Thread Tools
Old 5th March 2008, 00:18   #46 (permalink)
Xehaust's Avatar
Hey Shashank, im in the same boat, only i havnt bought everything
Xehaust is offline   Reply With Quote
Old 1st April 2008, 16:46   #47 (permalink)
Whats the harm in using water in radiator and not coolant in my Indigo Marina Dicor? What would eb ht eill effects?
__________________
Let it go...after all you live but twice.
wanderernomad is offline   Reply With Quote
Old 1st April 2008, 16:53   #48 (permalink)
spadival's Avatar
It will probably rust a bit more.. And water probably evaporates a lot faster if not mixed with the coolant. Better spend a few hundred bucks to put coolant mixed with water.
spadival is offline   Reply With Quote
Old 1st April 2008, 23:21   #49 (permalink)
I guess the coolant would be around Rs.150 bucks only..
Shashank.A is offline   Reply With Quote
Old 2nd April 2008, 11:13   #50 (permalink)
coolant (mixed with water) has a lower freezing point and higher boiling point than water. Hence you can run your car longer with coolant than without
suvi is offline   Reply With Quote
Old 2nd April 2008, 12:18   #51 (permalink)
Did i mention earlier that my car is running like a dream...unfortunately I didn't have much of knowledge about the cars, and in this checklist carburetter cleaning was not mentioned and I didn't get it cleaned...however I have got it done now and my car is as good as new..
Old 8th August 2008, 15:47   #52 (permalink)
Raajiv's Avatar
Hi Guys,
My i10 (6 months olde) is nearing 5K kms now.I am planning for a wheel balancing.Do i require wheel alignment also since i am not facing any dragging issue.
Please advise.
__________________
Acheivement is almost AUTOMATIC when the goal becomes inner commitment
Raajiv is offline   Reply With Quote
Old 8th August 2008, 17:12   #53 (permalink)
Originally Posted by Raajiv View Post
Hi Guys,
Please advise.
You should understand these three terms -
1. Wheel rotation - Changing wheel positions
2. Wheel alignment - All angles - camber, caster and toe are aligned.
3. Wheel balancing - some weight to added to balance wheel movement/rotation.
For your new car with 5K on odo, IMHO you only need item 1. Remaining item 2 and 3 during normal use, are required ~10K km only
omishra is offline   Reply With Quote
Old 8th August 2008, 20:42   #54 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
Car went for a service today. This was my third service in four and a half years. Car hasn't run that much though. Odometer says 26845 km. Due to lack of time they couldn't wash the underbody. I don't allow them to shampoo and wash the body anyway. So sometime next week they'll do it as whenever I can send the car.
Costs:
Mobil 1 = 4100/-
ABRO engine flushing fluid = 237/-
These are supplied by me.
Injector and fuel system cleaning = 1850/- (they've used 3M fuel cleaning solution of one can)
Oil filter = 67.56/-
Seal ring = 10.67/-
General service and check up = 550/-
No problems found anywhere.
Old 9th August 2008, 16:19   #55 (permalink)
Super-Admin
Wow Rudra, only 27000 kms in 4.5 years. That car's gotta be looking & feeling like new. Does she run better after this service?
GM sure is sticking to their claims of low maintenance. That's as cheap as oil filters get for this segment of car.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 9th August 2008, 17:27   #56 (permalink)
babhishek's Avatar
Injector and fuel system cleaning = 1850/- (they've used 3M fuel cleaning solution of one can).
I had a quick query - apart from fuel injector/ throttle body cleaning; what additional work is done for "fuel system cleaning".
I found 1850/- quite expensive, as I was told that a whole can is not required, unless the fuel system cleaning requires a lot of work/ fluid spray
__________________
Cheers,
AB.
babhishek is offline   Reply With Quote
Old 10th August 2008, 19:00   #57 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
Look and feel I don't know because I see it everyday. Running is always smooth. I haven't really taken the car out after that because I was not in town.
Looks like it.
I haven't spoken to their service manager. I had asked for fuel injector/ throttle body cleaning only. Will check out on Monday.
I found it expensive too. But if it's dealer/service center provided 3rd party stuff then price got to be higher. Again this will be checked on Monday.
Old 11th August 2008, 10:31   #58 (permalink)
abhik's Avatar
@GTO you mentioned changing KnN/High-Flow Filter at 60K kms. Is that really required? Because as per KnN the warranty of the filter is at double the above figure and needs regular cleaning/service after 20K odd kms. I understand that Indian conditions are very dusty so the cleaning/service bit has top be more frequent but that if done regularly should be fine. Should'nt it?
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 17th August 2008, 22:05   #59 (permalink)
Hi Guys !
I just got my car ( Ford 1.6 ) serviced at a local garage. The car was given to the Ford A** on a regular basis before that. During service, while the guy was cleaning the air filter, I noticed that he had just raised the top cover slightly to remove the filter. I insisted that he should open the complete cover as I wanted to see the housing (had a vague idea that the Mass air flow sensor would be located there and wanted to see it) - what I actually saw gave me the jitters. Rotting leaves in the air filter housing !
Just for the heck of it, checked up with a Ford supervisor whether there is any need to clean the housing - and the reply was " Sab, thoda sa cover tilt karne se filter nikal aata hai - poora to hum service mein bhi nahin kholte". The leaves had actually blocked a vent.
I would suggest ( for those with standard air filters) to get their housing checked - especially after a service - will give you a good idea as to how much care has gone into the service.
Other things : I was going through the manual and it says the gearbox oil for the 1.6 need not be replaced. The oil has to be filtered and will deteriorate with time. Can any body shed some light on this ?
dashoin is offline   Reply With Quote
Thread Tools
How to maintain a log book for a car TractionAvant Technical Stuff 14 1st July 2008 12:02
Palio Service checklist amitverma Technical Stuff 18 22nd May 2008 16:44
Zen to complete 50k on Odo - A Service Checklist Required nicejits Technical Stuff 2 28th February 2008 09:50
New to 4 Wheelers and hope to learn good tips and tricks to maintain my car. tango6996 Introduce yourself 3 24th March 2007 12:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
