Old 18th January 2008, 14:05   #16
breezydrive's Avatar
Thanked: 75 Times
Originally Posted by rapideffect View Post
The link provides much needed info!
breezydrive is offline   Reply With Quote
Old 3rd July 2009, 15:11   #17
Smile CRDi Vs Multijet
Hi Everyone,
All of us know in recent past that the Diesel powered hatches and sedans are a big success in Indian market. The most important factor (IMHO) for the success is the very successful engines either CRDi or MJDs. These diesel engines are giving very good mileage, good power and less maintenance compared to the older engines. Now almost all the auto manufacturers are either sticking to CRDi technology or the most celebrated MJD engine. Going by the trend the MJD is becoming more popular and successfull.
Now the question is with all the celebrations and fanfare, how does the MJD engine perform when compared to other CRDi engines with similar capacity?
Let us compare the 1.3L MJD with the main rivals 1.5 CRDi of Hyundai and 1.4 TDci of Ford. Please give your views on the following parameters
Parameter 1.3 MJD 1.5 CRdi 1.4 TDCi
1. Fuel Economy
2. Engine Noice/Vibration
3. Cost of Maintenance (including spares)
4. Frequency of Service/ Maintenance
5. Power (per 1000cc is a fair play)
6. Torque/acceleration
7. Lifespan of the engine
8. Technically Specific Superiority
The inputs from our auto gurus will definitely help others in deciding the proper diesel hatch/sedan during their purchase. So please please put in your valuable points.
@Mods: If neccessary Please move this post to a proper thread.
ForeRunner is offline   Reply With Quote
Old 3rd July 2009, 17:12   #18
architect's Avatar
Thanked: 597 Times
Isn't the Multijet also a CRDI engine as well? So is the Ford TDCi and the others. These are just different badging by manufacturers, with some differences, of course, but with a similar basic technology.
I think this thread can be called :"Fiat MJD vs Hyundai CRDi vs Ford TDCi vs GM TCDi vs Mahindra CRDe vs Tata DiCOR vs Mercedes CDI vs whatever"
architect is offline   Reply With Quote
Old 3rd July 2009, 17:31   #19
greenhorn's Avatar
Thanked: 1,519 Times
CRDi's are usually Bosch systems
The ford's common rail is Siemens made
Dicors are Delphi
Old 3rd July 2009, 17:35   #20
clevermax's Avatar
Thanked: 445 Times
I don't know the technical details, but the Hyundai CRDis produce that 'boat engine' sound after running a lot. Listen to the engine sound of Accent Crdis which has some figure around 60K in the odo, if you are wondering what I'm talking about.
clevermax is offline   Reply With Quote
Old 3rd July 2009, 17:44   #21
pb10gagan's Avatar
@clevermax
Accent CRDi is a three cylinder engine, where as in verna and getz its a four cylinder mill.
Three cylinder mill being inherently noisy.
I guess verna or getz dont get so noisy even after 1000k kilometers.
pb10gagan is offline   Reply With Quote
Old 4th July 2009, 03:55   #22
Ketan's Avatar
Thanked: 180 Times
I know its a bit OT, but just wanted to know you guys opinion on naturally aspirated disel engine like what I have in my Palio 1.9D!!!
Ketan is offline   Reply With Quote
Old 4th July 2009, 07:43   #23
Thanked: 448 Times
Originally Posted by breezydrive View Post
1.3 MJD is a hot topic these days ( ever since DDis swift arrived & now Palio + new Indica are going to have the same heart), as a potential buyer, some of the questions on this engine are :
  • How many km this engine should last as compared to its petrol counterparts? eg. suzuki's 1.3 ltr engine ( used in esteem)
  • After how many km overhaul would become necessary?
Several times, i have noticed thick black smoke bellowing from the tail-pipe in so called modern diesel cars ( Swifts, fiestas, vernas & some bigger ones like Endaevour, Innova etc.) when subjected to sudden acceleration.
Does this happens because diesel emissions are more visible than petrol emissions? I mean the the petrol cars might be emitting the same amout of gases but mostly unvisible.
Guys, pl. share your views!
Well first of all,diesel should never be compared to a gas motor,its just above them and in league of its own,splly the mordern ones.
Having worked with engines for quite some time ,what i can tell you is life will depend upon how you use it or abuse it.general family man,60-90kmph ride all his life,with good maintainence schedule and mild dusty conditions,almost all crdi(also mjd) engines will do 1lc+,sometimes might go even 1.5l but this can sharply fall with rise of revs,and aggresive driving.
3 barrel crdi was completely different design to the 4 barrel now being used,it sure was just a lil bit noisy,but majority of issues came with tougher balancing aspect of 3 cylinder design.
Ok now with the black smoke seen outa diesel,
Guess what its much cleaner than petrol motors,because its black colour comes from soot(unburnt carbon particles),emmissions in ppm, diesel is almost 1/3 of what petrol engines throw out.Carbonmonoxide and nitric di-oxide,sulpher dioxide to go along with carbon di oxide(green house gas).
diesel has lrgly sulphur di oxide(because of sulphur content of diesel) and soot,plus others in reduced quantity.however govt has standards in place for sulpher contents of diesel,almost all petrol pumps over shoot it by atleast twice! dunno whts the reason for standards not being enforced,also there by degrading diesel quality!
diesel engines has a diff funda of increasing rpm,where petrol motor,allows more charge(mix of petrol/air) by oppning the throttle valve,diesel entirely relies upon induction of air,making an ultra rich mixture(more diesel),thus increasing revs with more MEP.
although mordern diesel has come up with butterflies on intake manifold,but funda for accelerating is still same,inject more diesel,this extra rich charge produces more power then lean mixture,thus piston speed increases and draws in more air.
Now the thing to note is,when you step on the pedal ,you are injecting much more diesel than the air available to burn it,hence incomplete combustion and left over fuel gets converted into soot!
although this is unwanted in world,but it still is not as bad as green house gasses and acid rain making compounds from petrol motors
dustom_99 is offline   Reply With Quote
Old 4th July 2009, 07:45   #24
headers's Avatar
Thanked: 464 Times
@ketan: You've got a rocking engine mate! Its one of the best from the old school!
Old 4th July 2009, 08:02   #25
To make engine life better and smoother, which Diesel is recommended for Diesel engines out of "Normal" and "Extra Mile" ?
tarunmadhok is offline   Reply With Quote
Old 4th July 2009, 08:41   #26
Thanked: 448 Times
[quote=ForeRunner;1369434]Hi Everyone,
Let us compare the 1.3L MJD with the main rivals 1.5 CRDi of Hyundai and 1.4 TDci of Ford. Please give your views on the following parameters,
i guess power/1000cc wont be relevant if the overall vehicle weight is more,so BHP/tonne would give better idea.assuming cars to be swift/getz/fiesta(base modles)
1. Fuel Economy 15cty/19hw 14cty/18hw 14cty/20hw
2. Engine Noise(idle) 68~74DB 70~76DB 64~67DB
3. Engine noise(2200rpm) 71~78DB 69DB 70db
3. Cost of Maintenance Depends on manufacturer/vendors
4. Frequency of Service almost same for all 3
5. Power (/1000cc) 57.6bhp/1000cc 73.33 48.5
6. Torque/0-100kmph 190/15sec 240/11 163/15sec
7. Lifespan ofengine(expected) 1l km 1l 1.3l
8. TechnicallySuperiority 5 injections/stroke 3 3
8valves 16v 8v
9. Highest state of tune(reliablyknown) 92bhp 157bhp 71bhp
10.power to weight ratio 70 100bhp/tn 59
Old 4th July 2009, 14:34   #27
Bubby's Avatar
Thanked: 152 Times
What say guys? Has anybody got any concrete say on this.
I think for better engine life we should use normal.
For smoother it should be premium.
Bubby is offline   Reply With Quote
Old 5th July 2009, 02:40   #28
[quote=dustom_99;1370230]
8valves 16v 8v
Thanks Dustom for your valuable input.
Few Doubts from my side:
Now shall I conclude that economy and NVH are more or less same in 1.3
MJD and 1.5 CRDI?
Does the number of valves determine smoothness(NVH) and efficiency of the engine?
Thanks,
Old 12th February 2015, 16:46   #29
petroguzzler's Avatar
Thanked: 187 Times
Default Re: Life of MJD engine
The mechanic to whom i give my vista quadrajet for servicing told me that the fiat multijet (75bhp) is known to run for about 4lakh kms without much work.
petroguzzler is offline   Reply With Quote
Old 12th February 2015, 17:28   #30
Thanked: 69 Times
I recently hired a taxi at Trivandrum airport and it was a Vista MJD. I was chatting with the driver and he said the engine has run 1.7 lakh kilometres and there are no issues with pickup, excessive vibration, or noise, except that it sips about 100 ml more oil. I forgot to ask him about suspension overhauls.
Pradeep
pradkumar is offline   Reply With Quote
Life's like that: Real life anecdotes. Sam Kapasi Shifting gears 534 15th February 2018 19:23
My Italian bombshell Formosa-FIAT Grande Punto 1.3 MJD E-Pack finally enters my life! sumobom4 Test-Drives & Initial Ownership Reports 58 27th March 2011 00:52
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
Indica Vista MJD vs Palio MJD vs Swift DDiS greenhorn The Indian Car Scene 452 24th April 2010 18:11
Punto MJD Emotion Pack or Linea MJD Dynamic Pack atilla Hatchbacks 1 4th August 2009 14:16
