Thread Tools
Old 19th January 2008, 00:31   #31 (permalink)
DirtyDan's Avatar
Default Yes serious.
Originally Posted by dionysus View Post
Dirty dan you serious about using lizol? sounds a bit extreme!
Yes I am serious but just a little. A shot glass full. However, the smell will come back eventually and you will have to do it again.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 19th January 2008, 14:12   #32 (permalink)
Originally Posted by IronWolf View Post
what I still dont get is when the A/C is on for about 30-40 mins the A/C ducts should be quite dehumidified, however when you switch off the A/C button the foul air hits you almost instantly.
I dont believe that the humidity levels increase so much in those few secs to pick up the fungal smell again.
The cooling coils pick up moisture from the air. The air does get dehumidified, it's just that the humidity is retained, as water by condensation, on the coils. Since coils are always moist, they provide a good place for fungus and bacteria to grow. This is what gives the bad smell.
The only easy cure is: before shutting off the car after a long drive, put the blower on re-circ. mode, turn the temp control all the way to hot (put compressor off) and let the blower run for five minutes or so. This dries and heats the coils and sterilises the fungus/bacteria.
__________________
Hyundai Getz 05
Baleno Vxi 05
filcord is offline   Reply With Quote
Old 11th February 2008, 13:55   #33 (permalink)
Default Foul Smell from Fan
Hi
I am getting a foul smell when I am running my fan in Swift. In reciruculating mode, I dont get the foul smell. What could be the cause of this? and how can we get it rectified. I am concerned about my sons health in this fould smell. What steps do we need to take during the cleaning operation.
Appreciate your kind feedback and inputs
lambuhere1 is offline   Reply With Quote
Old 11th February 2008, 15:29   #34 (permalink)
The moist air is the cause of this problem - it could also lead to development of fungus/mould in the AC. Before you switch of the engine, ensure that the AC is switched off but the fan continues to run for atleast a minute (I typically switch off the AC the moment I turn into our street so that I dont have to wait another minute before i get off). This dries up the duct to some extent and you will not have the smell any longer.
If the problem still persists, get it looked at in a service center.
hsejars is offline   Reply With Quote
Old 11th February 2008, 15:59   #35 (permalink)
deep_bang's Avatar
Does the foul smell come up only without AC or does it happen with AC ON?
I have seen many cars which has a bad smell when AC is switched OFF after a few minutes of running with AC ON. This happens irrespective of whether in recirculating mode or fresh air mode.
deep_bang is offline   Reply With Quote
Old 11th February 2008, 16:06   #36 (permalink)
It happens without AC. With AC I have not yet tried. Let me see about it tonight. This smell is in fresh mode only.
Do you see any "dead" animal inside the tubing. I don't want to be a scape goat smelling dead meat
Old 11th February 2008, 16:59   #37 (permalink)
snaronikar's Avatar
Even it happens in my Ikon. When the AC is switched on, the first few seconds about 20~30 seconds I will get a foul smell and then it dies off.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 11th February 2008, 19:13   #38 (permalink)
vebmetal's Avatar
I started having this problem in my Estilo a few months after purchasing it. Have shown it to Marketing Times (Maruti owned service centre) about 3 - 4 times. Each time they cleaned some other part, and the last time they cleaned the whole thing, but no solution. Their final explanation, and my consequent acceptance of defeat, was that this just happens. They suggested buy AmbiPur. But for now in the winters there is almost no problem. So will wait till the summer.
This is something different. The above problem will happen when you turn the AC off after having used it. Yours is something different.
__________________
People who talk in metaphors ought to shampoo my crotch.
-Jack Nicholson
As Good as It Gets (1997)
vebmetal is offline   Reply With Quote
Old 11th February 2008, 19:51   #39 (permalink)
Absar's Avatar
In the first place why do you use Fresh air mode? A/C's work best in recirculated mode. By keeping it in Fresh mode, all the smells from outside come in the cabin, just you get coldness with outside smells.
Has to be smelly dirt stuck to the blower.
cya
A
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 11th February 2008, 22:15   #40 (permalink)
smith's Avatar
seems lots of these cars are suffering from this problem. i discussed the same with our fellow bhpian pompi( id alankarmotor) who has a maruti sevicemasters at patna . i have written about him in some of my previous posts . for precisely this very problem subros the oe supplier of ac's to most of the indian car cos. took his advice & he managed to find the culprit & the cure. it has something to do with the quality of resistance (ceramic) used in these ac's. pm him & he will be able to sort it out. in fact i will ask him to post a detailed reply on this thread for the benifit of all u guys.
__________________
A man with a gun is a citizen, a man without a gun is a subject.
smith is offline   Reply With Quote
Old 12th February 2008, 12:46   #41 (permalink)
Default Foul Smell From Blower/a.c
HI GUYS,this is a very tricky probelem which most of the technicians and service engineers have not been able to figure out. Fortunately we have diagonised. This happens because of the blower resistence ,every one of u who have faced this probelem will recall that this is prominent when blower is operated at lower speed mode. this is when the resistence gets heated up. The resister wire is covered with porcelene matrial, the smell comes from this matrial when heated. This explains why the smell goes off when the compressor is switched on because the resistence gets cooled.The resistence allso gets cooled when the blower is operated at higher speed. And when the blower is operated at max speed then this resistence is bypassed and will not cause smell.Vehicles that come with fin type resistence like FORD IKON etc.will not have this probelem.
During moments when I switch of the AC and keep the blower running, my swift produces a peculiar unpleasant smell. The smell vanishes the moment I switch off the blower. This is only while the AC is on off mode. Does anyone have a clue as toi why would this happen!
Please note this is not a momentary phenomena, the car has been doing this for about an year!
alankarmotor is offline   Reply With Quote
Old 12th February 2008, 20:11   #42 (permalink)
theexister's Avatar
I was following this thread very closely since the same problem started with my Fiesta a few months back but I just thought it was due to moisture build up. The smell eventually used to go away after keeping the blower on for a minute or so.
The resistor material seems to be the best explanation. Thanks alankar for the info.
theexister is offline   Reply With Quote
Old 12th February 2008, 20:20   #43 (permalink)
kuttapan's Avatar
I used to get some ****ty smell with only the blower on, but it vanished when the A.S.S did some cleaning?? maybe mine wasn't the resistor, then.
kuttapan is offline   Reply With Quote
Old 12th February 2008, 20:33   #44 (permalink)
wischvuanaudh's Avatar
hehe... guys, once the same problem appeared in my grandpa's ambassiador. and guess what the mechanics found...??? a rotting dead rat..!!
wischvuanaudh is offline   Reply With Quote
Old 13th February 2008, 07:38   #45 (permalink)
When did you report to them and what all did they clean buddy ?
Thread Tools
Need help with Honda Civic - foul odour navin Technical Stuff 36 5th July 2008 16:31
NEW Swift Petrol Burning Smell cyneverdie Technical Stuff 3 11th February 2008 19:30
Strange sound from the AC blower amit_mechengg Technical Stuff 8 16th January 2008 18:29
burning smell on swift micraft Technical Stuff 29 11th January 2008 11:11
Swift: Ventilation blower pumps in HOT air k36 Technical Stuff 16 18th April 2007 13:35
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
