Thread Tools
Old 8th January 2008, 10:31   #1 (permalink)
Default Compressor problem
Hi everybody,
I am having MFPI ZEN 2002 LXI model, I have this problem for last one year and its still not solved,I do hope one of you guys do help me on this.
When i put on my AC the CAR gets a drag feel, over that there is a continous noise comming from my compressor which can be heard even inside the car with all window closed and there is small amount of vibration along with it. I have shown to number of service people all have said that the compressor need to be changed. I have no problem with its cooling but only the noise, To change the compressor I have to shell out 12000-Rs. or i have to repair the compressor for which there is no surety that the noise will go. some have even said that due to the cars age the noise is bound to come.My car has done 54000 KM. I would appreciate if any one have simillar problem and where in mumbai i can get it done, I stay in Borivali area, Regarding the drag feeling I know its commen in ZEN but is any way that can be reduced by changing the compressor or the drag feeling is due to faulty bearing that ia with the compressor.
I also went to Sai service in borivali to get original wheel caps for my car and i was suprised to know that they do not keep ole zen's wheel caps, need info on where i would get original wheel caps in borivali, also I have to change my rims ,Please help
udaydesai is offline   Reply With Quote
Old 8th January 2008, 12:37   #2 (permalink)
risga's Avatar
I would recommend that you live with this. Even with repairs, there is no guarantee about its effectiveness.
When it does conk off, shop around and you would definitely be able to buy a compressor for much less. There are 2-3 companies making the compressor and supplying as OEM to Maruti. Buy it from their dealers. Dont buy from Maruti.
risga is offline   Reply With Quote
Old 8th January 2008, 16:09   #3 (permalink)
Originally Posted by udaydesai View Post
Hi everybody,
When i put on my AC the CAR gets a drag feel, over that there is a continous noise comming from my compressor which can be heard even inside the car with all window closed and there is small amount of vibration along with it. the compressor or the drag feeling is due to faulty bearing that ia with the compressor.
Was your car a victim of floods ever?If yes,it could be that the compressor bearing is the culprit.I can only suggest that you show this to a trusted A/C mechanic.I am sure Mumbai has plenty of competent angels.
As regards the wheel caps,I suggest you go to a accessories stockist in South/Central Mumbai for MGA wheel caps .You will get a set of four for approx. Rs.750 . You could also try KT(Kuan Tong) wheel caps from Taiwan..they look good and are reasonably priced
__________________
Som
Challenge The Impossible!!!!!
Old 8th January 2008, 19:11   #4 (permalink)
Team-BHP Moderator
Jaggu's Avatar
are you sure its compressor sound, zens are notorious for water pump whine very noticeable at ac idle (raised idle). Again the ac radiator fan will also make some noise.
i suggest if its minor noise dont bother, coz i would also recommend to go for a new comp unit rather than trying to repair it. AC comp is one of those things that never becomes perfect after repair, atleast in my experience.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 9th January 2008, 09:33   #5 (permalink)
No my car was not a victim of floods. The compressor's piston is the culprit and thats why the need to change, I have not changed it as I have no problem with its cooling. But the drag feeling is killing me
Old 9th January 2008, 09:39   #6 (permalink)
I want to ask one thing is there drag feeling for all ZEN ???
Old 9th January 2008, 11:07   #7 (permalink)
Super-Admin
+1. My Zen had exactly the same noise problem.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 9th January 2008, 11:56   #8 (permalink)
Change the compressor. If you keep using it the compressor clutch may also need to be replaced (if its not already reached that stage) and that will cost you atleast 2-3K more.
Bomi is offline   Reply With Quote
Old 9th January 2008, 11:59   #9 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Compressor overhaul+ bearing change will cost 7000rs, and this problem will come again after 30000kms or so of running.
Changing compressor is the only option, or you can wait till the compressor completely dies.
__________________
Reclaiming.....!
Old 9th January 2008, 12:02   #10 (permalink)
amit_mechengg's Avatar
dont go for compressor change. u can first go to workshops where they repair only AC's, they are specialists for AC compressors. they can fix ur problem or will recommend change if necessary.
__________________
" I dont Drive Fast , I Fly Slowly "
Old 9th January 2008, 15:55   #11 (permalink)
Let me put my problem in other way. I start my car, and then put on the AC, there is a continous noise just like a electric motor, then i put the car in motion and there is this drag feeling on the car as if there is another car that is being pulled by my car, the drag feeling is so much that even i press down the acc the car keeps crawlling and then after some time the car picks up. the compressor noise remain the same throught the drive.
Old 13th January 2008, 17:41   #12 (permalink)
HI ,
A compressor service will definitely not set you back by 7000 rs . max cost would be around 3000 rs . You can also get a brand new compressor for around 6000 rs . Esteem and 800 also have the same compressor ,but a different evaporator . So you can actually swap a 800 or esteem compressor .
cost of parts are as follows
bearing -250
cluth coil -275
clutch - 300-600
facing the clutch rotor - 50
changing the pistons -each piston costs around 200
The noise that you are getting might be due to the worn out bearing and not the pistons .If the bearing is worn out , it might just rub with the body of the clutch coil and cause sound . just change the bearing , I also think the bearing might need a reseating bush .
I guess the repairs might cost a max of 500 rs plus gas filling .
Old 13th January 2008, 18:02   #13 (permalink)
DirtyDan's Avatar
Default Are you sure it is the compressor?
How does it run with the AC turned off? Some here have written posts saying that these cars are notorious for water pump noise. Does the vehicle still "drag" with the AC off?
It certainly sounds like you have a moving part, bearing, about to seize up. You are lucky to get this warning. Bad bearings turn into non-functioning bearings very quickly. If you ignore it you will break down on the road soon. Then you will not be a happy camper.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 14th January 2008, 09:42   #14 (permalink)
With my AC off the car is a dream to drive and very much zippy, only when i put on the AC the drag is there.
Regarding the bearing part, I have shown the problem to Sai services people they say that the bearing is OK its the compressor piston that is causing the problem.
Old 15th January 2008, 08:59   #15 (permalink)
while they were at it , DID they try lubricating the pistons with compressor oil and rotating the crankshaft to check for the source of the problem ?
My advice would be to check at another outlet .
Thread Tools
Any feedback on this tyre sealant system with compressor? deepakvrao Technical Stuff 0 16th August 2007 00:08
AC Compressor Problem: Info & Advice manveet Technical Stuff 11 1st August 2007 04:25
MATIZ AC Compressor Needed sary Technical Stuff 0 22nd August 2006 12:58
AC compressor loading engine excessively Pankaj401 Technical Stuff 7 9th July 2006 19:35
astra compressor adilshah Technical Stuff 15 19th April 2005 22:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
