Old 9th January 2008, 23:14   #16
androdev's Avatar
Thanked: 2,305 Times
PD can match or beat CRDI in terms of FE, drive (power torque etc), tolerance to bad fuel which are primary engine characterics.
CRDI is better in terms of cost, emissions, noise which are IMHO important but secondary.
i am sure CRDI will get there soon but not yet there.
Toureg PD got too many pumps thats why it got CRDI first not because CRDI superior engineering (as of now)
i am the first one to say CRDI is the future. but it first solved manufacturers (cost) and govt (emissions) concerns. yet to fully please the driver like PD. it will though.
androdev is offline   Reply With Quote
Old 9th January 2008, 23:28   #17
BUSA's Avatar
Originally Posted by burnt. View Post
I dint know that the Octy 1.9 TDi is a next gen crdi.
Its not a CRDi, its a TDi, which is different from CRDi as well as PD.
Old 9th January 2008, 23:34   #18
burnt.'s Avatar
Man, I was being sarcastic.
burnt. is offline   Reply With Quote
Old 10th January 2008, 01:41   #19
abhibh's Avatar
Thanked: 34 Times
VW have Common rail engines which they use in Audis. They are still marketed as TDi or Clean TDi
AFAIK the 4.2l and 30.l TDi in Audis are Common Rail units and A4 also have common rail now as they developed 2.0 Common rail unit.
As for technology it depends upon how one uses it. PD costs more than CRD but overall PD is at par with CRD technology. But still CRD has edge.
Old 10th January 2008, 03:05   #20
rajtheindian's Avatar
Originally Posted by mail4ajo View Post
I don't understand why Skoda is giving the Pumpe-Duse diesel technology to India when VW itself is moving away from it to Common Rail. I read a report on it recently.
Are they dumping the technology on us? Or maybe its cost considerations.
Pumpe-Duse tech has some advantages over common rail, one of which is better adaptivity to bad fuel which is a must in India. Someone needs to do a neck to neck study with the DDiS. I also learned that Pumpe-Duse engines produces better torque than its common rail counterpart. Any info?
This may be because each cylinder head has an injector or in other words each of them have individual Pump, which makes it delivering better torque but sadly they will not be able to meet the emission standards, hence PD is replaced with CRDI
rajtheindian is offline   Reply With Quote
Old 10th January 2008, 06:04   #21
VW is moving away from PD as it is not able to meet the emission standards, so in europe and US they are shifting to CRDI engines, in india still they can manage with their PD
Old 10th January 2008, 10:03   #22
Thanked: 11,037 Times
A lot of people are wary of second hand crdi engines in Europe due to potential maintenance costs and effects of misfueling - puting in petrol by mistake.
Old 10th January 2008, 12:20   #23
One of the reason why I dropped the plan for buying Laura is considering the fate of PD. Here's the my version of the story
PD can produce more torque, and it has less pollution as better atomization can be achieved at 30,000 PSI. But I couldn't find why still it couldn't meet Euro 4/5 norms, when crdi could meet.
PD produce more noise, and vibration. Opening/Closing of individual pump results this extra noise/vibration.
PD in Laura has Solenoid controlled injectors. VW has replaced this tech with Piezoelectric controller in some newer models.
PD is more expensive to manufacture and refinement is difficult. Coupled with this, inability to control pollution led VW abandon this and move on to crdi.
VW put lot of money in developing PD, so it has to dump it some where, and its India.
swageo is offline   Reply With Quote
Old 10th January 2008, 17:50   #24
tadukuttan's Avatar
Thanked: 22 Times
Hey ajmat, are you saying that putting in petrol into a PD/TDi car is okay? Of course, I have not tried it, but I would imagine that petrol going into any diesel engine would have the same disastrous consequences?
tadukuttan is offline   Reply With Quote
Old 10th January 2008, 17:57   #25
BUSA's Avatar
If petrol is put into any diesel engine it can be disastrous, whether its PD, CRDi or old school TD
Old 10th January 2008, 21:30   #26
I don't care much about CRDi or PD, all I know is that the Golf TDi with the PD technology (100 bhp) in Canada gives 46 mpg in the city and 61 mpg on the highway, and that is simply astonishing.
The hybrids have a lot of catching up to do now.
sujaylahiri is offline   Reply With Quote
Old 10th January 2008, 21:58   #27
jerish666's Avatar
with this.I think it has 2.0L engine.
jerish666 is offline   Reply With Quote
Old 10th January 2008, 22:02   #28
BUSA's Avatar
46 mpg is something like 19kmpl, which is truly amazing.
Old 10th January 2008, 22:53   #29
Neither is okay. suppose you pt a little bit of petrol in a TDi car, you could get a away by draining the petrol off or filling the tank up with diesel (if you put around 5 litres).
In a CRDi, the tolerances are so fine that the petrol with dissolve the lubracity provided by the diesel oil
Old 11th January 2008, 03:35   #30
It has the same 1.9L TDi as before, except that after adding the Pumpe Duse technology in 2004, they bumped up the peak power to 100bhp and peak torque to 177 ft lbs. The older one had 90 bhp and 155 ft lbs of torque.
Oh and it's pronounced as "pump-ah du-sah".
Nano Diesel with CRDI technology coming? EDIT: Plans scrapped for now bullock-Car The Indian Car Scene 469 24th November 2015 18:38
Migrating from Petrol to Diesel CRDI cars:How to drive better ? GSMINC The Indian Car Scene 33 16th December 2011 19:17
Types of Diesel Technology Mohnish Technical Stuff 21 1st February 2009 10:53
is k&n replacement better or a cold intake better? redsfx Modifications & Accessories 1 31st May 2007 16:58
Better roads.. better late (than never) Laxminarayan Street Experiences 1 12th April 2006 03:14
