Thread Tools
Old 22nd January 2008, 12:04   #1 (permalink)
Exclamation Putting a Free Flow Exhaust in Esteem 2001
Hi Friends.... ( rather guru's ),
I have an Esteem 2001 model and wanted to put a FFE in it , i wanted to ask
- Mileage after FFE ( my car gives 13~15~17 city / highways in bangalore )
- Cost of FFE
- any recommendations from whom to get it done
passion4cars is offline   Reply With Quote
Old 22nd January 2008, 12:12   #2 (permalink)
planet_rocker's Avatar
Mileage - depends - most likely to go down because you will be revving more to enjoy the sporty exhaust note - may slightly increase if you drive sedately.
Cost - depends on whether you are opting for Mild Steel or Stainless Steel / Fabricator. usually ranges between 6K-15K
Recommendations - Viper / Automech / Raj Hingorani / Psycho / Electra / your friendly neighbourhood tuner.
__________________
Planet, Sonja, ETC - "Elements of Life"
RWD Rocks ... :)
planet_rocker is online now   Reply With Quote
Old 22nd January 2008, 12:23   #3 (permalink)
VJ_MAVRICK's Avatar
Since you are in Bangalore you can get it done from Raj Hingorani and also FRK Racing Bangalore and i suppose a person called Fazal does it if i aint wrong.
FYI FOLLOW THIS THREAD
http://www.team-bhp.com/forum/modifi...bangalore.html (need info on tuners in bangalore)
__________________
Every SAINT has a PAST and Every SINNER has a FUTURE
VJ_MAVRICK is online now   Reply With Quote
Old 22nd January 2008, 14:38   #4 (permalink)
n_aditya's Avatar
Mileage depends on the way you drive. Usually the FE goes down as you will be tempted to floor the pedal. Believe me the sound is very addictive. Even after almost 2 years i am still enjoying the sound of my FFE.
But if you drive sedately the FE will not be hampered, but might actually improve by a kmpl or two.
Cost varies on several factors like - design (4x1 ; 4x2x1), finish (SS or MS-GI alloy ; ceramic coating), tuner, etc.
Do let us know your driving stlye so we can help.
If you mostly drive in the city and rarely on highways i recommend a street spec (4x2x1 design). This design ensures high amount of low end torque which is needed the most in city traffic. Driving with street spec headers will ensure longer life of your clutch as you wont be compromising on low end torque and hence riding the clutch will be totally uncalled for. Expect wheelspins in 1st and 2nd gears as acceleration is very high. The power peaks in lower rpm's and leans out as the rpm's climb.
On the other hand if u drive frequently on the highways, consider investing in a race spec header - 4x1 design. Here the low end torque is less, riding the clutch is imminent to move the car from standstill/very low speeds. But the mid range and top end performance of the car increases to a large extent. With this you can cruise at high speeds with almost no effort. But do note that esteems have shabby brakes and suspensions which are vital to control the car safely.
You can also retain the center muffler for a muted sound or get rid of it and have a straight pipe from the headers till the end can. A straight pipe will make your car sound very loud and in blore this is not advisable.
An SS muffler will give a deep bassy note to the car while other mufflers made from MS will give a metallic rally note to the car. Decide on what kind of muffler you want. Note that there will be some flutter present in case of 4x1 headers no matter which muffler you use.
With regard to coating, SS headers look nice but are prone to corrosion. Ceramic coating provides some heat insulation though.
Consider getting a K&N filter or any other aftermarket high flow air filter too.
Approx cost of an OE K&N for esteem is around 4.5k to 5k while the full FFE can cost upwards of 10k.
Reputed tuners in blore for FFE and not limited to are - Psycho, raj hingorani, FRK racing etc and Electra in Chennai.
All the best.
__________________
RIP Tootie !!! Missing you terribly.
Old 29th January 2008, 17:25   #5 (permalink)
Thank you guru's
the whole trouble is that price of petrol is +50 / lt in bglr......I dont wana screw up my mileage as I am getting about 13~17 km/ lt range , i just want a good sounding car . I have already fitted in a K&N filter ( performance ) anyways thanks once again I will make up my mind ....... but 1 thing for sure I want it.......
Old 29th January 2008, 22:36   #6 (permalink)
motorheadinc's Avatar
@ n_aditya
Buddy can you enlighten poorer souls like me thirsty for knowledge by posting some pics or a schematic diagram sequence showing how an FFE really works and what are the different types per se'.
I am sure others would be equally benefitted.
__________________
The Identity awishcar.co.in
If there's not a car to satiate me, I will make one.......
motorheadinc is online now   Reply With Quote
Thread Tools
What's a free flow exhaust ? adityapd A Collection of the best threads 70 4th August 2008 18:00
free flow exhaust jobug Modifications & Accessories 3 28th September 2007 15:48
Help me for Free Flow Exhaust System malvechaitanya Modifications & Accessories 10 24th February 2007 15:58
Free flow exhaust!!! shalini_g Modifications & Accessories 1 27th June 2006 11:23
free flow exhaust sanket12 Modifications & Accessories 4 29th June 2004 20:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
