Old 23rd January 2008, 13:49   #16
gd1418's Avatar
Thanked: 656 Times
This is 'rooobbish' as Geoff Boycott would have said. I've yet to see or hear of a device that when externally installed can reduce carbon deposits.
If I remember correctly, this product was discussed elsewhere on the forum.
Originally Posted by tmanish76 View Post
They claim that it reduces carbon deposits and in the long run makes the engine run smoother and more fuel efficient. From the looks of it they have attached the device using plastic tags to the fuel lines coming from the engine block.
Old 23rd January 2008, 16:23   #17
clipto333's Avatar
i paid 65k for my accent crdi. the engine conked at 80k kms.
if you tell them that certain parts are not needed, they wont give warranty on the engine. ii got a 6 months unlimited milage warranty.
cheers
clip
clipto333 is offline   Reply With Quote
Old 24th January 2008, 08:42   #18
cheers
clip
What kind of warranty do they give on the engine after replacement? Mine is 5 years old and has done close to 90000 kms. Did your car start giving any sudden problems which prompted the work?
I understand that such a used engine as mine will give problems. But sudden seizures after a service due to oil not flowing has to be attributed to some faulty procedure in their service for which I am now being forced to pay.
Had checked on the hyundai website and have sent two mails to cr@hmil.net with no response. Is there any other place I can escalate?
tmanish76 is offline   Reply With Quote
Turbo Failure in '07 X-Trail! Nissan Customer service? EDIT: Now resolved. Scooby STi Technical Stuff 14 24th February 2010 17:21
Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge! sizoo Technical Stuff 2 7th August 2009 11:29
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
hyundai accent crdi engine failure. clipto333 Modifications & Accessories 92 13th November 2007 11:12
