| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | My car has run 17000+kms in 18 months. Whenever I stop the car and take a full right 'U turn', I hear a 'tack tack' sound from the front left wheel. It doesn't happen when I steer on the move. Only present when I move from standstill. Out of previous experiences on many cars, I suspected the drive shaft wear. I suggested checking the shaft. I replaced the left shaft at the authorised dealer under warranty. The sound refused to go. The same day we replaced the tie joint, serviced the strut, cleaned the steering knuckle, serviced the brakes etc. Still the sound persisted. I was beside the car the whole day from 9:30am to 9pm suggesting whatever I knew. I gave up since the guys were not able to identify the issue. Later at home I checked for wheel shake. No shake, that meant the bearings are intact. They now suspect a crankcase issue. The advisor says when the car turns right, all the load is shifted to that side and crankcase issue shows up. He is not able to clearly explain what the issue is. They have to open the case to shim it. That will take a few days to set right. From what I have heard of shimming, its done to centralise the crank seating and position. Please correct if wrong. Any suggestions or pointers would be of help.
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* |
| | #2 (permalink) |
| BHPian Join Date: May 2006 Location: Shillong
| I am not an expert, but before you go the whole yard, just check if the wheel touches the wheel well at some point. (In case you already have not done so) I am suspecting this since you would generally turn the steering to lock only you are at a very low speed, or starting from standstill, while on motion you usually never ever turn the wheel till lock. |
| | #4 (permalink) |
| Senior - BHPian | Did ya check the axle and bush ?
__________________ For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence! Last edited by abhibh : 13th December 2007 at 18:03. Reason: Spelling mistakes lol |
| | #6 (permalink) |
| BHPian | Check the engine mountings/gearbox mountings.Weak mountings can lead to the engine or the gearbox touching on one side.hence the sound. Also check the left apron.Raise the car on ramp and check the apron which has a joint under the body.If that is weak it could lead to the sound.Thats all i can think about right now
__________________ Its not the age,Its the mileage |
| | #7 (permalink) | |
| BHPian | Quote:
Are you sure about the side from which the sound is emanating ? In my case it was a distinctive knocking sound as you moved away on full-lock. | |
| | #8 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| i dont think you need to open the engine, check all the mounting points, and also see if your silencer pipe routing has enough space around. did you start the engine take a U but in neutral.. and checked for sound?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #9 (permalink) |
| Team-BHP Moderator ![]() Join Date: Apr 2005 Location: Pune
| Check bush for wearing out. I had faced similar problem couple of years ago in Astra when after replacing clutch plate on taking a sharp left turn there was huge grinding noise. After all silliness of trying everything, it turned out that mechanic had not tightened screws properly. So yeah before going to extreme measures, make sure you have gone through all simple looking solutions. |
| | #10 (permalink) |
| BHPian | hmm.... I remember the same issue with my brand new Maruti 800 way back in 1997! As per the experts, it could be of two issues. Your caliper might need some good shimming job OR the second one is a good shimmimg job on the diffrential. That day the technicians have checked both the areas and found that excessive backlash in differential to be the culprit! They shimmed it and the car covered 1 lakh kms wonderfully before I sold it! Although, as everyone suggested, check the mountings and all other usual rattling parts! Clutch assy could be a strong culprit too!
__________________ MISSED the action!!! :-( Guess another one has already started happening!! :-) Last edited by nikkibike : 15th December 2007 at 21:18. |
| | #12 (permalink) |
| BHPian | hello man.....i was surprised to hear u have a same 100% similar problem in ur alto....and that too only in right turn...exact thing happened with mine.....the service station people and myself took 5-6 hours to solve it...we checked all couplings ...lower arms etc..... the problem is simple....just get the tie rods greased....sounds goes...of rubber bush worn out replace..... it was horrible....whenever i used to start the car and just begin to roll it i used to get tuck tuck sound....and that too only for right turn... |
| | #13 (permalink) | |
| BHPian Join Date: Nov 2006 Location: Singapore
| Hi Adya, This happened with the Accent as well.. KTC Hyundai at Palakkad serviced it (long back) and since then there was this grinding noise when a sharp left was taken from standstill (the grinding noise would last hardly a second).. the problem disappeared on its own after sometime. What screws are you talking about here? Quote:
| Thread Tools | |
Similar Threads | ||||
| Strange sound from the AC blower | amit_mechengg | Technical Stuff | 8 | 16th January 2008 18:29 |
| strange fluttering sound in my baleno | abhishek_rait | Technical Stuff | 15 | 29th June 2007 19:01 |
| Doubtful of my WagonR front-left tyre | CheeseGuy | Tyre & Alloy wheel Section | 18 | 7th June 2007 17:51 |
| Strange Sound from Yamaha RXZ Gearbox - Need Help! | Rajeev29 | Motorbikes | 4 | 26th March 2007 23:01 |
| Front wheel .steering column ticking sound.. Need urgent help!! | DRC | Technical Stuff | 17 | 17th January 2006 12:47 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
