Thread Tools
Old 9th December 2007, 19:47   #1 (permalink)
Unhappy Squeking Sound From My Esteem
HI guys this is ELVIS (hell boy) I have some troblem with my 1997 carb maruthi esteem.As I have brought this car form one of my uncle and i'm now facing some issues with it the car is good from ever aspect the only thing i have a problem with is the engine. I have lately heard a squeking sound from my engine. So took it to my machanic he thought that it was the sound of my timing belt so i went ahead and changed the timing bealt and a gear that is conected to the timing belt but still the noise wont stop so what he said that he will go ahead and service the head which he did and i was also there in front of him when he was doing it .He found that the oil pump of my engine was choked so i went ahead and change the oil pump that was choked.
And now after 2 days i see that the noise is still there but it is worst this time as there was some tappit sound as well so took it back and told him about it so the said that he had found the problem it was when the oil pump was chocked it did not supply proper oil to the conecting rod bearing so he says that he has to go ahed and get the engine opened and service the whole engine and it will work like new and he said that it will cost around 10k to 15k to do this and my car had ran only 68743 km till date so psl advice me what to do should i take a second advice or go ahead and do the work that he says ............. help
hell boy is offline   Reply With Quote
Old 10th December 2007, 17:39   #2 (permalink)
Pankaj401's Avatar
Take a view from MASS rather than just one mechanic.
Pankaj401 is offline   Reply With Quote
Old 10th December 2007, 21:52   #3 (permalink)
Team-BHP Moderator
Jaggu's Avatar
did you check the water pump? and pulleys?
take it to a reliable M.A.S.S
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 10th December 2007, 22:08   #4 (permalink)
esteem_lover's Avatar
from what you have said here, it looks like your mechanic is hell bent on squeezing you of every paise that you got. get a second opinion (from MASS preferably)
__________________
"can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?"
The Bean effect on my 4 year old
Old 10th December 2007, 22:40   #5 (permalink)
gump's Avatar
Check wheater the timing belt is fixed properly or not, sometimes the timing belt might be loose and you might get these kinda noise, its important that it is fixed properly
__________________
LeArNiNg EsTeEm
gump is offline   Reply With Quote
Old 11th December 2007, 16:49   #6 (permalink)
DirtyDan's Avatar
Default Soap
Start the car. Take a bar of soap and press it firmly against the belt so that the side of the belt that makes contact with the pulleys is picking up soap. See if this stops or changes the sound you are hearing after a minute or two. If it does, it is a belt problem. The belt is not tight enough, about to wear out, or the belt tensioner is broken.
Also, check the tension of the belt. If you press on it with your hand (with engine stopped!!!!) the belt should have about 1 inch of play in it.
This would be lucky for you if it is just a belt problem. However, that ticking noise does not sound good.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 11th December 2007, 17:09   #7 (permalink)
iceman91's Avatar
agree with the others the mech could be messing with you..for eg the tappet sound would definitely come afte he serviced the head cos you have to get them adjusted and he would not have done this properly after the head service.
also if the engine had to be opened and checked it will not cost 15k. unless you are looking at replacing pistons or con rods
definitely check elsewhere
try dan's suggestion I too am inclined toward timing belt and tensioner
also check the other belts..they may squeek
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 11th December 2007, 17:58   #8 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Please donot do this on an esteem, the belts are in a tight position and you will land up injuring your hands.
Also play in an esteem will NOT be one inch, it will have a very minor up n down movement.
__________________
Old 11th December 2007, 17:59   #9 (permalink)
Thanks guys for your suggestion will work on the suggestions given and will reply back.
Old 11th December 2007, 21:23   #10 (permalink)
DirtyDan's Avatar
Default nit picking
Nit picking posts like yours are very tiresome. I think an adult can put soap on a belt without "injuring his hands". If he can not, he should not be driving a car.
__________________
Old 11th December 2007, 21:30   #11 (permalink)
rr_zen's Avatar
Another simple way to find if its a problem with the belt is to sprinkle some water over it. If the sound stops momentarily and returns later then is for sure a problem with the belt. This is out of my experience.
__________________
Ships are safest in harbour. But thats not what ships are made for !!
rr_zen is offline   Reply With Quote
Old 11th December 2007, 21:51   #12 (permalink)
Team-BHP Moderator
Jaggu's Avatar
sorry if i tired you, but there are a lot of new bees who might not be really equipped to do what you have mentioned, putting soap on a esteem belt which resides precariously close to chasis side member, and that too with engine running !!
again, hope you have some idea of what kind of belt esteem engine uses ?? and the issues when something like soap is introduced into the equation?? i suggest you google some more before suggesting home made remedies, which can even lead to bigger issues.
I again apologize if i offended you, but that was not the idea
__________________
Old 11th December 2007, 23:49   #13 (permalink)
DD, i find that comment awfully misplaced. A driver/owner need not be capable of actually doing something so silly. First advice that you will read in any safety manual is not to put your hand inside a running mechanical device. If you had chosen to do that then it is your hand & your life, please do not presume that is the standard. Hope you understand.
__________________
Old 12th December 2007, 00:05   #14 (permalink)
bar of soap pressed onto a running belt? well i agree with you cos i guess that in most cases this "soapy trick" would identify the problem cos it could ensure a damaged hand and no need to start/drive the car for quite a while. and 1" of play? too much. belts are good enough that if it starts to squeal then its mostly a worn belt. replace it!
like its often said "when all else fails read the instruction manual".
__________________
life is a beach....enjoy it!
surYa
hollywoodhogan is offline   Reply With Quote
Old 12th December 2007, 17:21   #15 (permalink)
DirtyDan's Avatar
Default Let him decide
I'll tell you what, let's let "Hell Boy", the thread originator, decide what is best for his own safety, okay all you highly concerned safe citizens? The soap trick has been around a long time because it often works.
__________________
Thread Tools
What's that sound ?? four_tire Technical Stuff 74 21st August 2008 02:06
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 17:31
no sound from speakers bunnarith Ask the Gurus 21 12th August 2006 10:41
HU ---> Sound panky12345 Ask the Gurus 18 28th July 2006 11:34
What could this sound be?! Zappo Technical Stuff 14 20th December 2005 17:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
