Thread Tools
Old 20th December 2007, 07:42   #1 (permalink)
Unhappy Failing lights and immobilizer in an accent
Hi guys,
Have been facing a strange problem in my accent. On Saturday, I first had a duplicate key made for my Accent GLX from Sreenath Hyundai at Andheri for 1360/-. They programmed it for me too. Same day, I got replaced my ICE with a new player and front speakers.
This Tuesday, the left high beam conked off. Got it replaced. On Wednesday, the right high beam conked off. Replaced the bulb again. Today morning, Thursday, the car would not start. The engine immobilizer light remained off. It took me a couple of tries of removing the original key and reinserting it before the car would start. Considering that the keys are RFID based, I doubt it would be a loose connection.
Has anyone else faced the same problem? Could someone guide me what the issue might be as I plan to go for a long drive soon and do not wish to risk doing it on a car that might not start in the middle of the night or lose its high beam.
tmanish76 is offline   Reply With Quote
Old 20th December 2007, 07:55   #2 (permalink)
tsk1979's Avatar
Looks like your alternator regulator has gone for a toss. Get voltage checked
__________________
Reclaiming.....!
Old 20th December 2007, 10:43   #3 (permalink)
I went to my local mechanic who checked the battery and said that the voltage was normal. He even had me start the car and rev the engine while he was checking the voltage.
The car was fine all these months. Am just trying to understand if the new ICE or the key programming had any part to play in this.
Old 20th December 2007, 11:43   #4 (permalink)
Technocrat's Avatar
I am guessing that some wiring is getting short somewhere get the ICE wiring checked
__________________
Racing Throttle Response
Old 20th December 2007, 11:46   #5 (permalink)
Steeroid's Avatar
Electrical issues after changes to your ICE are usually attributable to the installation itself. I have had the same experience.
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 20th December 2007, 12:06   #6 (permalink)
if it was me, i would first not have done 2 changes together on the same day,... typical practices of engineering maintenance specified by CMM 5
but since it is done, please isolate all that is new in your ICE wiring and equipment. see if the rest of the car works fine.
i would have also pointed to the alternator regulator like tsk, but since the voltage remains the same after starting and revving the car, you can rule it out.
my doubt will be a shortcircuit in your ICE wiring, that might be indirectly affecting the HU screen's auto-dimming lead, that will be one of the leads that connect to the harness of the HU. this is the only link i see between the head-lights blowing out and the ICE being changed.
hope you resolve it soon and immediately. dont take chances in with electrical short-circuits.
__________________
...looking forward to sit a few feet above mean road level and away from potholes...
gbpscars is offline   Reply With Quote
Old 20th December 2007, 13:12   #7 (permalink)
Is it ok if I try locating the short myself? I was present when the guy installed the HU. Doubt there would be much rocket science in pulling it out and searching for any exposed leads.
But would this be in anyway connected to the erratic behavior of the engine immobilizer? The thought of the engine dying out in traffic and the car not starting again is scary.
Old 20th December 2007, 14:52   #8 (permalink)
sbasak's Avatar
Sometimes you can reset the immobilizer problem by disconnecting and reconnecting the battery.
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is offline   Reply With Quote
Thread Tools
Engine Immobilizer for Safari 2.2 VTT Lx amitk26 Modifications & Accessories 4 24th July 2008 11:07
Immobilizer for Palio Stile MJD? mohanaj Modifications & Accessories 1 18th June 2008 15:56
Immobilizer - Worth it?? Nimz Modifications & Accessories 46 9th May 2008 21:07
Need to replace front bumper of Accent GLS with that of a Hyundai Accent VIVA Peter Modifications & Accessories 0 10th March 2008 15:28
Was Kimi failing last year or was it the Mclaren? Stig Motor-Sports!! 44 4th May 2007 11:24
Powered by vBulletin
