Thread Tools
Old 14th January 2008, 17:37   #1 (permalink)
rajivanoj's Avatar
Default Indica - radiator water problem
in my indica, Radiator water decreases by around 100-150 ml during 150kms travel...therez no hose leak , engine is good condition (it starts in a single heater time even in cold morning)...no oil trace in radiator can, so i hope there wont be any gasket leak..
what must be the prob? but there is no coolant when i bought second hand..its water..
temp gauge also shows almost half the gauge, so ..the fan is running..Will the prob be solved with coolant? or any other???
rajivanoj is online now   Reply With Quote
Old 14th January 2008, 23:58   #2 (permalink)
wolfinstein's Avatar
If its water then it will evaporate....check condition of the coolant mix, if its totally watery replace it.
Drain the entire coolant resorvoir, Add 6 Ltrs of OEM Thanda Raja ( HP ) or Golden Cruiser, should solve the issue and reduce worries for a year or two, unless on some other case like Leakages or Radiator Damages.
I replaced the Coolant to Thanda Raja Pre-Mixed @ Rs 115 per Ltr when the coolant level in my XETA had dropped low over a year.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 15th January 2008, 01:35   #3 (permalink)
.anshuman's Avatar
It can be blown off gasket that must be mixing coolant with oil,or a hose leak,whatever but never take chances with cooling system its time for you to go to a service center and get it checked A.S.A.P
__________________
Anshuman Bishnoi
Hyundai Elantra CRDi 2.0
Mahindra Scorpio VLX 2.2
Suzuki Swift VDi ABS
.anshuman is online now   Reply With Quote
Thread Tools
Strange problem with Petra - Radiator fan jraj Technical Stuff 8 24th August 2008 14:00
Sunroof / Water leaking problem in 2007 Optra 1.6 LT Royale swayam Indian Car Dealerships 16 11th August 2008 15:02
Water seepage problem on testdrive swift diesel .anshuman Test-Drives & Initial Ownership Reports 17 25th October 2007 18:55
Ford Ikon: A/c Water Diverter Valve problem Absar Technical Stuff 12 16th May 2007 02:38
problem with Indica V2 msk_kapoor Technical Stuff 6 31st January 2006 13:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
