Thread Tools
Old 5th February 2008, 09:14   #1 (permalink)
Default new civic - car is slanting towards right
I have noticed that my new civic has some suspension issue which makes the car to slant towards right.
I have measured the gap between the ground and the bumper, and saw there is a difference of close to 1 inch between right and left hand side. Is this an issue that can be corrected ?
I did the testing on a level ground and both front and rear has this problem.
swageo is offline   Reply With Quote
Old 5th February 2008, 09:29   #2 (permalink)
snaronikar's Avatar
Have you tried doing wheel balancing/alignment. It may be helpful. If this does not resolve the problem, then better take it service centre.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 5th February 2008, 09:33   #3 (permalink)
BUSA's Avatar
Check your tire pressure, then get your wheels aligned and balanced and then your problem should be solved.
__________________
Got Bhp? Team-Bhp.com
Old 5th February 2008, 09:34   #4 (permalink)
Would recommend you face the car the other way at exactly the same spot and measure again. Will confirm whether there really is a sag.
Old 5th February 2008, 10:05   #5 (permalink)
I have ensured that type pressures are all same. I need to do some more verification with the help of water level, but 99% sure that there is some problem.
Is there any adjustment that can be done one suspension ?. I have contacted the dealer and waiting for their reply.
Old 5th February 2008, 10:06   #6 (permalink)
I do not see any such problem in my Civic. It is better you take it to the service centre
__________________
Dream Big. It does not hurt in a dream
jayguar is offline   Reply With Quote
Old 5th February 2008, 10:12   #7 (permalink)
suman's Avatar
Swageo, is this the 2007 model that you got a discount on? Buddy, something doesn't smell right here - you should take it to the dealer workshop ASAP & ask for an explanation. I don't think alignment or balancing could be an issue with a brand new car
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
Old 5th February 2008, 10:19   #8 (permalink)
amit_mechengg's Avatar
put ur car on a ramp one.lets the wheels fall freely. then measure the distance between the wheel arch and the centre of each wheel. if there is a diff then note it down. also park ur car on a very plain surface and again check the ground clearance and also the sitance between wheel arch and centre of wheel. if there is a difference found ur suspension has developed some problems. please ask the authorised dealer to fix it.
__________________
" I dont Drive Fast , I Fly Slowly "
Old 5th February 2008, 10:20   #9 (permalink)
ram_hyundai's Avatar
it should be the tyre pressure ,hope the issue should be cleared once you check and clear it.if it is the suspension then there should be other problems like thud sound etc.and more over both suspension of the same side going kaput is a distant probablity.
ram
__________________
Become MAD SOON and join the MON SOON Drive.
one more from me-
hey MAN come SOON for the MONSOON drive
ram_hyundai is offline   Reply With Quote
Old 5th February 2008, 10:34   #10 (permalink)
suman's Avatar
He has, see below post -
__________________
Old 5th February 2008, 10:42   #11 (permalink)
[FONT=Arial][SIZE=2]I have contacted the dealer and asked to take car to service tomorrow. I will update the thread after that.[/SIZE][/FONT]
[FONT=Arial][/FONT]
[FONT=Arial][SIZE=2]But this is annoying, its 2008 model brand new Civic
[/SIZE][/FONT]
Old 5th February 2008, 10:43   #12 (permalink)
But this is annoying, its 2008 model Civic
Old 5th February 2008, 12:26   #13 (permalink)
Could be a busted shock absorber..
rangaraj is online now   Reply With Quote
Old 5th February 2008, 12:30   #14 (permalink)
shock absorber seems to work fine, it goes over bumps smoothly without any noise. What I suspect is something need to be adjusted in suspension.
Old 5th February 2008, 12:30   #15 (permalink)
iraghava's Avatar
Swageo - In all probability it is an alignment issue. Take a TD with the advisor before giving the car in & clearly explaining the problem to him, also make sure he notes the problem down as told by you in the Job card.
Then, while taking delivery reach a little early (since I'm assuming it's the first service so shouldn't take long anyway) and insist on taking a TD to make sure that the problem has been completely sorted before making ANY payments.
This is routine for finicky customers (like me!) so the service centre will not have any objections to this approach.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Thread Tools
New Car - Civic / Octavia or Laura ? hitinv Sedans 1 28th February 2008 12:23
Honda Civic adjudged as Indian Car of the Year - ICOTY 2007 navdeep The Indian Car Scene!! 1 13th March 2007 17:59
Honda Civic voted Indian Car of the Year salilpawar1 The Indian Car Scene!! 5 9th March 2007 18:53
Confused between buying a car b/w 8L or 11L or waiting for Civic? ankit.agl Sedans 26 29th March 2006 02:56
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
