| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | A very close friend of mine from my hometown is plonking my engine into his zen. The only problem being my car has been parked for the last month or more since I have a burnt clutch and I am finding it extremely hard to find a good aftermarket clutch that can hold up on the engine after TCing as well. The only options I have found so far are: 1. Exedy - Haven't heard great reviews about them. And after using their stage 1 (or was it 2?) clutch which lasted only for 9k kms inspite of being treated very well I was not impressed. Don't want to go down that lane again. So my eyes fell upon these. Would like to know what the experts would recommend amongst the 4 clutches I am going to post below. Streetability is not an issue. So here are the choices: 1. ACT - Two clutches which can be seen in the link provided below. ACT Product Search | Products ~ Advanced Clutch Technology® Which of the two clutches would be better in terms of tranferring optimum power.? 2. I also fell upon another person who makes custom clutches for almost all makes and when he showed me this my eyes lit up. The clutch looks out of this world and is a dual friction organic clutch. ![]() More info on the clutch. Input Spline Quantity: 18 Input Shaft Diameter (in): 0.750 in. Disc Diameter (in): 7.500 in. Disc Diameter (mm): 191mm Disc Material: Organic Disc Style: Sprung hub Pressure Plate Style: Diaphragm Throwout Bearing Included: No Alignment Tool Included: No Pilot Bushing Included: No Flywheel Included: No Counterweight Assist: Yes Mounting Hardware Included: No Quantity: Sold as a kit. Clutch Kit, Organic, 3/4 in. Diameter Shaft, 18-Spline, 7.5 in. Diameter Disc Thirty percent more holding capacity than stock clutches. The clutch is designed as a high-quality entry-level performance clutch for those in need of a superior stock replacement. Using the patented centrifugal weights (where applicable) and premium friction materials, the Stage 1 clutch system is perfect for applications with stock engines or mild power increases from minor bolt-on modifications. Another clutch from the same manufacturer. ![]() Input Spline Quantity: 18 Input Shaft Diameter (in): 0.750 in. Disc Diameter (in): 7.500 in. Disc Diameter (mm): 191mm Disc Material: Organic Disc Style: Sprung hub Pressure Plate Style: Diaphragm Throwout Bearing Included: No Alignment Tool Included: No Pilot Bushing Included: No Flywheel Included: No Counterweight Assist: Yes Mounting Hardware Included: No Quantity: Sold as a kit. Clutch Kit, Organic, 3/4 in. Diameter Shaft, 18-Spline, 7.5 in. Diameter Disc. The clutch that is up to 90 percent better than stock. Dual Friction clutches generate up to a 90 percent increase in holding capacity over stock systems. These clutch-and-disc sets are designed for engines producing high horsepower and big torque outputs. Perfect for 4WD vehicles, all Centerforce clutch systems provide smooth engagement and light pedal pressure, without compromising high performance. Now my question is which of the 4 clutches will best suit a G16B that might get TCed into a zen? Request the experts to fire away or ask any doubt pertaining to the clutches and I will try to get more info on them. PS: Unless I can source a good clutch this project cannot go any further. So need your assistance.
__________________ I am proud of you, binzy boy !!! Keep up the good work. Last edited by mclaren1885 : 23rd December 2007 at 13:25. |
| | #2 (permalink) |
| Newbie Join Date: Nov 2005 Location: delhi
| the above list looks good.. iam sure theres long list of better clutch then OEM in market. dont know much about clutchs .. but the custom clutch looks alright. .. not sure if it will last longer. i came across this as iam also looking for clutch for esteem 2002 |
| | #3 (permalink) |
| Newbie Join Date: Apr 2006 Location: Chennai
| The Exedy Stg 1 feels softer (weaker) than the stock. This was my exp whn I had used it in TC'd D15B. Either go with ACT or Exedy stg 2. Though I feel that the ACT stg 2 might be a li'l hard on your leg for B'lore traffic. |
| | #5 (permalink) |
| Distinguished - BHPian ![]() | I didnt feel the exedy to be that far out but yes i agree it would be better to with a stage 2 for a turbo. but you could still bend the leaves on the stage one to run it easily for a daily drive with a turbo.
__________________ Learning is a continuos job that keeps me busy. |
| Thread Tools | |
Similar Threads | ||||
| Automatic clutches | superavi | Technical Stuff | 7 | 22nd October 2007 17:19 |
| Needed some nice advice on performance mods for baleno 1.6 BS III | Aficionado | Modifications & Accessories | 10 | 16th October 2007 20:50 |
| 76mm Honda performance pistons, baleno performance cam & NOS kit for sale. | mclaren1885 | Shifting gears | 6 | 16th September 2007 14:02 |
| Forged Baleno Conrods , Crank , performance cam and intake manifold for SALE !!!! | mclaren1885 | Shifting gears | 0 | 24th April 2007 23:23 |
| Different types of Clutches ...? | amitoj | Technical Stuff | 11 | 12th January 2005 08:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
