Thread Tools
Old 8th January 2008, 10:52   #1 (permalink)
harry2223's Avatar
Default problem with car electricals
guys i have m800 and installed an amp and subwoofer in it one year ago. now i have a problem in my car electricals from one month they behave abnormally sometimes indicators stop to work, when headlights are flashed the amp switches off. if the horn is pressed there is disturbance in subwoofer and speakers . i have replaced all fuse.also checked battery but the problem is not solved
__________________
harry
harry2223 is online now   Reply With Quote
Old 8th January 2008, 11:10   #2 (permalink)
low_bass_makker's Avatar
Disconnect all the audio equipment and then try using the car. See what happens and let us know.
__________________
156.6 db, naa....time is coming to cross it......
low_bass_makker is online now   Reply With Quote
Old 8th January 2008, 12:39   #3 (permalink)
risga's Avatar
Looks like the wiring for the audio system is not done properly. Have it checked by a good electrician.
risga is offline   Reply With Quote
Old 8th January 2008, 16:13   #4 (permalink)
harry2223's Avatar
had checked electricals without audio they are all working fine . got audio system checked from mechanic even he was not able to solve it. does it an indication of weak altenator.
__________________
harry
Old 8th January 2008, 17:09   #5 (permalink)
Like I asked in the other thread what audio equipment do you have ?
__________________
Old 8th January 2008, 18:06   #6 (permalink)
Infractions: 0/2 (10)
hello
check ur grounding cable and the rc wire which goes from ur head panel to ur amp
armotosport is offline   Reply With Quote
Old 8th January 2008, 18:07   #7 (permalink)
harry2223's Avatar
i presently have a 4 channel sound barrier amp, pioneer sub woofer, and a pioneer head unit.
__________________
harry
Old 8th January 2008, 22:09   #8 (permalink)
Which wiring are you using. Boss cable or some thing else. Also check all the amplifier connection points like ground and battery wire.
__________________
Old 9th January 2008, 07:41   #9 (permalink)
harry2223's Avatar
i am using a jbl wiring . i dont know whether it is fake or not as somebody on forum told me that it was fake as jbl had stopped making wiring kits a long time ago. i had tried putting my amp and wiring on my friends ikon it works fine there . but when i install back the same problem persist. are there any chances of problem in head unit.can i try by changing my head unit.
__________________
harry
Old 9th January 2008, 10:50   #10 (permalink)
Seriously speaking I did not understand your problem please try to explain it again in a little more elaborate way.
__________________
Old 9th January 2008, 11:57   #11 (permalink)
harry2223's Avatar
i have problem in electricals of my car . the problem only persist when audio system is on . when i press car horn there is disturbance in sound system.when i switch headlights on then also there is disturbance in sound system. when i flash headlights the audio system shutdown and restarts again automatically. i have got it checked from a mechanic but he is also unable to solve it he told me that audio system is faulty so i tried installing my car audio system in my friends car to check whether the system is faulty but it worked there without any problem.plz help me out because there is a lot of disturbance in the sound while pressing horn and flashing lights.
__________________
harry
Old 9th January 2008, 23:43   #12 (permalink)
It seems to me that the HU ground is not connect correctly . Try grounding the HU directly to the car chassis rather than connecting through the car wiring.
__________________
Old 10th January 2008, 08:02   #13 (permalink)
harry2223's Avatar
dear friend i had tried grounding the head unit to car chasis earlier but the problem was not solved . i am totally helpless what to do.the another problem that i came to know yesterday night when i was coming home that the headlights become more brighter when i accelerate. can it be an altenator problem.
__________________
harry
Old 12th January 2008, 21:04   #14 (permalink)
hello
if your alt is over changing your head light bulb will fuse. its your grounding problem get it checked by a good audio prof
Old 13th January 2008, 15:37   #15 (permalink)
get your car alternater check or lots of things will get fused.
__________________
Thread Tools
New Electricals in Karizma Godma Motorbikes 13 25th December 2007 22:10
Any electrician in Pune who looks at vehicle electricals? spadival Modifications & Accessories 6 9th September 2007 12:28
Upgrading electricals COUGAR Modifications & Accessories 4 4th February 2007 20:30
Some problem with Car Insurance ... hari_rama Indian Car Dealerships 7 26th January 2007 09:55
Car audio problem. karthik247 Ask the Gurus 6 14th June 2005 21:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
