Old 28th January 2008, 12:24   #46
nitrous's Avatar
Thanked: 285 Times
Used engine oil has acids,dirt,grime,etc of all sorts.
So,it is harmful in the long run (carcinogen).
Old 29th January 2008, 01:45   #47
Raccoon's Avatar
Thanked: 105 Times
Not only is used engine oil very harmful... washing your hands after the act isn't good enuf! You shoud'nt even be touching it! Use gloves if you have to...
Raccoon is offline   (1) Thanks Reply With Quote
Old 3rd May 2011, 13:56   #48
Thanked: 175 Times
Default Re: Santro Timing belt
My Santro is nearing 75k km mark and need to change the timing belt. I have been told that Gates is the Hyundai vendor for timing belts. Gates timing belt is available in the market for ~rs.400.
Can you please tell me if Gates is actually the Hyundai vendor for timing belts. Otherwise, how are Gates timing belts, are they as good as OE one's.
I want to try and get the belt replaced outside of HASS. The dealers in Patiala area (where the car is) are pretty incompetent.
amit1234singla is offline   Reply With Quote
Old 8th March 2015, 11:00   #49
Thanked: 24 Times
Default Re: Timing belt queries
Can anyone tell me how many belts and how many pumps are there in a car?
I have seen these items in my old car(800)-
1. Timing belt(on the right hand side, visible from the top/below)
2. Alternator belt(on the left hand side)-Responsible for charging the battery and also involved in the operation of the power steering.
3. Water pump belt/pulley-Responsible for the operation of the water pump.
4. Fan belt-responsible for the operation of the radiator fan.
Are there any other belts? Where is the cam belt? I have never seen it.
Thanks,
Ashok.
Ashok Naik is offline   Reply With Quote
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Skoda Laura DSG: Transmission oil & Timing belt replacement queries laurabeast Technical Stuff 12 2nd October 2013 18:53
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
Trouble after timing belt change hamadrayad Technical Stuff 1 6th November 2006 20:05
Changing the Timing Belt .. ?? khaadu75 Technical Stuff 5 5th February 2006 19:38
