Old 2nd April 2012, 09:29   #16
infotech58's Avatar
Thanked: 217 Times
Default Re: Is this a clutch plate Problem????
Originally Posted by ryan_wheelz View Post
Hey Infotech,
Im planning to get the clutch plates changed of my ohc from bhavani coming week.
Apart from the clutch/pressure plates what are the other parts i need to buy since i will buy them myself. What cost and brand should i look at also from where did you buy them.
Cheers !
i bought the parts from Prakash Auto Stores, SV Road, Santacruz.
you shall be able to get the same parts at approx. same cost with Shetty Motors (Turbhe OR Opera House).
excedy clutch and pressure plate - 3500
clutch bearing - 700
Gearbox Mounting: 750 (you may or may not need to change it)
clutch cable (non OEM, OEM is not available moslty): 400 or 450 (i am yet to change it)
give me a buzz (will send you my number in a PM) while you are at Bhavani; i'll drop by (it is approx. five mins from my workplace) to have a quick chat.
infotech58 is offline   (1) Thanks Reply With Quote
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Gettings brothers Accent VIVA CRDi but a mysterious issue and clutch plate problem... ajai_dev Technical Stuff 1 3rd December 2009 22:17
Clutch Plate Problem Safari VTT 2.2L maverick_atam Technical Stuff 10 4th November 2008 15:18
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Is my clutch plate damaged? johy Technical Stuff 15 25th April 2006 07:20
