Old 11th December 2007, 02:04   #1
Thanked: 9 Times
Default Types of CNG Kits
can anyone please give more info on the different types of CNG kits, their positive and negative types and kinds of vehicles to use them in....
Types i have heard
Open Loop
Closed Loop
Sequential Injection
thanks
coolmob is offline   Reply With Quote
Old 11th December 2007, 13:02   #2
wolfinstein's Avatar
Open Loop system
Basic Throttle Body Delivery system
Uses an Timing Advancer System if installed- Helps in Sudden Accelaration. Open Loop system is a Basic system with minimal requirements, However needs regular tuning and mandatory periodic checks. Open Loop system does not auto correct the Lamda readings( O2 in Emmision as scanned by Car OEM O2 Sensor Lamda) this leads to Check Engine light at times when the Mixture is Poor or Rich.
Cheaper Option- Starts at Rs 33,000 Avg + Timing Advancer for 2000 more.
Closed Loop System
Uses a Lamda Controller to regulate the flow of Gas into the manifold by Throttle Body Delivery ( Stepper Motor),by reading the O2 emissions. It Auto corrects the Mixture for Lean Mix and also emmulates the Reading to the ECU incase of any variations to avoid Check Engine Error- The Range is defined and not extreme.
Closed Loop system also has a RPM Cap regulated by Engine Power- Like all Systems the CNG mode clicks auto on RPM above 1500 or as set. In a closed Loop system it allows the engine to stay on CNG till about 4000 RPM and anything more it shifts to Petrol for the power needed at that level and on lowering down Auto shifts to CNG.
This ensure a better and Optimal Engine Power Management as desired at Higher Speeds.
Usually does not need regular checks, however as all kits needs periodic checks with Scanner to set/read the settings.
Does not need Timing Advancer.
Usual costs are around Rs 40,000 onwards.
Sequential CNG systems
Similar to the Closed loop, However has a seprate ECU to manage all Gas functions- The main feature is that it incorporates an Injection Rail System with seprate Injectors - Auto mixing the Air-CNG in the right mix.
Sequential Systems are advanced an good, But they are pretty expensive and replacement costs are higher since not all locations and dealers can service this kind of setup.
Major issue is that it needs disconnection of the OEM petrol MPFI injector setup
Sequential Kits are as of yet pending approval from ARAI for use in Indian BS 3 Stage cars.
Needs a Pro to install, Avg costs are Rs 65,000 Upwards.
You can go through this PDF to understand more
http://engva.org/Pages/235/documents...20Info%202.pdf
wolfinstein is offline   (2) Thanks Reply With Quote
Old 27th February 2010, 13:05   #3
Question advancer??
can anybody tel me how a timing advancer affects the gas mileage?
AutoMad is offline   Reply With Quote
Old 28th February 2010, 16:10   #4
vigsom's Avatar
Thanked: 610 Times
A timing advancer alters the ignition timing to suit gas ; this results in optimum engine performance when the car is run on gas.It ensures more complete combustion and thus better fuel efficiency
Old 9th May 2010, 07:30   #5
devarshi84's Avatar
Thanked: 119 Times
What are the types of LPG kits available?
devarshi84 is offline   Reply With Quote
Old 9th May 2010, 07:54   #6
Is there some preference between Indian and Italian kits?
As the rates which have been quoted here, are for Italian kits.
For Indian kits rates in Delhi market are as follows:
Open Loop: ~23K
Closed Loop: ~30k
Sequential: ~40k
Sorry, but I dont remember the model and make of these Indian systems.
ashishsonileo is offline   Reply With Quote
BMW India stops sale of M Peformance Power Kits *EDIT* Power kits are back! Akshay1234 The Indian Car Scene 52 11th September 2017 00:57
Working of CNG / LPG kits adarsh76 Technical Stuff 3 11th June 2007 15:54
LPG / CNG kits amu1983 Modifications & Accessories 6 27th February 2007 23:13
For sale: CNG and LPG kits (with installation) Minardi Shifting gears 3 3rd October 2005 14:51
