Thread Tools
Old 6th December 2007, 09:27   #1 (permalink)
Default santro (Nov 2004) crank shaft failure at 30000km
I have a terribly SHOCKING experience with my SANTRO XG Model Nov 2004 which recently started giving rattling sound during normal running. The car was running very smoothly after a routine overhauling was does just a couple of days back from local Hyundai dealer M/s Bhagat Singh Hyundai Motors in Rajpura (Punjab).First I thought its a fan noise but later car had to be towed to the local garage where the Hyundai Technician after initial inspection declared to be something inside engine which has to be diasmantled.I was told its a costly affair since I was not under extended warranty.They gave the estimate around Rs. 25000/- and said the spare cranck shaft will take time and also piston/rings will be replaced.
I took all the sanps of the broken shaft and sent to Hyundai repeatedly till date with an earnest request to consider my case for full comensation against TOO EARLY a failure which is entirely not expected just after 30000 km.I have approched telephonically and through varoius mails to their local,Patiala and Delhi Customer care division with one just reply that they have forwarded the case to their service dept.After the repairs I was told to collect the car after payment of Rs. 23400/- and if something comes out as compensation will be paid back to me. Till date nothing has comeout. I have also written them regarding a similar case of Dr.L.Murugan who has been compensated full amount excluding labour charges.This failure has totally shocked me and even after the repairs I am not comfortable driving fearing it may repeat again!!!I have being undergoing complete restlessness and mental torture since the incidence.The company is silent totally and not ready to listen anything because of one fact that I was not under extended warranty!!Please suggest.
Note from mod: Use the correct section while posting
msvilkhoo is offline   Reply With Quote
Old 6th December 2007, 11:05   #2 (permalink)
tsk1979's Avatar
Why did you get the engine overhauled so early?
__________________
Reclaiming.....!
Old 6th December 2007, 12:01   #3 (permalink)
Spitfire's Avatar
Yes, why was the engine overhauled. Its not normal to overhaul an engine within 30K kms.
Spitfire is offline   Reply With Quote
Old 7th December 2007, 09:37   #4 (permalink)
IT WAS JUST A ROUTINE OIL CHANGE AND TUNING ONLY PRIOR TO FAILURE. NOT A COMPLETE ENGINE WORK.
Note from mod: Do not type in all CAPS
Old 7th December 2007, 10:13   #5 (permalink)
tsk1979's Avatar
Can you post the snaps of the broken shaft.
I will help understand what exactly happened.
__________________
Reclaiming.....!
Old 7th December 2007, 10:22   #6 (permalink)
humyum's Avatar
Crankshaft failure = defective crankshaft
But why piston rings at 30 thousand?
__________________
Life is a lemon and i want my money back!!!!
Old 7th December 2007, 10:23   #7 (permalink)
theMAG's Avatar
This isnt the first of its case. There are other Santros reported with the same problem on the forum. If I were Hyundai, I'd look into it very proactively and with an open mind.
__________________
If you lose your temper, you’ve lost the argument
Old 13th December 2007, 17:24   #8 (permalink)
Please give your mail address where I can send the snaps.Thanks
Old 13th December 2007, 18:42   #9 (permalink)
Zappo's Avatar
Please post it on the forum so that members can have an idea of what exactly happened.
About this problem, although it is no assurance, but let me tell you that you are not alone in this. Hyundai has had this crazy problem of breaking crankshafts, axles etc for quite some time now. We have a bunch of these already reported on this site.
I am getting more and more convinced by the day that Hyundai's are better left aside. In fact for quite sometime now I have even stopped recommending Hyundais to people when they ask for a 'good car'. Your case only bolsters my views.
Its happening a little too often for anyone's comfort. I do not think a car (any car) should have such a catastrophic failure within 30,000 kms.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 13th December 2007, 20:44   #10 (permalink)
Ford Rocam's Avatar
Please post up the pics for analysis. Within how many KM after changing oil did crank failed? & prior to oil change was there any sign of roughness/vibration, loss of power from engine?
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 19th December 2007, 12:02   #11 (permalink)
It ran extremely well after changing the oil for nearly 250 km.noise was sudden like a rattling sound in the running car when I was just about 1 km to reach home.I thought it may be a fan noise.Next day morning it did not strat at all.Hyundai technician came to my house and he advised car to be towed to their workshop.Thier first reaction was that this is the first case they have come across.I am sending the snaps>
Old 19th December 2007, 12:11   #12 (permalink)
It ran 250 Km very very smoothly like never before after changing the oil.Just 1 km before to reach home I heard rattling sound which I thought immediatly opening the bonnet cover would be from fan.Later car had to be towed to Hyundai workshop.To Hyndai local people it happened to be thier first case ever.
You may please try to view the snaps as per link below:
file://192.9.200.109/My documents/Hy...nck fail snaps
Old 11th March 2008, 09:30   #13 (permalink)
the snaps of broken cranck shaft of my Hyundai Santro XG model 2004 run 30000km are now attached.
Old 11th March 2008, 11:22   #14 (permalink)
spadival's Avatar
Looks like the end has sheared off.. Manufacturing defect, if you ask me.
Also, Did you check if they have really filled oil after the oil change? Some times, given the standard of service in India, these idiots can forget to refill after draining off the old oil from the engine. That could explain the damage to the pistons.
spadival is offline   Reply With Quote
Old 11th March 2008, 15:31   #15 (permalink)
risga's Avatar
Relevant point. Actually, photo of the pistons will reveal the sequence of events. Could be no oil was filled, which led to engine seizure and consequently shearing of the crankshaft. If only crank failure due to mfg. defect, pistons should not be damaged. But on engine rebuild, new pistons would be used even if the earlier one was undamaged.
In either case, whether negligence of their service outlet or mfg defect, Hyundai cannot shirk responsibility. Its bad of them to avoid the customer.
risga is offline   Reply With Quote
Thread Tools
santro 2004 XS ICE ullal_h Sound Off and Show Off 15 25th September 2008 16:00
Hyundai Santro Xing - Crankshaft & engine repair/ failure-only 26000 Kms & 2 1/2years Murugan Long-Term Ownership Reviews 40 27th May 2008 09:13
2004 Silver Santro Xing abhilash Shifting gears 1 31st October 2007 19:12
2004 Santro Xing XG for sale mohit Shifting gears 1 20th June 2006 09:56
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
