Thread Tools
Old 6th February 2008, 13:57   #16 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Originally Posted by sushrutha View Post
Nopes nothing of the above have worked on my Honda city windsheild. Mine was totally filled with watermarks in all my windows n winsheild.
Best solution, But for this one has to suffer the arm pain for a week or so,
Get a soft rubbing compound(Motomax) , apply it on the winsheild, take a soft cloth and keep on rubbing it against winsheild with a bit of force.Keep continuing the rubbing in circles, Once the rubbing becomes a bit hard water marks tends to disapper, then the glass tends to become clear.
I'm sure 100% this will workout but one needs to put in a lot of effort for this.
Now all my glass looks as new, but to cleanup all I took almost 1 week(each glass a day)
wont this cause swirl marks? those irritating spider web thingies that land on your vision when lights dazzle at night...
I suggest lemon and vinegar over rubbing compound, much safer. I had the same problem after last spell of monsoon/rain but slowly marks are fading off without any special attention (i wash my car only once a week, hence slow process)
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 6th February 2008, 14:43   #17 (permalink)
If your cloth is not soft enough and you have resident dust on the windshield you will definitely get swirl marks if you keeping rubbing it hard. Use a top down swipe and then start from the top again. Do not do up and down or circular. Also change the cloth side regularly and dip it in water and squeeze dry. Better to use chamois or banian cloth.
Lemon/Vinegar is a nice choice. Should work.
Jaggu, surprising rain water left marks ! Rain is supposed to be soft water. Probably its all the pollution in the air. Or water bouncing off walls/terraces/sunroofs !! :-)
Actually nothing cleans a car better than good hard rain.
__________________
Everyone is born right-handed, only the gifted overcome it.
This is my car and I have my wife's permission to say so.
csentil is offline   Reply With Quote
Old 6th February 2008, 16:27   #18 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Yeah its a combination of rain with atmospheric and road pollution along with terrace spray et all BUT the big contribution was ME. I didnt bother to wipe (except for using windshield wiper) and went for the muddy messed up look
__________________
Old 6th February 2008, 16:39   #19 (permalink)
Tried lemon and left it for 2 minutes and then washed it with water but couldn't feel the change, Pls let me know if the lemon needs to be put for some more time before washing off?
saurabhkum is offline   Reply With Quote
Old 6th February 2008, 17:07   #20 (permalink)
Prithvi's Avatar
The windshield experts offer something called chemical cleaning, heard its Rs 900 or so. A friend of mine had a lot of water marks and then gave it to Southern Motors on St'Marks road and they charged him about Rs 700, but the glass was fantastic after that.
Another cause of not proper wiping is the horrible Bosch wipers which have a soft silicon coating which is a real pain especially when it rains hard and you are using the wiper constantly then you get a mist that forms with each swipe of the wiper. Had this problem on my Indica, Accent & Octy too.
Would advise chemical cleaning for the windscreen. Had seen it on WE site sometime back.
Need to get my windscreens done next week. Will keep you guys posted on this.
Prithvi is offline   Reply With Quote
Old 7th February 2008, 09:51   #21 (permalink)
Just now contacted Windshield Experts, they said they don't provide any sort of cleaning services. They are only offering replacemene or repair of chipped glass. Has anyone got this kind of service from any other outlet. Or please let me know the best cleaning solutions which can be used for this?
Old 7th February 2008, 10:15   #22 (permalink)
sushrutha's Avatar
Jaggu,
I don't have any swirl marks on my windscreen. That's why I have mentioned to use SOFT rubbing compound
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 7th February 2008, 10:32   #23 (permalink)
lemon with salt is what i have heard from elders....
put some salt on lemon..and then slowly rub over the patch.
__________________
Mohit
Finally...Esteem VXI.
amohit is offline   Reply With Quote
Old 7th February 2008, 10:38   #24 (permalink)
If it is 'hard water' residues/marks that we are talking about, then the way I see it is: rubbing compound will remove these with ABRASIVE action, whereas a solvent will DISSOLVE these without any abrasive action.
For hard water scale, Harpic Liquid works splendidly, specially on glass and bathroom chromium-plated fittings etc..
Old 7th February 2008, 11:45   #25 (permalink)
Has anyone used Harpic for windsheild? Pls let me know the results for the same.
Old 7th February 2008, 12:07   #26 (permalink)
For just a few stains -- u can use a mild abrasive like the rubbing compound suggested or even try toothpaste -- its a mild abrasive and I've used it occasionally to remove marks.
71Convertible is offline   Reply With Quote
Old 7th February 2008, 12:18   #27 (permalink)
sushrutha's Avatar
I had used easy of bang for the salt water marks. It(water marks) didn't go.
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 7th February 2008, 15:40   #28 (permalink)
benbsb29's Avatar
That product is a waste! The ads are over hyped, and the actual product is of no good. Just a waste of money 'Easy Off Bang' is !
And i had the impression from many on the forum that Bosch wipers were the best?!
__________________
"Wise are they who invested in a diesel powered automobile" - Benny
Old 7th February 2008, 15:43   #29 (permalink)
snaronikar's Avatar
How about 3M windscreen washer? Heard its a good product.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 7th February 2008, 15:49   #30 (permalink)
Prithvi's Avatar
Even I had that impression, was sadly mistaken after installing them.
Thread Tools
windshield toyota Technical Stuff 9 25th July 2008 20:06
Windshield leakages fergus Technical Stuff 7 27th August 2007 09:53
Scratches on the Windshield kiranpashtakar Technical Stuff 39 21st April 2007 01:01
Wiper marks on windshield sadnabrina Technical Stuff 18 27th September 2006 11:12
Windshield Wipers. v12 Technical Stuff 21 8th August 2005 16:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
