Old 2nd March 2011, 16:07   #136
saurabhkanchan's Avatar
Default Re: The Technical Truth? :Petrol vs Diesel
also can you clarify what type of pump is used in the fuel oil system? there is a return line connecting the pump with the fuel tank, what is that for?
saurabhkanchan is offline   Reply With Quote
Old 2nd March 2011, 17:01   #137
niteshbids, in one of the earlier posts you had mentioned about piezo injectors, can you give some information regarding the same? how are they different from regular injectors?
Old 2nd March 2011, 17:35   #138
niteshbids's Avatar
Thanked: 64 Times
The fuel pressure in the rails and the injectors are in the range of 1200 to 1800 bars in general applications. There have been engines in which the pressure goes as high as 2400 bars, though i don't know exactly which one it is.
I'm not aware of any separate overflow tank for the fuel. I really don't see the point, but maybe there is something. or maybe the Scorpio owner was confusing some other part. Not sure..
niteshbids is offline   Reply With Quote
Old 2nd March 2011, 17:59   #139
niteshbids's Avatar
Thanked: 64 Times
Don't know the exact type of pump used. All i can say is that it is a mechanically driven pump driven by the engine.
The main difference is the method of actuation. Instead of regular solenoids, the piezoelectric injectors use piezoelectric crystals for the actuation which have much faster response time (upto 5 times faster) allowing for more accurate metering of the fuel. The higher accuracy also allows for higher pressures which in turn give better atomisation.
Better atomisation and accurate metering result in less unburnt particles, lesser emissions and better efficiency.
Old 2nd March 2011, 18:01   #140
niteshbids's Avatar
Thanked: 64 Times
Sorry, missed this part in my earlier reply - The return line is same as the one coming from the common rail as well. The idea behind it is that wherever there is any excess pressure and needs to be released, there needs to be a provision for it.
Old 2nd March 2011, 21:20   #141
Thanked: 2,404 Times
By regular injectors do you mean the older non CR implementation? If so, these are entirely different. Injectors for CR systems are controlled by a electrical signal. These don't pop under fluid pressure.
Sutripta
Old 6th March 2011, 01:43   #142
niteshbids's Avatar
Thanked: 64 Times
By regular injectors, I reckon he means the more commonly used solenoid based injectors currently used in most cars running on common rail engines. The piezo injectors are still uncommon as they are significantly more expensive than the solenoid based ones
Old 6th March 2011, 11:31   #143
Radial piston pump.
Sutripta
The financial Truth: Petrol vs Diesel druva The Indian Car Scene 235 14th July 2014 10:49
Whats the Truth behind Diesel Cars! krish82 The Indian Car Scene 2 24th September 2011 01:56
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
Truth behind september 9/11 pentagon attack??? Harrie Shifting gears 13 2nd May 2005 19:26
Stretching the truth? Rtech The Indian Car Scene 10 4th August 2004 21:24
