Thread Tools
Old 30th December 2007, 11:22   #1 (permalink)
ece2k2's Avatar
Default Disarming autocop and setting it up - Help pls
Friends,
When I gave my Fiat Siena (equipped with Autocop XS) for service at Manipal Motors, I forgot to give the remote fob and just left the key with the vehicle. I got my vehicle back y'day and tried locking the vehicle using Autocop after reaching home. That triggered the alarm. I subsequently tried to lock the vehicle using the key and even then it started the alarm. After some more lock/unlock combinations with key/remote to get the autocop right, the alarm started blowing continuously. I had to disconnect the battery to stop the alarm.
Looks like the autocop got reset during service and needs some setting for getting it to the original condition. I do not have the autocop manual as I bought this car as second hand. Request your help to sort out this issue and get the autocop working properly.
Thanks,
Karthik.
ece2k2 is offline   Reply With Quote
Old 30th December 2007, 16:37   #2 (permalink)
Originally Posted by ece2k2 View Post
Friends,
Thanks,
Karthik.
Karthik,
Please disconnect the battery(negative) for say 30 seconds and connect back.That should solve the problem.
When you connect the battery back,
1just check if all the indicators come on ,
2.then press unlock and make sure the indicators stop blinking and the unlock alarm beeps twice(unlock chime !!!)
3.then lock and check that the doors lock and the alarm beeps once.
4If the alarm is continuous(for a few seconds) when you lock,it could also be that one door switch is not OK.
Please check and give us a feedback
__________________
Som
Challenge The Impossible!!!!!
Old 5th January 2008, 21:27   #3 (permalink)
ece2k2's Avatar
Hi Vigsom,
Unfortunately, I could not set the autocop right after following the steps. So, finally decided to disable autocop for now and disconnected the autocop power cable from the positive terminal of the battery. I hope to fix this some time later, probably during my next visit to manipal motors ...
thanks
- Karthik.
Old 5th January 2008, 22:38   #4 (permalink)
why don't you just visit one of the autocop service centers and get it fixed?
HappyWheels is offline   Reply With Quote
Old 5th January 2008, 23:38   #5 (permalink)
ece2k2's Avatar
I am planning to fix it at a service center happywheels. Just postponing my trip to the service center as far as possible
Karthik.
Old 7th January 2008, 18:42   #6 (permalink)
trrk's Avatar
The following is their regional office at Bangalore.
No. 19/3, Jayaranga, Ground & First Floor,
Railway Parallel Road, Kumara Park (West),
Nehru Nagar, Bangalore - 560020
Tel.: 9916135966
The service is supposed to be at your door step.
__________________
Rajesh
-Marina LS, Oct 05, 46336 (47015) kms, 13.97 kpl, 45km/day
-City CVT, Sep 07, 16862 kms, 13.22 kpl, 50km/day
trrk is offline   Reply With Quote
Old 7th January 2008, 19:00   #7 (permalink)
Team-BHP Moderator
Jaggu's Avatar
ok if you have a switch for your hood, while you reconnect the batt ensure that the switch is pressed (deactivated), then unlock (the system will lock the car) using remote and leave the switch free
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 1st February 2008, 23:31   #8 (permalink)
Hey folks,
This might sound like a rather weired question, but how do u disable the alarm without the remote?
My remote fell down yesterday and i realized today that it is broke. Today when I opened the door with the key, the alarm went off. Thankfully, I had the duplicate remote at my place or else it would have driven the entire occupants of my apartment crazy!
Is there anyway to turn this thing off in such situations? Plus, is it possible to get the remote fixed?
psynaps3 is offline   Reply With Quote
Old 2nd February 2008, 12:39   #9 (permalink)
trrk's Avatar
Hi, synaps3
Another remote could be sourced and programmed for your installation.
__________________
Rajesh
Old 2nd February 2008, 20:25   #10 (permalink)
how much would that cost? and whats the procedure for turning the alarm off without the remote? <-- I know this question sounds wicked
Old 3rd February 2008, 00:12   #11 (permalink)
rohan_fonseca's Avatar
Originally Posted by psynaps3 View Post
Hey folks,
Not to disturb the neighbours you could disconnect the siren temporarily( theres a coupler leading to it) untl you fix the problem.
rohan_fonseca is offline   Reply With Quote
Old 3rd February 2008, 20:30   #12 (permalink)
Deeps's Avatar
I was quoted 140/- for a new remote in delhi last month.
__________________
Stupidity is not a handicap! Park somewhere else!
Deeps is offline   Reply With Quote
Old 4th February 2008, 10:35   #13 (permalink)
nikunj_cal's Avatar
Ok , another problem but not Autocop this time ,infact it is for my guardian central locking system in my Indica. Very curiously the alarm starts to sound itself even though there has been no break in entry . I have to manually lock/unlock the car with my remote for the alarm to stop. This has led to high amount of irritation for the durwans and the drivers. The central locking is nearly 4.5 years old. We plan to keep the car for another year so no sense of going for a new central lock. Is it possible to cut out the wires to the hooter connected with the central lock and use the central locking only for locking/unlocking the doors ?
__________________
RIP, RIP, RIP AND AWAY.................
nikunj_cal is offline   Reply With Quote
Old 4th February 2008, 16:39   #14 (permalink)
trrk's Avatar
Hi nikunj_cal,
> doors
The intermittent siren may be due to one of the sensors being loose.
Do you have impact sensors fixed? You can reduce the sensitivity of the impact sensing part if that is triggering the alarm.
Finally, if you do not have any immobiliser once your alarm goes off, you can safely cut off the hooter wires and continue using the remote lock / unlock function.
__________________
Rajesh
Thread Tools
anti-stall setting . what is this ? joecherian Technical Stuff 6 15th August 2008 01:46
Clutch Setting in the Swift Optimus Prime Technical Stuff 4 27th July 2007 23:42
Normal and Reverse sub setting on HU ?! NIP Ask the Gurus 82 23rd July 2007 13:50
Help: Setting amplifier amit_sound DIY - Do it yourself 11 9th March 2007 08:15
pls pls wear helmets!!! ns_jughead Street Experiences 20 8th June 2006 22:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
