Old 6th December 2007, 12:37   #1
arunnn's Avatar
Default Speed & Gear combination for Chevrolet UVA
Request anybody who own UVA or has experience on Chevrolet cars to advice me about the optimum speed to shift gears. I usually follow this
on level roads,
1st Gear : 0-10
2nd : 10-20
3rd : 20 -30
4th : above 40
5th : above 60
This is what I used to do in my Santro.
When I do the same in UVA, first 2 gears are ok. But when shifting to 3rd gear, there is a slight jerk. I tried varying the speed between 20-30. Some times its smooth, but gives a jerk most of the times.
Its a new car, less than 1000km. And I dont have tacho in the car.
cheers,
Arun
arunnn is offline   Reply With Quote
Old 6th December 2007, 16:34   #2
Default Feel not read the speed
Mod Note : Post edited to remove FONT tags. Please do not cut-copy-paste from other word softwares. It results in a formatting error. Thanks
Hi Arun,
The gear change should not depend on the speed rather it should depend upon the engine state.
Gears are to modify the engine out so that the output power is tunes to meet the terrain requirement.
A Gasoline engine does not have ability to give varying torque and takes some time to pick up speed up (torque is depends on the speed)
The gear box helps to modify the engine output torque which is required to meet the terrain requirements
Try to understand the engine behavior; a Hyundai engine is different from a UVA. You need to understand
- is your engine a high rpm engine (like Opel)
- is your engine a low rpm engine (like Honda)
The torque curve is what this gives; unfortunately GM does not give Torque curves for its models. So you need to guess engine performance and manage it
I personally feel the engine and drive (same with my Bullet).
1. Keep a close tab on mileage this will tell you if you are behaving with the engine properly
2. Try to understand the engine humm.. this will tell you if you are straining the engine (sure you would have observed auto drivers going up a flyover.... closer to the top the sound of engine is just like .... man spare me spare me....) try this over some time only then will you be able to appreciate this point
Summary
Gear Change is to be done with engines ability to provide the required torque and not by speed (the speed limit is for general public and since you have come here you are not really in that category)
The engine sound is a good indicator (in absence of a Tacho)
Try to learn how to hear our engine and change gears
ashtwinks is offline   Reply With Quote
Old 9th December 2007, 12:53   #3
adya33's Avatar
Thanked: 91 Times
arunn its not a good idea to drive at such low speeds specially when you are running-in your car.
I would advise you to go through Team-BHP's guide to running-in your car
https://www.team-bhp.com/forum/ownin...r-new-car.html
As for driving speeds, well speedometer is probably not the best choice I would say.
Start getting to know the engine. A single gear can run over wide band of speed. its all about finding the sweet spot.
adya33 is offline   Reply With Quote
Old 9th December 2007, 13:29   #4
Shan2nu's Avatar
Thanked: 87 Times
Just read the user manual. All manufacturers provide the optimum shift points (wrt to engine rpm as well as vehicle speed) when driving under normal conditions.
Shan2nu
Old 9th December 2007, 16:37   #5
Thanked: 24 Times
Shan2nu
Yup! Would like to add that don't pay too much focus on the technicalities. The thing to keep in mind is try not exceed 90-100 kmph before first 2k and too ensure the engine, gearbox gets worked out in the city i.e. a mix of city and highway driving!
Elito
Elito11 is offline   Reply With Quote
Old 9th December 2007, 16:48   #6
DirtyDan's Avatar
Thanked: 745 Times
Default Tell us
You are now the resident expert, you tell us where the shift points are (just do not over rev it until it's run in a bit, okay?)
Third gear is a little notchy on a lot of vehicles. You will see some write ups on this in this site. There are some technical reasons for this that I can not remember...anybody help out here?.....I would give it a little run in time and see if the problem diminishes. Coax it into gear a bit for awhile.
Old 10th December 2007, 23:01   #7
arunnn's Avatar
Thanks for the all good advice..
GM dont give any speed details in the user manual. The documentation need lot more improvement.
Chevrolet Aveo UVA - Initial review (2000 km) arunnn Test-Drives & Initial Ownership Reports 38 6th October 2015 21:54
Speaker combination for existing HU & amp CLYDE In-Car Entertainment 11 29th May 2012 11:13
Hyundai i10 Magna or Chevrolet UVA LS Jazz Hatchbacks 31 19th December 2009 18:52
Notchy Gear Shift in my new Chevy Aveo UVA EatMyDust Technical Stuff 12 5th June 2009 09:46
