| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| BHPian Join Date: Sep 2007 Location: Chennai
| Folks. Here is my 2 cents. I had Camry Automatic, which has P-N-D-1-2 sequence on the shift. The 1 and 2 are same as S and W what we are talking about I gues. Its just down-gear Once and Down-gear Twice when you need to - accelerate / climb uphill with load faster / go down-hill with better control. (The same as you down-shift in Manual Transmission cars). As far as braking from high speeds, my experience is below: I had driven Camry-stick shift for 4 years in Saudi Arabia, where speeds like 180 kmph on higways is normal. (no cops could ever watch that vast desert highways those days...) While crusing on such higway at 180-190 kmph, suddenly from nowhere group of Camels would pop up on the highway and Man... I would have to really screeeeech brake. My sequence (though within seconds) would be - Take of foot from accl pedal / press the Brake slightly / press clutch to downshift and shift gear from 5 to 3 directly / release clutch / brake real hard without pressing the clutch. You get the best possible braking distance. Once you are in control, under 60 kmph, press clutch and take gear to the right mode. Later, I switched to Camry Automatic and really in the first few instances, I was scared about the brake response. It sure did not give me the feeling of safety as the MT. Then I learnt to get the best out of the car for braking as follows - Take foot from acclr / just touch the brake pedal for a second / watch the speed to come under 100 kmph and then press the brake pedal progressively hard. Never stomp on the pedal. Start with gentle press and press harder as the speed comes down.That progressive pressure within few seconds would bring the car to stop in minimum possible distance and still not stall the engine.
__________________ RajaTaurus... Friends come, Friends go, those tolerate stay... Last edited by RajaTaurus : 5th February 2008 at 15:52. |
| Thread Tools | |
Similar Threads | ||||
| Hard clutch | shazikon | Technical Stuff | 7 | 18th January 2008 11:13 |
| Hard Clutch on the Baleno | bruce | Technical Stuff | 12 | 23rd August 2006 13:54 |
| Hard surface | Surprise | Technical Stuff | 3 | 18th August 2006 21:25 |
| Palio and its hard clutch | prkothan | Technical Stuff | 0 | 13th December 2005 11:04 |
| Vibrations under hard braking | RJK | Technical Stuff | 15 | 21st July 2005 13:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
