Old 13th December 2007, 11:17   #1
arunkumar_rec's Avatar
Default GETZ low fuel warning lamp- does it work
I have my doubts whether the low fuel warning lamp of Getz is working properly. I was told by the dealer that the lamp will get triggered as soon as the fuel left in the tank is close to 5 litres. But this doesnt seem to be the case. Getz fuel tank is 45litres capacity. I filled full tank yesterday. Filled 42litres+. But the warning lamp was not on going by the dealer's words. I have seen this irregularity every time I fill the tank. I checked the road where i parked the car and found that to be flat. So there is no way that the sensors can give a wrong signal.
Anyone has faced this problem? Solution for the same appreciated.
Arun
arunkumar_rec is offline   Reply With Quote
Maruti Suzuki - Low Fuel Warning Indicator Venkatesh.C The Indian Car Scene 51 31st October 2014 08:54
Palio injector warning lamp amitverma Technical Stuff 24 15th April 2011 08:56
Low fuel indicator lamp - Getz nishantgandhi Technical Stuff 16 18th January 2009 11:44
Low Fuel warning light on Dzire/Swift-can it be activated/retrofitted? TOR Technical Stuff 43 20th October 2008 10:41
How long after fuel warning lamp is on thalavoy Technical Stuff 26 25th April 2005 12:50
