Old 9th January 2008, 17:01   #1
Default Zen - Engine Switching off on long drives
Hi All
I have a Carb Zen which has a rare problem. The Engine is switching off during long drives.
This I noticed when I was driving on a highway with a speed of 80-90kms consistently. First 30-35kms there was no problem & suddenly the engine switched off. I kept the accelarator pressed to see whether it will start again & after 10-15secs engine started with jerks.
Then again it stopped after 10kms & the frequency kept increasing. After some time it started repeating every 3-4kms.
It was very annoying & was very dangerous because couple of times the car stopped in the middle of the road(this was during climb) & took 10-15 secs to start and move again.
Surprisingly I dont find this issue when driving in stop-go or city traffic.
I got the car checked for spark plugs which they told was Ok, Alternator was fine. fuel flow is OK.
garage guy told that they will check the fuel pump for any problems.
I dont know what is the actual problem.
Guys suggest on how to solve this issue.
Tiger is online now   Reply With Quote
Old 10th January 2008, 11:35   #2
sushrutha's Avatar
Thanked: 324 Times
Some questions.
What model the car is ? How many Kms It has run ?
Have you done Carburettor overhauling(when was it done last) ?
I think here clogged carburettor is the culprit.
Also check out for faulty spark plug wires, n Airfilter.
Old 10th January 2008, 12:21   #3
Fazal's Avatar
Hi Tiger,
Sounds like
1. Clogged or dirty fuel filter
2. Improperly functioning fuel pump
also, like sushrutha said, checkout the plug wires & air filter
depending on how many KM's your car has clocked, go with replacing the fuel filter
ALSO, does a carb zen have a PVC valve?
Keep us posted
Fazal is offline   Reply With Quote
Old 10th January 2008, 16:29   #4
Thanks for the suggestions,
It is a 97 model & run 75000 kms.
I got the carburetor cleaned with 3M choke & carb cleaner, & airfilter was cleaned some 500kms back.
I will get the fuel filter, fuel pump, plug wires checked this saturday.
I dont know about PVC valve, will check.
Old 10th January 2008, 17:13   #5
esteem_lover's Avatar
Thanked: 445 Times
Check your vaccum hose, it could be cracked, that could be the culprit. Replace all the hoses that lead in & out of the carb.
Old 10th January 2008, 18:05   #6
amit_mechengg's Avatar
Thanked: 1,538 Times
check electricals mainly the coils..i have observed when they get hot after long run the resistance increases and this happens ..the current stops flowing.
Old 10th January 2008, 18:35   #7
DirtyDan's Avatar
Thanked: 744 Times
Default wire harness chafing, short circuiting.
Originally Posted by Tiger View Post
Hi All
Carefully inspect all wires and especially wire harnesses under the bonnet for chafing. Movement of wires and their harnesses due to road vibration often leads to insulation quickly wearing off wires (chafing) and then they short circuit. This sounds more like an electrical problem to me than a fuel or vacuum hose problem. Check your battery leads, too.
Old 10th January 2008, 21:08   #8
Thanked: 143 Times
Checked temperature? I know of one case where the engine used to switch off coz the temperature gauge was not working, resulting in the cooling system not functioning properly.
Old 10th January 2008, 21:29   #9
QUOTE]Check your vaccum hose, it could be cracked, that could be the culprit. Replace all the hoses that lead in & out of the carb.[[/quote]
The crack in pipes can cause the problem...
A kind of same problem occured to our car(800 carb) once. It used to stop with a jerk as if there is no petrol. The problem was with petrol inflow pipe and some other pipe cracked(radiator or oil) not sure which one, they created this problem. They informed us that the other liquid is getting mixed up with petrol and causing the problem. They changed the both pipes and that problem did not repeate again. May this info help you
Let us know what caused the problem.
ravi_28_8 is offline   Reply With Quote
Old 10th January 2008, 21:57   #10
humyum's Avatar
Thanked: 2,186 Times
After u check all that is mentioned above and your problem does not get sorted also check the keyhole where u insert the key to start the car.
Had the same switching off problem in my 800 and took me a month to diagonise it to the keyhole.It was heating up and stopping the flow of current.
Initially started with misfires and then reached to a stage of total shutdown like u.
humyum is online now   Reply With Quote
Old 11th January 2008, 10:28   #11
BMW-X5's Avatar
Thanked: 9 Times
Exactly samething had happend to My sister's M800 a couple of years back. It was happening only after running 50-60 kmts. This issue was getting worst after travelling 20- 30 kmts more.Faulty fuel pump was the culprit. This issue has never resurfaced since i changed the fuel pump.
BMW-X5 is offline   Reply With Quote
10 automakers sued over keyless ignition not switching engine off GRAND23 The International Automotive Scene 29 2nd September 2015 20:23
Switching off the engine at traffic lights Rough Square Technical Stuff 83 14th April 2015 14:57
Switching ON headlights shuts OFF the engine aargee Technical Stuff 35 21st July 2013 23:09
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Engine Smooth after switching off and on again DWind Technical Stuff 6 21st December 2009 18:54
