Thread Tools
Old 31st December 2007, 10:32   #1 (permalink)
forbhaskarm's Avatar
Default Scorpio : Weird electrical problem
Hi friends,
Although I have recently joined this forum, I have been following it religiously for over a year now.
As I was looking for some technical advice for a weird electrical problem in my Scorpio, I thought that with all experts available in this forum, somebody maybe able to help me out.
Problem:
After starting the car & running it for around 5-7 kms, there is a sudden increase in the electrical output generated by the car. Symptoms being:
1. The headlights become brighter
2. Horn sounds more shriller
3. Power windows roll up & down faster than usual
4. The turbo wine increases noticeably
5. The amp shuts down & sub-woofer stops to produce any sound
6. Additionally off late, the complete music system dies for a short while & comes back to life again
All the above problems go off after a brief period of time ~3-5 minutes. The whole scenario repeats over 3 -4 times before everything becomes OK.
This problems happens every time the car has been parked for over an hour or so.
I don't know if anyone has ever faced such a weird problem. Please let me know what could be the possible reasons for this & how it could be rectified.
forbhaskarm is offline   Reply With Quote
Old 31st December 2007, 11:06   #2 (permalink)
Originally Posted by forbhaskarm View Post
Hi friends,
Problem:
Hi ,
Pls get ur alternator checked for its functionality and the earth connections
for the audio . get the wiring checked as it seems to be shorting some where otherwise the amps would not shutdown .
it only shutdows when it get more power then expected actually a safety feature to prevent burn out of the amp.
__________________
Zen VXI
Baleno Vxi
Audi A4
abhishek_rait is offline   Reply With Quote
Old 31st December 2007, 11:21   #3 (permalink)
iraghava's Avatar
From the first 3 problems & the ICE problems you're facing it seems that your Alternator is acting up & is in spurts generating excess current & dumping it on to your electrical system.
This can result in a serious failure of break down so I would suggest you get the car checked up at the dealership or a competent Car electrician asap.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 31st December 2007, 21:17   #4 (permalink)
Thanks for the suggestions. I will definitely go to the service center & get it checked. Will confirm what they say.
__________________
Bhaskar
Old 7th January 2008, 10:16   #5 (permalink)
Thanks all for the suggestion. It was indeed a problem with the alternator. I got it rectified at the service station on 3rd Jan. The problem seems to have gone.
__________________
Bhaskar
Thread Tools
weird allignment/suspension problem. chandan Technical Stuff 3 4th August 2007 11:51
weird heating problem in accord prateek Technical Stuff 23 22nd June 2007 16:29
Weird problem...Palio Iknowthisguy Technical Stuff 16 31st August 2006 08:58
Weird computer bootup problem adya33 Gadgets, Computers & Software 7 28th March 2006 22:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
