Old 6th December 2007, 08:58   #1
arunkumar_rec's Avatar
Default Aromatherapy oil usage for making your car smell better
Has anyone used the Aromatherapy oils for making your car smell better? People say that the ambipure is chemical and very bad for health. So i threw away the ambipure stuff from my car.
If anyone has used the aroma oils, please share your thoughts as to how you can effectively use it? what method to follow etc etc.
Thanks,
Arun
arunkumar_rec is offline   Reply With Quote
Old 6th December 2007, 12:48   #2
HKP
HKP's Avatar
Thanked: 12 Times
Default true?
Arun
I did not know that, I mean what is the chemical they are using? what are the health hazards? Can you explain?
\\hkp
HKP is offline   Reply With Quote
Old 6th December 2007, 13:17   #3
gd1418's Avatar
Thanked: 656 Times
What I know about aromatherapy oils is that you need to heat them to dissipate.
Even if we replace the synthetic oil in ambipur with this aroma oil, will that evaporate on its own without warming?
Old 6th December 2007, 13:57   #4
tsk1979's Avatar
Thanked: 16,421 Times
From your posts it appears you really have a smelly problem in your car. First filters, then ionizers and then this.
Using perfume(natural or chemical) is curing the symptom, not the disease.
I suggest you park your car in bright sunlight for few days continuously so that any fungal growth is gone.
After that get interior dry cleaning done(500rs)
for AC vents buy silica gel(A huge packet costs just 90rs), tie a few sachets by a thread and hang them when your car is parked in the sun.
Heat will make moisture evaporate, and silica gel will absorb the moisture.
Within a weeks time your car will be cured of all smelly issues.
However if your problem stems from as smelly co passenger, whom you can't ask to take a bath due to political correctness reasons, perfume is the best answer
Old 6th December 2007, 14:01   #5
gd1418's Avatar
Thanked: 656 Times
Tanveer, what an explanation? I haven't yet stopped laughing..
Old 6th December 2007, 14:23   #6
BlackPearl's Avatar
Thanked: 5,144 Times
.. twenty twenty
BlackPearl is offline   Reply With Quote
Old 6th December 2007, 14:32   #7
ram_hyundai's Avatar
Thanked: 48 Times
arun,isnt the problem solved yet.its almost 2 weeks now that i had pmed you.did you get your a/c ducts and filters cleaned.is it still persisting after that.
ram
ram_hyundai is offline   Reply With Quote
Old 6th December 2007, 14:40   #8
speedmiester's Avatar
Thanked: 931 Times
Once when I was at my friends place, who has a vanilla grove. He offered me some of the vanilla ( i dont know what it is, very poor in biology and stuff) thingy. I used to keep it in my car. It really was very good.
Its natural and no need to worry about the chemicals and it fills up my car with a rich aroma of vanilla. One stem almost lasted for 3-4 months.
speedmiester is offline   Reply With Quote
Old 6th December 2007, 15:50   #9
The dealers are not willing to get the ducts cleaned. They are saying that it will create rattles if the original set up is tampered!!!!. I dont understand onething. If they cant do it then who else can?? They cleaned only the A/C filter. That's all. The problem persisted. ie for first 10 seconds, I get a unpleasant odour from the A/C duct and then slowly the odour goes away(or is it that I got used to the odour).
I have got the A/C neutraliser spray sprayed onto the ducts yesterday. Hope the problem gets ok. Need to check after few days as there is that smell from the neutraliser spray which is still prevailing.
Tanveer, My car is not smelling though as you have predicted. The problem is with the A/C only. Anyway thanx for the useful info which may be useful some other day if my car stinks.
Aroma oils, I am just curious to know if it can make the car smell nice. I have stopped using the ambipure as per the advise from ram hyundai.
The Advaith in Mysore is getting the A/C cleaning machine only next month which they promise will get all the A/C problems solved. I am waiting.
Old 6th December 2007, 16:10   #10
snaronikar's Avatar
Thanked: 23 Times
Agarbathis...Beautiful smelling Agarbathis will do the trick.
snaronikar is offline   Reply With Quote
Old 6th December 2007, 16:24   #11
tsk1979's Avatar
There is saying in one of the National languages of India
"Na Rahe ga Baans, Na bajegi Bansuri".
This literally means
With no Bamboo, there will be no flute
What you described will do the same thing. After the car burns down, there will definitely be no smell problem.
Of course it can be done, but you need to have adequate precautions so that even if the incense stick falls, nothing burns.
Old 6th December 2007, 16:43   #12
Technocrat's Avatar
Thanked: 2,589 Times
This Might sound funny & weird but around 8-9 years back we did a trip in an Omni from Burhanpur(Small Town in MP close to Jalgaon) to Banglore & the car had a agarbatti stand & we did lit some during our journey..
Also This stand was quite a common site then when the Taxis were primarily Ambys
Old 8th December 2007, 11:31   #13
Thanked: 44 Times
Tsk's post is damn funny, but is rings of truth. Smells can only happen if something is not clean. There is nothing like the smell of a clean car.
The a/c smell should be solved if you use neutraliser spray. It's due to fungus on the coils.
One way to cure this, after a long run when engine is hot, run the blower in re-circ mode, a/c off, temp setting to full heat, keep windows open just a tad, and of course step out of the car. Let it run like this for about ten minutes. All the bacteria/fungus on the coils will get toasted, and you should be free of smells for along time.
filcord is offline   Reply With Quote
Old 8th December 2007, 11:45   #14
mobike008's Avatar
Thanked: 8,319 Times
I am still . your absolutely correct.
I typically park my car for atleast 4 hours in sunlight and keep windows open for a short period each day and clean the interiors atleast twice a week and till date, i never had to use a perfume in any of my cars
My own aftershave cologne does the trick for me
Old 6th March 2010, 19:35   #15
vijaypalsingh's Avatar
Thanked: 62 Times
You may find it an 'OUT OF BOX' suggestion but in 2008, I happen to meet Ms Dimple Kapadia & in discussion she suggested me to use scented candles (the one that come in metal containers) in my cars. Make some holes in the cap with household nails & leave it in the place where the heat will be at max. First few days the smell will be bit strong but later it'll settle down to mild. I also suggest that one must change frangrances so that we dont get immune to one smell.
(Note: I personally tried it that whenever the perfume seemed to have lessen, I would open the container & disintergrate the wax with screwdriver)
vijaypalsingh is offline   Reply With Quote
How does your car smell Neel Modifications & Accessories 611 8th May 2018 13:36
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
What does your better half think of your 4x4? Sudarshan 4x4 Vehicles 43 21st November 2012 13:02
Diesel & LPG - Your oil burner just got better! KL54 Technical Stuff 5 31st August 2012 10:35
