| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| BHPian | Yup, agree to what iraghava says. Surprised at that. 1 inch is quite some difference. Did you feel it when you sat inside the car? Lets hope its something minor. You need to take it to the dealer definitely.
__________________ Everyone is born right-handed, only the gifted overcome it. This is my car and I have my wife's permission to say so. |
| | #17 (permalink) |
| BHPian Join Date: May 2006 Location: bombay
| buddy you have a damn honda civic not a maruti anything , forget what everyone has told you just take it ASAP to the honda dealer you bought it from and let them deal with it. let us know how that works out. give them hell man |
| | #18 (permalink) |
| Distinguished - BHPian ![]() | I am surprised how so many people have related this to an allignment issue. The only allignment issue that can cause this is a very high negetive camber, which I am sure the member must have noticed. This is to do with ride height. Yes things like tyre pressure (already ruled out ), a busted shock absorber are things that should be looked into. Dont waste your time on allignment related issues. Hope the problem gets sorted soon. All the best.
__________________ He's Back |
| | #19 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Also, I'm sorry but my advice in my last post was wrong & I didn't read your post properly which led me to assume that you car tracking to the right rather than a physical slant.
__________________ There is a very fine line between "Hobby" and "Mental Illness". | |
| | #20 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Check your suspension and shockies, dont go by feel, take it to a dealer and show them the diff in height. It can be as simple as a missing rubber spacer or likes, be nice and explain and demo the problem clearly. Keep us posted ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #21 (permalink) |
| Distinguished - BHPian ![]() | This does not look like an alignment issue at all. If it was you would note the abnormality seeing the wheel, but going the fact that you are knowledgeable enough to check the tyre pressures first, you would have noted a slanted wheel. (on a different note: I think you already checked the loading on the car, if there are heavy objects sitting on one side etc) This could be anything from broken spring to busted shocks, but definitely in the suspension. Get it checked ASAP at the workshop. The car is too new for you to troubleshoot this yourself. Let us know soon.
__________________ ________________________ Every Ferrari is always a Fiat Last edited by 1100D : 5th February 2008 at 19:27. |
| | #23 (permalink) |
| BHPian Join Date: Nov 2007 Location: Chennai
| I just came back from the dealer's service station, and this issue is surprisingly expected. It seems its a design ![]() Along with Service advisor, I checked 3 Civic (2 brand new, and one 2007 model) and all had this difference in height. It is about 2cm. Right hand side is lower that left hand side by 2cm. One possibility is that you have silencer on the right hand side, which is causing the spring to go down. We all know civic got a soft suspension. All Civic owner, please check this. I am planning to write to Honda about this expected issue. |
| | #24 (permalink) |
| BHPian | Thats news !! I certainly am suprised by that. Anyways tell me how did you find out this issue in the first place. When you were sitting inside the car or when you looked at the car from an angle? Your observation powers are indeed too good coz none on this board, including yours truly, have spotted this.
| | #25 (permalink) |
| I noticed this while I was admiring the jet like tail lamps . Did you check this with your Civic. Try measuring the high from the ground to lower portion of rear wheel arch. Need to be very accurate it measurement as difference is only about 2cm. |
| | #26 (permalink) |
| Distinguished - BHPian ![]() | Thats interesting, but do other cars as well display the same trait when new?. On a low-end passenger car usually weight balancing is not usually given much precedence but that causing the car to sag by 1 inch on one side is like having an extra person on one side. Add to it that the driver will be on the right side and it will sag further. Or is it that the additional weighting on the right side is to counter the drivers weight on a left-hand drive car. The directions have not been reversed in making it into a RHD.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #28 (permalink) | |
| Quote:
I guess this issue is also something similar. But I would expect to see atleast one more BHPian confirming this issue. I have noticed one more issue, steering is more harder when you turn it left compared to turn it right. I just need to create an instrument to prove this. This could be because of above mentioned slope towards right. | |
| | #29 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
Be advised that there are situations where the BEST measurement is by one of our famous five senses. Smoothness of a crankpin or journal of a crankshaft is invariably 'measured' by a) feeling with a finger-tip and b) un-aided visual examination. You'd be surprised how accurate/adequate our senses can be! | |
| | #30 (permalink) |
| Senior - BHPian | If it is design parameter, then you cannot do anything. If all Civics have this, then why complain. You have not mentioned as to whether it is affecting your driving.
__________________ For one who sees Me in all beings and sees all beings in Me, I am never lost, nor is he ever lost to Me. |
| Thread Tools | |
Similar Threads | ||||
| Current civic or Wait for Civic Facelift ? | unknown | Sedans | 103 | 3rd June 2008 20:22 |
| Used(corolla or civic) or new(ONLY CIVIC) | hell_raiser | Sedans | 10 | 25th November 2007 22:34 |
| Honda Civic adjudged as Indian Car of the Year - ICOTY 2007 | navdeep | The Indian Car Scene!! | 1 | 13th March 2007 17:59 |
| Honda Civic voted Indian Car of the Year | salilpawar1 | The Indian Car Scene!! | 5 | 9th March 2007 18:53 |
| Confused between buying a car b/w 8L or 11L or waiting for Civic? | ankit.agl | Sedans | 26 | 29th March 2006 02:56 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
