Thread Tools
Old 8th December 2007, 12:34   #1 (permalink)
team suzuki's Avatar
Infractions: 0/1 (4)
Question is it possible to clean the lense of the lights from inside
hi,
i don't know if any one will understand what i am trying to ask .I have a daewoo cielo,i had changed the lights to philips h4 90/100, when i drove the car at night i noticed the lights were not bright enough,i didn't mean it was not showing the 90/100 effect but it was not even bright as other cars i had then noticed that the lense of the lights were dirty from inside is it possible to open the lense and clean it from inside hope some one has understood my question
team suzuki is online now   Reply With Quote
Old 8th December 2007, 15:57   #2 (permalink)
1self's Avatar
Yes, it is very much possible to clean the headlight from inside out. What you will need is a heat-gun/oven(not the microwave variety). There are many DIYs on the net about angel eyes. See those to get an idea about baking your headlight to get the glue soft.
Then they use a butter-knife/other tool to separate the inner & outer housings of the headlight.
Once the headlight is apart, use a silver ornament cleaner liquid to clean the reflector to a mirror finish...& voila...your reflector is as good as new!
Now, bake the two saperate halves of the headlight again to soften the glue, put the two together & you are done!
Remember to be careful when you bake the headlights, don't melt the plastic or allow it to become too soft....this is the only critical area in this DIY!
__________________
I'm not into exotica & badges, just horsepower & handling!
1self is offline   Reply With Quote
Old 8th December 2007, 16:11   #3 (permalink)
karlosdeville's Avatar
...Or you can get them done from Chor Bazaar in Bombay for a pittance, from someone with tremendous experience in a few minutes. A couple of us got it done recently with good results. I wouldnt tinker with opening the lights myself if I weren't absolutely sure of what I was doing.
__________________
( O \ | / O )
karlosdeville is online now   Reply With Quote
Old 8th December 2007, 16:13   #4 (permalink)
1self's Avatar
The guy lives in Kerala.
__________________
Old 8th December 2007, 17:32   #5 (permalink)
Lukeskywalker's Avatar
I had a similar problem in my cielo, what my mechanic did was remove the headlamp assembly and then he removed the bulb shade which is a kind of hood for the bulb and then u can use a soft cloth and your fingers to wipe most of the dust off. The only problem is the bulb shade has to be crushed for removal and so cannot be refitted, this only gives u a brighter light.
Lukeskywalker is offline   Reply With Quote
Old 8th December 2007, 20:33   #6 (permalink)
will this be a major problem?
Old 9th December 2007, 06:39   #7 (permalink)
speedzak's Avatar
There was this guy called Karthik247 from Trivandrum who did all this himself using an LPG stove. And a proper DIY job it was.
I wouldn't take this chance. Would rather get it done with somebody who repairs headlamp assemblies. Try your nearest auto electrician. He may help you.
You can also use glass cleaner and cloth to get it cleaned after removing the bulbs.
__________________
The squeaking wheel doesn't always get the grease.
Sometimes it gets replaced!!
speedzak is online now   Reply With Quote
Old 9th December 2007, 08:10   #8 (permalink)
If you mean removing the bulb shade, I don't think it should matter much, IMHO these are used for shielding glare to oncoming vehicles, so if you are using a decent wattage bulb then I;m sure there won't be any problems.
Thread Tools
Finally!! The FIRST CLEAN BMW design in a decade - The X6 GTO The International Automotive Scene 11 9th October 2007 12:02
How to Clean the Engine Bay ? mithun Technical Stuff 36 18th September 2007 01:52
Rs.200 to clean my K&N filter!! OK? stevie Technical Stuff 39 26th March 2007 00:14
Which Is The Best Way To Clean Alloy Wheels? Epic Tyre & Alloy wheel Section 2 15th March 2007 09:59
How to clean headlamps?? prince85 Technical Stuff 6 12th January 2006 12:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
