Old 11th January 2005, 15:39   #1
z klasse's Avatar
Smile how long can u keep neons on
hi. was just wondering. how long do you think you can keep neons on without the ignition being turned on? if you make it direct to the battery how long do you think you can leave the neons on without draining the battery.. i think 3 hours is a good enough time for neons to be on?
Does anyone have any info or know anything about this?/
Z Klasse
z klasse is offline   Reply With Quote
Old 11th January 2005, 19:25   #2
revtech's Avatar
Thanked: 35 Times
hey interesting topic.....
wanna know bout it to...
revtech is offline   Reply With Quote
Old 11th January 2005, 21:11   #3
jesal's Avatar
Z Klasse
depends wht u use on the side as well
jesal is offline   Reply With Quote
Old 11th January 2005, 22:01   #4
Cool neon's
Z Klasse
hey all,
Klasse i leave my neon's on when ever we drive from juhu to bandra and back at night for approx 2 hr's , it hasent given me a problem yet.
Best is to buy it on remote control for rs4600 at milan-sub from wasan or suraj motors. both are good and cheap.mine is connected directly to the battery so no hassel of starting the car every now and then. even if u are 20 feet away u can start the light's via remote , it's cool.
WILDTHING is offline   Reply With Quote
Old 11th January 2005, 22:04   #5
Stratos's Avatar
Thanked: 1,217 Times
Topic moved to Technical Stuff due to its technical nature
Stratos is offline   Reply With Quote
Old 11th January 2005, 22:07   #6
normally_crazy's Avatar
Thanked: 394 Times
hey wildthing
as ur neons are directly connected to the battery - i guess u can keep them on , till the battery runs out !!
normally_crazy is offline   Reply With Quote
Old 11th January 2005, 23:22   #7
z klasse's Avatar
What i meant was how much time can u leave it on without the car being turned on so that the battery doesnt run out.
Old 11th January 2005, 23:33   #8
jesal's Avatar
Originally Posted by normally_crazy
hey wildthing
we do that to bully him neways lol
Old 12th January 2005, 15:53   #9
DRC
DRC's Avatar
Thanked: 48 Times
That depends on how much of current your neons draw from the battery,
time shold be less than capacity of the battery in Ah/(current drawn), This is time to completely drain the bat. You need to have around 60% of bat to start your engine again
DRC is offline   Reply With Quote
Old 12th January 2005, 20:17   #10
Rehaan's Avatar
Thanked: 25,043 Times
Precisely. Well said.
A lot of people forget about leaving enough power to crank up the car again (which is the function that puts the most electrical load on the battery for those few seconds)
R
Old 19th January 2005, 14:37   #11
xstream_nos's Avatar
Thanked: 7 Times
hey...
well u can keep the neons on as long as u want.... may b even till ur battery runs dead.. well technically it depends on ur neons power consumption....based on tht u can calculate the amount f time u can keep em on without the engine running....
navin...
xstream_nos is offline   Reply With Quote
To keep or not to keep...am confused lohithrao Sedans 13 9th April 2008 10:48
alternate way to fix neons on zen mclaren1885 Modifications & Accessories 11 17th August 2007 12:39
mounting a audio system,neons etc in any car TEAM R.A.R Modifications & Accessories 5 13th October 2005 09:46
RPM / NEONS for sale .rs. Shifting gears 5 22nd September 2005 15:55
Remote control Neons on my car WILDTHING Modifications & Accessories 23 10th January 2005 21:27
