fan belt to slip. One leakage was noticed and it was plugged. But it happened again last week. Now, all undiscovered oil leakages have been plugged. I am not sure if it happen again because i am scared to put more strain on the engine by going above 60kmph. My questions below: 1) Are all these related to the impact i had one year back. 2) If no, what are the possible causes this is happenning continously? 3) If yes, why has this problem appeared only now? and not sometime back? 4) Why do i see a trail of engine oil only after the fan belt has slipped off and no other traces of oil leak before that? (I check my regular parking place regularly and there is no single drop of oil there) 5) I am feeling like selling off my car because i have lost the confidence in going for long drives with it. Can this be repaired or is my car a lemon?? NB: I am taking my car to Cauvery Ford this weekend for a regular check up. I will update you all on what their comments are. (i got a got from them last week on the feedback i had given to them on thier website a couple of weeks back, which was surprising) |
| | #2 (permalink) | |
| BHPian Join Date: Jul 2006 Location: Bangalore
| Quote:
Answers to your questions: i,ii,iii. Well very much possible, engine falling off is not a normal thing. Even in bad accidents the engine doesnt fall off. Also maybe the engine was not aligned properly to the engine bay and other components. Over a period probably a year the tolerances increased and you started seeing the problems. iv. Ask the service center to check all oil seals. Due to the belt tension the shaft is held securely in place. As the belt comes off it may induce some play at the shaft end making oil come out. Best way to track this is to check where the oil is leaking from. If the oil leaks only after the belt comes off then it surely is one of the components in that system. v. It surely can be repaired. But how much it will cost depends upon the extent of damage the engine fall cost. You may never know whether the job being done is of a high quality or not. Try and convince the Ford guys that they need to give some sort of warrranty on their work since they have not being able to rectify the problem, and that if it occurs again you wont have to pay for it, atleast for the parts you had recently changed on their recommendations. What policy does Ford have on such repairs. At Mahinndra i get 6 months warranty on any critical part failure from the company after repairs for both my Classic and the Bolero. | |
| | #3 (permalink) |
| Team-BHP Support ![]() | Engine Falling Off is something which I am still not able to digest, I mean never heard anything like this in an accident like yours . Just curious to know Are you the first Owner of the car or is this a 2nd hand Car?
__________________ Racing Throttle Response Last edited by Technocrat : 6th December 2007 at 12:18. |
| | #4 (permalink) | ||
| BHPian | Quote:
I dont have the bill with me now. Will take a look tonight and see. I have another question though. When the rpm increases, does the fan rotate at a greater speed or is the speed of the fan constant throughout? I ask this question because this problem has occured to me only when i am travelling at high speeds in the 5th gear and on the highway and no where else this has happened. Cheers Sanju | ||
| | #6 (permalink) | |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Quote:
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #8 (permalink) | |||
| Quote:
PS: Dude are you from IBM GSDC? | |||
| | #9 (permalink) |
| BHPian Join Date: Oct 2004 Location: Bangalore
| I was wondering about the engine falling off too. I remember this hump very well. I think you are talking about the one which is right after the right turn and is not easily visible. I ran over that too once, but I was about 60kph at that time. I have not had any problems with my car and I got it checked after that drive too. There is a good possibility that your present problems with the fan belt and oil leaks can be related with your hump incident.
__________________ Deepak Honnalli. |
| | #10 (permalink) | |
| BHPian | They did not weld them. The engine is mounted on a metal piece on either side which snapped. They just replaced them with a new one. The bill has that specifications though if i remember well. I checked that last week and i did not see a problem with the mounts. May be complete misalignment?? Because i had change the fan belt assembly from Metro Ford for a bill coming to 17k. (lots of money spent on it already ..lol) Quote:
Yes I am. Cheers | |
| | #11 (permalink) | |
| Quote:
Its the engine/water pump/alternator belt that changes speed with RPM, this is for the sake of technically challenged members who might read this thread.
| | #12 (permalink) |
| BHPian | By engine mounts breaking into 2 and the engine falling off i think he means the crossmember in the front. Must have been already weak and must have broken off due to the hump and since it supports the front side of the engine the engine came ahead and that stressed out the engine mounting behind and the whole engine came out. Not very suprising.A weak/cracked crossmember is easily noticable if looked properly
__________________ Life is a lemon and i want my money back!!!! |
| | #13 (permalink) |
| BHPian | Seems like the problem with my fan belt has been resolved. Had been to Cauvery Ford on Saturday and they confirmed that oil leak has stopped and the belt was in fact slipping off because of the oil leakage. Have been using for a couple of weeks since i got it repaired after the last problem and see no problems yet. Still tentative about going above 60kmph. But the confidence in my car is slowly coming back. Another question. May be the last couple of posts have not yet cleared my query. Sorry for asking again. 1) Does the fan belt speed increase as i rev up the engine? OR does the fan belt speed increase as the speed of the car increases? Cheers Sanju |
| | #14 (permalink) |
| fan belt or water pump belt is the one which connects the various pulleys of the engine, like crank, water pump as well as power steering and ac comp. so in effect when the rpm of the engine increases the speed of the belt rotation also increases. again when the speed increases technically your engine speed is also increasing and hence the belt also increases its RPM (rotations per minute)
| Thread Tools | |
Similar Threads | ||||
| Strange problem with Petra - Radiator fan | jraj | Technical Stuff | 8 | 24th August 2008 14:00 |
| alternator belt damages timing belt??? | jalsa777 | Technical Stuff | 20 | 3rd June 2008 20:53 |
| Is it the fan belt noise? Please guide | sforsarang | Technical Stuff | 25 | 17th December 2007 10:45 |
| Baleno belt problem!! | bhp | Technical Stuff | 3 | 29th September 2007 12:22 |
| Fan belt noise in Xing XP | Sush | Technical Stuff | 32 | 10th July 2007 10:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
