| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Started to notice a weird noise, while changing the gear expect between first and second gear. I do activate the clutch only during gear change and i don't have a habbit of driving with half clutch. As soon as I press the clutch, their is noise, like some couplers has been loostned. However, with the gear shift I am not seeing any change. It is normal. Any hints on what may be the cause will help. I am taking my car for 20K service on Saturday at Mandovi Motors Vijayanager. regards, -manju |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| is it a squeaky clutch pedal or dry cable? or a squeaky footwear?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #5 (permalink) |
| Surely it is not a squeaky sound from cable or pedal or the foot wear. It is like having a free running metalic ring around aluminum pipe sort of the thing. I have VXI with ABS, 14 months old, I think not bad for a petrol ![]() regards, -manju |
| | #7 (permalink) | |
| Quote:
regards, -manju | |
| | #9 (permalink) |
| A lubrication job is on the cards i guess, if the pedal is not hard. Darn what did i say??? I meant if your clutch pedal is not hard to actuate, issue should be resolved with simple lubrication of cable and other moving parts. Also there is spring on the pedal, check that also.
| | #11 (permalink) | |
| Newbie Join Date: Dec 2007 Location: PATNA
| Hi,the problem u have mentioned could be because of a worn out clutch release bearing, because the release bearing only moves when the clutch pedal is depressed. Quote:
| Thread Tools | |
Similar Threads | ||||
| 1.2 nv gear humming noise from ac vents | kapilsharma80 | Technical Stuff | 0 | 30th May 2008 11:46 |
| Gear change problem !!!! | funkydevil | Technical Stuff | 3 | 2nd April 2008 19:34 |
| Grinding noise in gear-change! | ramzsys | Technical Stuff | 3 | 1st October 2007 22:37 |
| when do we change gear | rranjith_kum | Technical Stuff | 1 | 17th October 2006 07:25 |
| 5th-gear noise?! | ghostrider4385 | Technical Stuff | 25 | 6th February 2006 23:07 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
