Old 11th December 2014, 20:57   #16
sdp1975's Avatar
Thanked: 920 Times
Default Re: Sound from front wheels while turning the steering at standstill
Don't know about Hyundai's - but Fiat vehicles are known for making a grinding sound when their front wheels are turned and the car is stationary - this was due to defective strut bearings , or elastic pads , as Fiat call them. The bearings become loose - I had this problem and it went away after replacing them.
Does the sound come when the car is stationary ?
sdp1975 is online now   (1) Thanks Reply With Quote
Old 11th December 2014, 21:24   #17
Mr.ASG's Avatar
Thanked: 16 Times
Originally Posted by joybhowmik View Post
It could be a problem with the PS pump - since you say the sound comes from lock to lock, and the steering feels tight/hard.
Also, at standstill, you may have the same symptoms.
Thank you for the response, It might be a problem with Power steering Pump. I'm curious to know one more thing, Is their any lubrication required for steering linkages?
Yes when car is Stationary, there is sound when turning the wheels. I also have doubts about bearings too.
Mr.ASG is offline   Reply With Quote
Old 12th December 2014, 00:55   #18
joybhowmik's Avatar
Thanked: 1,905 Times
Not ordinarily.
If your shocker / strut assembly bearings have failed , the steering will turn very hard - at all speeds including stationary.
Noise from the bearing will appear at all positions of the wheel.
Usually the kind of noise you describe - as happening at steering lock is more indicative of pump failure. I would advise to get it checked.
Front wheel .steering column ticking sound.. Need urgent help!! DRC Technical Stuff 34 27th April 2015 11:31
AC tripping when the car is at a standstill revved_up Technical Stuff 57 27th November 2014 09:19
A sound while turning the steering wheel. InternetUser Technical Stuff 8 19th December 2012 09:21
Screeching sound in Santro while turning Lalvaz Technical Stuff 8 26th June 2008 13:35
Screeching sound while steering Vinay DL Technical Stuff 4 28th November 2007 10:32
