Old 16th January 2008, 19:24   #1
Ajaybiz's Avatar
Thanked: 144 Times
Default i10 hand brake issue
My Brother(in Pune) recently picked up i10 Magna and we all are quite happy with its perfomance, but its handbreak is giving big time issue, even after lifting her to its full it dosent works properly and if you forget to release the handbreak vehicle moves with ease no issues like burning smell from break pads n all, what could be the issue? seen the same thing in some other post, just curious if any other fellows over here faced the same thing, need input to get it done at service station.
Ajaybiz is offline   Reply With Quote
Old 16th January 2008, 19:29   #2
simply_sunny001's Avatar
Thanked: 15 Times
moving just few mtrs wont fry the clutch plates so you are not getting burning smell.
you need to drive few kms to get that smell
though for the main issue of ineffective hand brake,please visit service centre or some other mechanic to get it tightened.
it should not be a big problem unless untill its something specific to i10
simply_sunny001 is offline   Reply With Quote
Old 16th January 2008, 19:39   #3
Thanked: 34 Times
Does your friend feel some kind of resistance initially when driving the car with hand brake on?
deepakhon is offline   Reply With Quote
Old 16th January 2008, 19:54   #4
rks
rks's Avatar
Please ask your brother to read the manual from cover to cover before driving the car. This is something that we all neglect, but is really essential if you want to treat your car properly. The manual will explain the purpose of the various warning lights in the dash apart from giving other invaluable tips about operatiing/maintaining the car.
In particular, it is a good habit to look at the dash warning lights as you switch on the ignition and start your car. Then you will see the handbrake light glowing and take action before doing any damage to the handbrake liner or to your clutch. The other warning lights in the dash are also important and it is essential that one understands their purpose and funcitioning before driving the car. For example, if handbrake is down and the handbrake light is still on when engine is running, that means brake fluid level could be low (in my old Santro, at least).
Old 16th January 2008, 19:54   #5
Ajaybiz's Avatar
Thanked: 144 Times
No resistance at all and he drove almost 10-12 KM before realizing that handbreak is not released after seeing the handbreak indicator on dash.
Old 16th January 2008, 19:55   #6
Stratos's Avatar
Thanked: 1,217 Times
I have noticed that sometimes the handbrake does not activate completely if it is lifted while the lock is pressed. Technically it should be lifted without pressing the lock and it makes small TRRRR noises around 5-6 times which are the locks... am I right techies??
I hope you are not doing the same thing!
Stratos is offline   Reply With Quote
Old 16th January 2008, 20:38   #7
Thanked: 146 Times
just now checked with a friend of mine who has a i10 and it seems that he has not faced this issue. the hand brakes are working fine for him! please do have it checked ASAP.
OT: he said he has got 18kmpl on his last long drive, this is even before the first service!!! Do you get this much?
HappyWheels is offline   Reply With Quote
Old 16th January 2008, 20:43   #8
Thanked: 146 Times
not necessarily.
The lever just work on basic mechanics; the nob / lock is just that , a lock.
Regardless of you pulling the lever up without pressing the nob/lock and getting the TRRRR sound or you pulling it up with the nob/lock pressed, the end result will/should be the same - namely - engaged brakes, period.
Old 16th January 2008, 20:52   #9
Stratos's Avatar
Originally Posted by HappyWheels View Post
not necessarily.
Well, i said..what i have noticed in a few cars...hope you will see/saw that.
Old 16th January 2008, 21:05   #10
Thanked: 149 Times
I do not own an i10; but I guess that it is a front wheel drive. Hand brakes lock up the rear wheels. Since the engine drives the front wheels, it is possible for the vehicle to move even if the rear wheels are not turning.
There are ways of knowing if the hand brake is engaged. Noticing the pull is one. Noticing the extra sound while the vehicle is moving is another. Looking at the dash indicator lights is most reliable. Putting your hands on the hand brake lever before moving off is always a good practise.
The guy in question appears to be either a newbie, or this is a case of sheer negligence.
BTW, my WagonR will move with just the clutch released and hand brake appleid. I have learnt to (a) check the dash board (2) recognise the distinct sound when vehicle moves with the hand brakes applied.
Old 16th January 2008, 21:08   #11
rks
rks's Avatar
A knowledgable service engineer told me that the handbrake should fully engage with six clicks in my Santro. If more/less clicks are required, then handbrake needs adjustment. I agree it is better to engage without pressing on the lock, so that you can hear the clicks.
Old 16th January 2008, 21:34   #12
Thanked: 146 Times
my limited exposure to cars never got me to notice this. will keep an eye out. cheers:
Old 16th January 2008, 22:09   #13
Thad E Ginathom's Avatar
Thanked: 8,377 Times
You should press the button, pull up, then release the button.
I learnt from a couple of good pro instructors in UK, as well as having practice with some very experienced drivers including my dad --- all them instructed me to push the button, saying that to do otherwise just wears the 'teeth' of the ratchet mechanism. But as Happywheels says, it will make no difference to the working of the brake.
This is plainly just a case of a fault on a new car: the service people should fix it. And quickly: an issue with the brakes is fairly serious.
Old 17th January 2008, 00:08   #14
TrueDreamer's Avatar
Thanked: 7 Times
I like to press the nob even while engaging the hand brake (so as to avoid click click sound) and disengage pressing the nob lift a bittle and get it down.
Just wanted to confirm if this will have no ill effects on the braking system of car when compared to standard click click type.
If it does harm the car, i will change my habit.
TrueDreamer is offline   Reply With Quote
Old 17th January 2008, 00:17   #15
No harm. Quite the opposite.
Even at age 18, though, I resented not hearing the satisfying ratchet noise after being firmly told that I must press the button.
Hand Brake - Do you use it everytime ? mithun Technical Stuff 111 24th June 2015 10:07
Blaring Music + Bad Driving = Does it go hand in hand!!! SamtheLeo Street Experiences 77 20th December 2014 20:41
Hand Brake Operation revharder Technical Stuff 25 14th February 2010 12:42
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
