Old 3rd January 2008, 23:15   #1
sreenivass's Avatar
Default Is it a fuse problem
I have an interesting problem with head lights and tail lights. After a 900 KM trip I see some lights not glowing. This is what I observe
- Upon lock/ unlock using remote: only side lights in RHS head light and LHS tail lights glow
- Turn on lights: Head lights come on, but small lamps in RHS HL set do not come on and only one side of the tail lights glows (forgot which one)
Can any one point out whats wrong, I suspect a blown off fuse.
sreenivass is offline   Reply With Quote
Old 3rd January 2008, 23:17   #2
esteem_lover's Avatar
Thanked: 445 Times
Check the bulbs. Mostly they are blown. Also check the voltage your alternator is putting out. Any decent battery shop will do that for you
Old 3rd January 2008, 23:22   #3
sreenivass's Avatar
Default so many bulbs at the same time ?
Is it possible that so many bulbs have burnt at the same time? If alternator is putting out less voltage it might be possible, is that what you mean ?
Old 3rd January 2008, 23:26   #4
Thanked: 445 Times
There is a regulator in the alternator which gives out the right voltage, when this goes kaput, there is a surge whenever you revv the engine & that could blow many electrical components starting from the bulbs.
Old 3rd January 2008, 23:40   #5
sreenivass's Avatar
Default Thx
Thanks esteem_lover, will get it checked either at a battery shop or mechanic.
Old 4th January 2008, 10:33   #6
Jaggu's Avatar
Thanked: 7,475 Times
Check bulbs this seems to be a bulb issue, after that take the car to a good electrical shop and see if the charging is proper. Usually if its fuse then the same side circuits will fail and not in diagonal.
To be on the safe side just check if all the grounding for wiring and holders and clips are in place also (DIY).
Looks like a freak bulb failure and again you might not have noticed the small marking bulbs going kaput earlier?
Old 4th January 2008, 11:31   #7
tsk1979's Avatar
Thanked: 15,648 Times
Its most probably a fuse issue. I had similar problem in my indica where LHS parking lights, rear lights, and number plate left side light went kaput.
On changing the fuse the problem went away, but again the lights went out. It was finally traced to a wiring issue. The coupler had a short.
Old 4th January 2008, 12:56   #8
Jaggu's Avatar
am confused i thought sreenivas mentioned that its the bulbs that are diagonal (front to rear) are bust, then the fuses are in tact???
Old 4th January 2008, 15:21   #9
amit_mechengg's Avatar
Thanked: 1,541 Times
its a wire short issue. some wires have fused up. get the wiring checked.
Old 4th January 2008, 19:00   #10
sreenivass's Avatar
Default Thanks
I have no clue if the fuses are intact. The lights diagonally opposite seem to be not functional. I am going to the mechanic tomorrow to check the bulbs, wiring and alternator unit.
Since there is a pattern of functional (or non functional lights), I felt it could be a fuse problem.
Thanks for all your inputs.
Old 6th January 2008, 00:49   #11
sreenivass's Avatar
Got the problem fixed today. No problems with alternator, bulbs and fuses. Some wiring problems fixed, not expensive. It sounded like hard labor though.
Old 6th January 2008, 14:03   #12
Thanked: 445 Times
Great. As long as there was no major damage.
Lanson Toyota wanted to change the entire blower. Problem was merely a FUSE!! diyguy Indian Car Dealerships 7 23rd August 2010 17:37
Fuse Holder Problem !!!! low_bass_makker In-Car Entertainment 39 2nd January 2010 20:31
M800 fuse blows out - need help svaid Technical Stuff 0 24th June 2008 12:35
2004 Ford Ikon 1.6 nxt repeated ECM Fuse blowout 1100D Technical Stuff 13 22nd February 2007 22:02
indigo cigarette lighter fuse location shldn Technical Stuff 3 11th May 2006 12:17
