Old 11th July 2011, 10:50   #151
bluevolt's Avatar
Thanked: 2,351 Times
Default re: Long-term Parking: Do's and Don'ts
Originally Posted by libranof1987 View Post
You've got the car cover on, right? That'll keep dust away from the engine bay.
Yes I have got the car cover on. But still when it rains all dust passes on to the car body in form of large patches. That is why I have asked to clean the car every Sunday as monsoon season is at peak in north.
bluevolt is offline   Reply With Quote
Old 9th August 2011, 14:46   #152
Visaster's Avatar
Thanked: 199 Times
This is all new running cars we are talking about, right.
Here I am posting to know what all precaution you need to take on a old, close to never used car.
My santro is going to be grounded at my parents house forever, i might use it whenever i go there (may be once in 3-4 months) few kms.
So what all precautions should i be taking on regular basis to keep the car running every time i need it and maintaining it in present condition for ever.
Hold on to it forever
Visaster is offline   Reply With Quote
Old 15th August 2011, 02:25   #153
libranof1987's Avatar
Thanked: 4,218 Times
1) Put a body cover on.
2) Have someone at least start it every 2-3 days.
3) If 2) is not possible, disconnect the battery each time you leave, connect each time you go there and start the car.
4) Use the car for some distance so the engine and other parts remain in working condition.
5) Keep tyres inflated beyond the prescribed pressure.
libranof1987 is offline   Reply With Quote
Old 15th August 2011, 06:08   #154
Gansan's Avatar
Thanked: 914 Times
#2 is not really necessary if the car is driven at least once a week. Ever since the Chennai Metro work started, my car is more or less in "long term parking " state only! Moreover some re-modelling work + multi-level car park construction is going on at our office, leading to scarcity of parking space. My car goes out only during weekends for 30 - 60 KM, with absolutely no ill effects.
I also notice an old Santro Zip drive at our apartment complex quietly gathering dust! It seems to go out just a couple of times a month, seemingly without any issues.
Old 15th August 2011, 09:56   #155
Well, he says, the car will be drive once in 3-4 months by him.
Old 15th August 2011, 11:17   #156
Gansan's Avatar
Thanked: 914 Times
In that case, starting every alternate day will not help. The battery will go dead slowly, unless there is some minimal running (~40 KM) every week.
Old 15th August 2011, 11:57   #157
bblost's Avatar
Thanked: 6,980 Times
If its only switch on and switch off, then you are using the stored power without recharging the battery. That would drain it faster than it otherwise would.
I have once kept the battery disconnected for over a month. Started without any fuss when I needed it.
Old 15th August 2011, 12:40   #158
ameet_pv's Avatar
Use a battery trickle charger to keep the battery Charged. The best way to keep the fuel injector & the suspension components in good shape is to use the car, that will also keep the rodents & bugs away
ameet_pv is offline   Reply With Quote
Old 23rd August 2011, 22:47   #159
smrsraja's Avatar
Default How frequently should one use his car?
Hello friends,
Request your suggestion.
I have a Indica diesel and for the last 9 months I have been using it only in the weekends. sometimes if we dont go out in the weekends also, it lies idle for straight 14-15 days. I bought a scooter 9 months back and from then onwards i find it easier to use and park the scooter than the car while commuting to office. So stopped using the car during office days.
My concern is, I have heard, diesel cars should be used regularly. But is the frequency i am using is too bad? These days the car gives starting trouble and i tried recharging the battery in the shop, but its not helping. I bought this battery 2 years back. Not sure if the battery life is gone or is a problem with the car dynamo or its because of less usage.
I am seeing people in my neighborhood parking their Santros for weeks and using only occasionally. Are petrol cars ideal for this kind of use?
smrsraja is offline   Reply With Quote
Old 24th August 2011, 09:29   #160
Gansan's Avatar
Thanked: 914 Times
^^ I use my car only during weekends for ~50 KM. If I have no outing planned, I will still take the car on Sunday mornings for a spin on the highway for 40 KM, come back, park and cover it. Highway drive is ideal because I can maintain a steady 70-80 KMPH speed. This for a petrol car!
It is all the more important for a diesel. Battery charge will go down faster in a diesel due to the higher cranking power needed during start-ups.
Old 24th August 2011, 09:36   #161
sumeethaldankar's Avatar
Thanked: 1,158 Times
Originally Posted by smrsraja View Post
Hello friends,
What make the battery is it.? OE battery's ususally last 2-3 years depending on make.Get the battery checked out along with the alternator charging.
Putting a cover in the rainy season is not a good idea unless the cover is thick and absolutely water proof.The water will seep inside the cover onto the body and will not dry up.
A open but covered parking is the way to go.That way the car won't get wet and even if it does it will dry up soon as the car is not covered.
sumeethaldankar is offline   Reply With Quote
Old 24th August 2011, 10:06   #162
ssh1979's Avatar
Thanked: 106 Times
Default Re: How frequently should one use his car?
Hello friends,
Hi, it shouldn't be difficult to start the car once in two days atleast, if you can manage this. Leave it running for 2-5 mins ("go green" guys don't jump on me now ).
I like @Gansan's method; even if you are not driving it regularly, take it out once a week for a spin. If you can't reach the highways, do some half hour of city driving atleast.
ssh1979 is offline   Reply With Quote
Old 24th August 2011, 13:38   #163
dhanushs's Avatar
Thanked: 4,506 Times
.. These days the car gives starting trouble ..
Yes, infact older diesels require much more power to crank, and that is why they were reved hard before shutting off the engine.
In your case, as you use the car only occasionally and for short trips, the battery doesnt get charged enough. IMO, the only solution is to recharge the battery to its full capacity once in two weeks from a neighbor battery walla.
Old 24th August 2011, 15:13   #164
Idling the car for 2-5 mins would be counter-productive rather than helpful. I don't think idling for 5mins would help the battery recharge or even regain the charge lost in cranking up the engine.
Old 24th August 2011, 16:12   #165
ssh1979's Avatar
Thanked: 106 Times
OK. Then what're the other options for @smsraja's situation?
And also how is the idling counter-productive to the vehicle? I can accept that it is bad on the environment and our pockets. Otherwise?
Long term car parking at RGIA Hyderabad TheDoors Shifting gears 26 9th January 2017 10:48
Parking space in independent house-Don't repeat my mistake mooza Street Experiences 45 17th February 2012 10:13
Need Help: Car PC and ICE (long term project) Devil on Wheels In-Car Entertainment 25 10th June 2010 19:01
Short Term vs Long Term Ownership, New Car vs Used Car Ownership architect The Indian Car Scene 10 9th May 2008 11:39
