| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | A friend of mine has very kindly agreed to bring some performance stuff from the US. So, I am planning to get an ignition coil, Spark plus and Plug wires for my MPFi Esteem(has Distributor) details of which are below: 1) MSD Ignition Coil: The Part No is MSD-8207. Link is: [COLOR=#800080]http://store.summitracing.com/partdetail.asp?part=MSD%2D8207&view=1&N=700+429492 5143[/COLOR] 2) Accel Spark Plug Wires: The Part No is ACC-4048. Link is [COLOR=#800080]http://store.summitracing.com/partdetail.asp?part=ACC%2D4048&view=1&N=700+429492 5143+4294756594[/COLOR] 3) Spark Plugs: Not sure which one. While I am sure that the Ignition Coil will match the Esteem, I am not too sure about the Plug Wires and Spark Plugs. My Questions: a) What is the recommended diameter for Esteem? I am not sure if I should buy 8MM, 8.5 MM etc. Also, will I need to change the plug boots to the stock ones as the ones in the picture seem short? b) I want to buy Iridium or Platinum wires but don't know how to choose spark plugs? I don't know what the specs should be for an Esteem. I am
__________________ Cheers Santhosh |
| | #2 (permalink) |
| BHPian | Oops, somehow my thread got posted before I completed. Well, here is the remaining part b) I want to buy Iridium or Platinum wires but don't know how to choose spark plugs? I don't know what the specs should be for an Esteem. I am not sure of how many mm thread, resistor/non-resistor, heat range etc. Please help with my queries.
| | #4 (permalink) | |
| BHPian | Quote:
Most of the Plug wires I found on summitracing are 8MM, very rarely 8.8 MM. After reading the description, I found that they suit cars much larger than the Esteem in Cc. So I would like to understand why 8.5MM is recommended over 8MM. If 8MM is good for street use, I'll buy a set of 8MM which has straight plug boots rather than the right-angled ones. Also, how do I choose the right Iridium/Platinum Spark plug(s) for my Esteem?
__________________ Cheers Santhosh | |
| | #5 (permalink) | |
| BANNED | Quote:
The reason I said 8.5mm was the MSD wires are more superior to the Accel and is more suited if you plan to go in for the 6AL Ignition unit. 8.5mm Super Conductor Spark Plug Wire. You have to specify that it is for a MPFI car and you will get the straight plug boots. Choose a plug with heat range 6 which is perfect for a mildly modded to stock car. Normal heat range is 5. Viper | |
| | #6 (permalink) |
| Team-BHP Support ![]() | I hope your friend realises that performance plugs / wires offer a next-to-zero benefit on a mariginally modified car. Have a look at this article (ARTICLE: How to Modify / Tune your car) for further information.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #7 (permalink) |
| BHPian | No GTO, he is bringing these for my Esteem. Nice summary there GTO. I read it again today and found it very informative. Actually, I am now thinking I'll get only the Ignition coil and the spark plugs. What do you guys think about the Bosch Platinum Ir Fusion series? A friend of mine just got these for his modded 1.6 Swift and is pretty impressed. So, I might get the same too. Has anyone on the forum used these spark plugs yet?
| Thread Tools | |
Similar Threads | ||||
| Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug | finetuning | Modifications & Accessories | 17 | 7th October 2008 13:24 |
| Replacement of OEM Spark plug Wires | Kaizer Sozay | Technical Stuff | 2 | 16th October 2007 23:40 |
| Spark Plugs and Wires | bmdesai1987 | Modifications & Accessories | 0 | 6th October 2007 11:59 |
| Anybody Using aftermarket ignition coil & plug wires? | finetuning | Modifications & Accessories | 0 | 27th March 2006 22:41 |
| MSD Spark Plug Wires & Ignition coil | Kaizer Sozay | Modifications & Accessories | 11 | 16th December 2005 09:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
