Old 29th August 2013, 23:19   #46
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: Switch off / Park in first gear or neutral?
Originally Posted by s_pphilip View Post
Is it normal for the car when parked in Gear to roll down the slope in jerks....
.....I always assumed in reverse the car should not roll forwards, in fact people advice that you should always leave the car in the opposite gear from the direction of the slope, it doubles up as a safety precaution and reverse gearing should not allow forward motion.
Yes, if the g forces are more than what the engine can hold, then the vehicle will roll down the slope, when the engine is switched off.
Old 30th August 2013, 00:19   #47
s_pphilip's Avatar
Thanked: 231 Times
Hmmn, Embera I believe weighs about 1.7 k kgs. So will that happen on 20 degree slopes as well and that too in reverse, ideally should not reverse gear stop the forward motion. Thanks for clarifying.
s_pphilip is offline   Reply With Quote
Old 30th August 2013, 04:46   #48
Wildy's Avatar
Thanked: 667 Times
Very helpful topic. I usually switch off the vehicle and then leave it in neutral with handbrake on. But after reading many advises here, I shall follow them. Thank You.
Wildy is online now   Reply With Quote
Old 30th August 2013, 09:46   #49
KiloAlpha's Avatar
Thanked: 1,597 Times
@s_pphilip had posted the same query on another thread, and I had responded to it there. Linky: http://www.team-bhp.com/forum/test-d...ml#post3222586 (First Impressions Sonata Embera)
KiloAlpha is offline   (2) Thanks Reply With Quote
Old 18th December 2015, 16:57   #50
McLaren Rulez's Avatar
Thanked: 591 Times
Just wondering, but what happens if you park in gear with the handbrake on and someone tows your car. The newer cars are hard to break into (to release the brake) and this might result in damage, no?
McLaren Rulez is offline   Reply With Quote
Engine shuts off in neutral gear 2cents Technical Stuff 24 25th September 2013 20:44
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Santro gear shifts suddenly into neutral nura Technical Stuff 18 11th August 2008 14:21
Gear slipping to neutral? - Wagon R johy Technical Stuff 32 25th March 2008 19:01
Re: Gear "jumping" to neutral??? johy Technical Stuff 9 9th November 2006 21:45
