Thread Tools
Old 15th January 2008, 20:30   #1 (permalink)
aravindwarrier's Avatar
Question Fiat Palio 1.2- Rusted Exhaust replacement: Stock/ FFE?(Cochin)
My dad uses a Fiat palio 1.2 sport , June 2002, till date run 40K . Things were running fine till a couple of months back, when problems started cropping up, one by one(some sensors playing fool, powerwindows packing up etc) .
I'll leave all the other issues for a later thread, but right now we are facing a problem, as the exhaust muffler and the entire piping seems to have rusted (Not a Fiat problem, rather due to the heavy monsoons in Kerala) .
The A.S.S guys at Cochin (R.F Motors) says the entire exhaust inclusive of two mufflers(?) and piping need to be replaced, and will cost 10k. And of course, they have to order it and get it from factory, as ready stock is not available which means we have to wait for a months time. As usual, I am out of station, and have no means to personally acertain the facts as well as the figures.
My doubts are:
1.What do they mean by 2 mufflers?Are they correct in this count? The whole thing is one single unit, including the cat-con?
2.Is the quoted cost/time realistic?
3.If it is, is there any way to get it off the shelf ?
4.Any point Going free flow way? Dad would prefer to be discreet, and I dont see myself laying my dirty hands on her any time soon, so the noise is lost here.
4.Otherwise , does anybody in here have a stock exhaust lying idle ( any sense in putting up a "wanted" thread in the market place ie.)
aravindwarrier is offline   Reply With Quote
Old 16th January 2008, 16:12   #2 (permalink)
Hey Guys, somebody give me some suggestions, I am running out of time ......
Old 16th January 2008, 19:00   #3 (permalink)
JayD's Avatar
Hey! get an FFE from automech! Great sound, and will cost u the same as your stock one! btw, what they mean by two pieces may be, one as the tail piece with the end can, and the other piece from the headers.
__________________
ATTENDANCE- The last 3 minutes of a class which makes the 2 hours of torture worthwhile!!
JayD is online now   Reply With Quote
Old 16th January 2008, 19:36   #4 (permalink)
gemithomas's Avatar
Have not had experience with the Palio but on my UNO i have needed to replace the bigger muffler (located closer to the rear end) as much as 6 times over these 7 years. But i think the smaller muffler (towards the centre of the underbody) has not had to be changed yet. Please confirm that you need to change the whole set in your case. They might just be taking you for a ride.
Maybe Palio users could give first hand experience.
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 16th January 2008, 21:49   #5 (permalink)
Originally Posted by JayD View Post
Hey! get an FFE from automech! Great sound, .
In Cochin? Where? can you give any contact?It has to be custom made or is it readymade, bolt-on thing?
The bigger, and squarish muffler located nearer to the tail pipe is sure rusted and needs to go. It had signs of rusti, the last time I was at home and that was before the monsoons.
The one nearer to the headers did not seem to have any issues back then. However, things can change during six months time right? I will ask my dad to check that first thing tomorrow morning.
One can never be so sure about these A.S.Ses nowadays.
Old 17th January 2008, 07:55   #6 (permalink)
JayD's Avatar
Yep. in cochin. I'll PM u the contact details. U can check if they offer automech for palio,(i think they do). Its readymade, u just need to bolt it on. For an OHC, it took around half an hour, thats all!
__________________
Old 17th January 2008, 09:37   #7 (permalink)
Thanks, JD.
I've already spoken to Balu, he said he'll check up and let me know the details, may be after an hour or so. Any idea where he gets his stuff from?
Old 18th January 2008, 06:43   #8 (permalink)
mithun's Avatar
It might be the whole unit.
Very high cost, you'll get it from outside for a few thousands less.
Try Bosch service near RF motors OR you can search yourselves using the Yellow pages.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
mithun is online now   Reply With Quote
Old 18th January 2008, 08:02   #9 (permalink)
gigy's Avatar
i just replaced palio1.2 3rd and 4th part of exhaust for 3.5k. lift her up in a local garage and have a look below. keep car running to locate the leaking areas. the mechanics can help you out in this. i found the last part which is the silencer rusted. replaced the 3rd part also since the place both join was also rusted and putting only last part will not give good sealing. also get the locks and new rubber bushings(4 of them).the 3rd unit has a muffler like triangle part. 4th unit has the proper muffler.
in most case it should be the last part only which needs replacement and will come for less than 2.5k
__________________
Suzuki Baleno
Old 18th January 2008, 09:13   #10 (permalink)
Had you taken any pictures? Is it possible to post any? Again the problem here is like I am out,and my dad dont have the mind to do all these.Lucky that the workshop guys did not have a full exhaust at that time,or he'd have had already replaced it by now.
Old 18th January 2008, 13:46   #11 (permalink)
gigy's Avatar
no pictures buddy. it was my cousin's car so just wanted to get it back on road as soon as possible. it had a dead battery and rusted & broken silencer.
__________________
Suzuki Baleno
Thread Tools
replacement for sx4 stock ice: single din man_1 Ask the Gurus 15 4th February 2008 21:33
Is an FFE worth on fiat 1.6 swathyd Modifications & Accessories 15 2nd July 2007 20:52
Need help for exhaust system(stock). Deepz Modifications & Accessories 23 18th June 2007 10:57
K&N Stock Replacement for Ford Ikon Flair mega5918 Technical Stuff 4 22nd January 2007 19:32
Brand new rusted fiat petra!! Dovin The Indian Car Scene!! 29 10th October 2004 02:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
