| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I read an article in one of the websites which conducted a road test with the following two cases. Case 1. Windows down and No A/C Case 2. Windows up and A/C on This was done to check whether the mileage is better in the case of Windows down and No A/C as most peeople were believing. The resultant mileage was surprisingly almost same for both the cases. The argument for Windows down and No A/C is that due to the drag/wind resistance the vehicle will spend more fule to overcome when compared to a vehicle whose windows are closed & A/C on. This results in similar mileage for both the test cases. The moral of the story is be comfortable with A/C or without A/C. The mileage will be almost similar. DO we have any counter arguments for this study? Arun
__________________ Enjoy the little things in life, for one day you may look back and realize they were the big things. |
| | #3 (permalink) |
| BHPian | Yeah. You are right akshay. Now a days, the popular cities are so polluted that it forces you to always use the A/C. You wont be able to open the window at all.
| | #6 (permalink) |
| BHPian | We Test the TipsThis is the test article from edmunds.com
| | #8 (permalink) |
| Senior - BHPian | Arun, what is your experience. Would have loved to hear that from you, apart from what the test has to say. Exactly. There is no myth - the results will depend on the conditions that you do the test under. Highway + windows down: high drag, low FE. Might as well use the A/c. Tell us if you see similar results in city driving, and if you do, we can try understand why would it happen.
__________________ Life is Analog. Digital is an approximation. All kinds of animals come here ... and the occasional demon too ! |
| | #9 (permalink) |
| BHPian Join Date: Nov 2006 Location: Bangalore
| In normal driving that we do everyday AC will hurt FE. By the way the test which said "almost same" does not mention what was the small difference. Guess it favoured windows down. A small difference matters a lot in the long run. |
| | #10 (permalink) |
| BHPian | I would have loved to test the two cases. But you know it is difficult to use the A/C in the morning time when I go to office which is hardly 10-15 minutes drive from my home(mysore). Only time I use A/C is during noon time when I go back to office from lunch at home. As you say the mileage will be almost similar in the case of highway driving with the two cases we discussed.
| | #11 (permalink) |
| Senior - BHPian | Arun, using a/c has nothing to do with temp settings. You can use the a/c with low/no cooling to do the same tests. If you want more info on how cooling levels affects load on engine etc, pls go through other threads here that discuss these points. I would say that mileage on highway with a/c will be more than without a/c & windows down.
| | #13 (permalink) |
| BHPian | The ideal situation would be to roll the windows up & drive without the AC. This will give you the BEST Mileage, though you can do this only if its cold outside.
__________________ As they say in Italy 'The speed limit is the maximum speed attainable by your car' |
| | #15 (permalink) |
| Newbie Join Date: Apr 2006 Location: Melbourne
| True! But I guess it depends on type of driving as well. On highways, it’s a no-brainer. While doing a 100 with your windows down your creating more wind turbulence and drag than the power you’d loose with the AC on. Also the Aircon compressor steals less power when the engine sits at a constant RPM and that obviously doesn’t happen in the city. |
« Will A/C blower speeds affect the Fuel Economy?
Which is the Best Brand of Petrol for your car? »
| Thread Tools | |
Similar Threads | ||||
| Myth: UPS can't run on inverter? | linuxtechie | Gadgets, Computers & Software | 14 | 1st September 2008 09:36 |
| The 3,000 Mile Oil Change Myth | Superleggera | Technical Stuff | 1 | 18th June 2008 01:12 |
| CNG savings, a MYTH??? | yuv | Modifications & Accessories | 21 | 25th December 2007 20:08 |
| LPG savings, a MYTH? | yuv | Modifications & Accessories | 15 | 21st August 2007 17:24 |
| Ferrari Challenge - New Concepts of the Myth | salil_kulkarni | The International Automotive Scene | 4 | 19th November 2005 11:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
