Old 29th December 2007, 18:23   #1
jerish666's Avatar
Default Difference between MSR & ABS
MSR is a function that is shared between the brake system and the engine management systems. Is task is to prevent the driving wheels from locking up during engine braking. This could occur when the foot is quickly removed from the accelerator or when suddenly changing down gears. MSR prevents loss of steering control, due to slippage of the driving wheels, by increasing engine rpm, thus ensuring that the driving wheels do not spin and steering control is maintained. This sort of slipping is quite frequent when descending roads that are icy or snow-covered. Source:carpages.co.uk.
Anybody knows the difference between MSR and ABS?
jerish666 is offline   Reply With Quote
Old 29th December 2007, 19:12   #2
kpzen's Avatar
Thanked: 1,655 Times
Full form of MSR...??
Old 29th December 2007, 19:17   #3
jerish666's Avatar
Motor speed regulator.I want to know more about MSR.
Old 29th December 2007, 20:12   #4
kpzen's Avatar
Sorry Jerish. No idea about it. Let the gurus explain this.
Did some googling but all in vain.
Old 29th December 2007, 20:28   #5
CrAzY dRiVeR's Avatar
Thanked: 19,905 Times
Isn't this the Fabia thingy?
Old 29th December 2007, 20:39   #6
Shan2nu's Avatar
Thanked: 89 Times
Sounds like some sort of onboard system that revv matches when you down shift, in order to prevent sudden change in wheel rpm due to engine braking.
Shan2nu
Old 29th December 2007, 20:45   #7
jerish666's Avatar
They are using MSR for Alpha Romeo, Fiat Bravia ,skoda Fabia.
Old 29th December 2007, 20:59   #8
ram_hyundai's Avatar
Thanked: 48 Times
no snows so not bothered about it.any way hearing this for the first time.may be a talk in the snowing region.does anything like speed governors to do with msr.
ram
ram_hyundai is offline   Reply With Quote
Old 29th December 2007, 21:58   #9
hyper123's Avatar
Shan2nu
If it revv matches when you downshift, won't that negate the engine braking??
hyper123 is offline   Reply With Quote
Old 29th December 2007, 23:01   #10
Shan2nu's Avatar
Thanked: 89 Times
When you revv match, it makes for a smoother downshift (minimum clutch friction) and a more even rate of deceleration.
MSR sounds like the kind of technology that might be found on automatic/paddle-shift cars. So while an ABS system acts after there is a wheel lockup, MSR prob sees to it that the vehicle never reaches a rate of deceleration which might cause the wheels to lockup, due to engine braking.
Shan2nu
Old 30th December 2007, 14:51   #11
jerish666's Avatar
I think nobody knows what is MSD?
Old 30th December 2007, 14:58   #12
Shan2nu's Avatar
Thanked: 89 Times
MSD or MSR?
ABS only works when wheel lock-up is caused due to regular braking. MSR on the other hand sees to it that the wheels don't lock-up under engine braking.
Shan2nu
Old 30th December 2007, 15:46   #13
jerish666's Avatar
sorry it is MSR.Thank you Shan.
Old 30th December 2007, 17:16   #14
hyper123's Avatar
OK, now I understand. Thanks.
Old 1st January 2008, 11:30   #15
Alfa_Kilo's Avatar
MSR increases the throttle only when the system detects imminent wheel slip due to excessive engine braking. It shares the wheel speed and acceleration sensors with ABS. It does not reduce engine braking except in conditions where wheel lock/slip is beneficial like in soft snow and deep gravel. It is the nanny to engine braking as ABS is to wheel braking.
I personally prefer unassisted brakes (no servo, no ABS) on light 4x4s.
Alfa_Kilo is offline   Reply With Quote
Difference between a KIKI & Mico fuel pump on Nissan SD 25 engine joe3tom 4x4 Technical 12 17th April 2014 15:04
Difference between Iridescent & Pearlescent Paint? Epic Modifications & Accessories 15 11th May 2010 19:52
what's the difference between a grey market purchase and a B&W purchase wannabelean In-Car Entertainment 99 3rd June 2009 16:54
Difference between Poineer 6850 & 6950 HU saurabhkum In-Car Entertainment 16 27th May 2009 18:12
Difference between horns & compos! chiragh_bir In-Car Entertainment 7 19th May 2009 01:02
