Old 17th December 2007, 18:40   #1
Default Used Sensors - Where are they available?
My colleague - for a project -needs the following sensors (used in car engine's function monitoring):
Water Temperature Internal
Water Temperature External
Oil Temperature
Generator Voltage
Oil Pressure
Exhaust Temperature
He checked with several Maruti service stations. They all said Sensors are not available as spare. One station quoted a price of Rs.35000 for the set of 6 sensors
Different sensors ( used in Tata Indigo) are available as spares, with Manipal Motors and total price comes to around Rs.3500-4000.
Does any one know if discarded( but functional) sensors are available at a low price anywhere? Also, these sensors are having only Tata Part numbers and no specification sheets. Are the spec sheets for these sensors availble anywhere?
Thanks in advance for the help.
ankura12 is offline   Reply With Quote
Old 18th December 2007, 01:41   #2
rohan_fonseca's Avatar
Try the scrap yards for totalled vehicles. No idea about the specs.
rohan_fonseca is offline   Reply With Quote
Old 18th December 2007, 12:51   #3
nitrous's Avatar
Thanked: 285 Times
I would suggest sourcing autoguage meters for all the above applications.
Old 18th December 2007, 13:04   #4
JayD's Avatar
Thanked: 2,008 Times
As nitrous said, getting the meters would be the easiest method. U can also keep track of those readings. Or else, try scrapyards. Finding working mods at the service center may be will be a tough job since if they were working well then they would still be on the car right?
Old 18th December 2007, 14:40   #5
razor4077's Avatar
Thanked: 258 Times
Lots of spare part shops (non authorized ones) have connections with scrap yards and impound lots (accident cars etc). Tell them the parts you need (you may have to provide them with the original samples) and they should be able to source the parts for you. These are generally in good condition, but do a quick visual inspection before you buy them.
If you have any friends who are familiar with some spare part stores, ask them to help you out... so you don't get cheated by the store.
I had a similar situation where I had to get replacement sensors used in my Lancer engine, and went the route I have mentioned.
razor4077 is offline   Reply With Quote
Old 18th December 2007, 17:35   #6
Awaiting Email Confirmation
Oil Temperature
Generator Voltage
Oil Pressure
Exhaust Temperature
You have another cheap choice temperature sensors, if you use microcontrollers.
* Buy temperature sensors(from -50 to 125 DegC) ReDirect
* Above sensors are around .5$(==> Rs.30-50 including customs,etc) and one has different options for them (milliVolts, SPI method,etc)
* For temperature above 125 Deg C, you can use thermocouples(which are available at SP road in B'lore -- for example 'Vishal', where I bought Type-K for Rs.200). A Type-K thermocouple can measure temp upto 1200 Deg C(They have steel-sheath for protection ). But output of these thermocouples is in millivolts and you have to use ICs(eg MAXIM) for convering them into temparaure.
Hope this helps
Suryam is offline   Reply With Quote
Smart glass (variable tint level). Are they available in India? Chuchan Modifications & Accessories 22 4th July 2015 16:41
Calibration of Sensors used in cars? a4anurag Technical Stuff 5 9th March 2014 18:59
Power valves - What are they / how do they work? chetanhanda Technical Stuff 10 9th June 2009 16:51
sand/mud boards for 4x4 - are they available in India. sat 4x4 Technical 8 1st January 2009 10:31
Economic Bubbles - Why they form and why they burst ? DCEite Shifting gears 49 20th October 2008 16:04
