Thread Tools
Old 17th April 2008, 15:42   #46 (permalink)
Yesterday I have tried prill liquid with lemon to remove hard water mark from windshield, not a big success, but i feel a little improvement.
Now i have to try with vinegar. I will try sometime this weekend.
What about contacting 3M people or windshield experts?
kavu75 is offline   Reply With Quote
Old 17th April 2008, 20:55   #47 (permalink)
I had success with used Scotchbite pad and liquid kitchen soap. 5mins , Sparkling clean.
Sutra is offline   Reply With Quote
Old 17th April 2008, 21:39   #48 (permalink)
nirmalts's Avatar
Scotchbite pad? Wouldnt that create scratches on the glass?
Nirmal
nirmalts is offline   Reply With Quote
Old 18th April 2008, 21:23   #49 (permalink)
I had similar concerns.
The green ones are soft enough and do not scratch the glass.
Have you seen borosil clear lemon glasses used at home ever getting scratched with Scotchbite pad.
To be on safer side I used a worn pad, it’s equally effective.
Try this with warm water.
Old 18th April 2008, 21:47   #50 (permalink)
clevermax's Avatar
Hard water drying on the windshield will leave marks which cannot be cleaned with Colin, Prill or whatever. These marks will be gone as time pass by, when your car undergo several washes... But while washing the windshield, always take care to wipe off extra water with a cotton. And do not fill your wiper tank with tap water if water in your area is hard. Use water from a reverse osmosis filter or Aquafina
clevermax is online now   Reply With Quote
Old 18th May 2008, 16:55   #51 (permalink)
Default Hard water mark gone from windshiled
Last week I had taken my vehicle to Vijay(GM Bangalore) showed them the hard water mark. I can't believe It's hardly less than 5 minute job.
First they sprayed soap solution to windshield. Then they rubbed the windshield carefully with some glass cleaning clay mix. After this washed the windshield, my god all the marks are gone.
How much i struggled earlier
Asked them the details of the clay mix, they told me they are getting this from 3M.
Old 19th May 2008, 21:46   #52 (permalink)
Can you please find out the details of the clay mix? It will be off great help.
saurabhkum is offline   Reply With Quote
Old 20th May 2008, 10:30   #53 (permalink)
I had asked them the details. Since they have a tie up with 3M, they are getting this clay mix from 3M. They don't know outside where we can get that. He asked me to check-up with some accessories shop. I have tried some shops in bangalore, but no use.
Can you ask the 3M guys at Mumbai? Hope they might be having some solutions for this.
Old 22nd May 2008, 17:53   #54 (permalink)
adityamunshi's Avatar
Try alcohol, i use it to remove water stains from my bathroom mirror.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 22nd May 2008, 19:30   #55 (permalink)
Assuming that it is an ultrafine powder, perhaps Brasso might do?
anupmathur is online now   Reply With Quote
Old 22nd May 2008, 20:56   #56 (permalink)
I use stainless steel wool (used to clean kitchen utensils) to clean water stains from glass. It will not create any mark, nor it require any other cleaning liquids. Just make it wet and scrub. If you guys are in doubt try it on other glass and then on to the car. I was doing this in Bangalore. In kochi as we have soft water, steel wool is limited to aquarium glass. This is easier/ faster than Scotch-bite.
__________________
KL 06, KA 03, KA 03, KA 05, TN 72 and now KL7 BH Dzire ZDI
kochicar is online now   Reply With Quote
Old 23rd May 2008, 20:04   #57 (permalink)
nirmalts's Avatar
hello kochicar,
Wouldnt really advise to use steel wool on glass. For naked eyes the scratches caused might not be visible, but this is enough to cause troubles like glare during night driving due to unwanted reflections through these marks, water marks even after using wiper during rains etc.
Old 25th May 2008, 14:26   #58 (permalink)
yzfrj's Avatar
Hard water stains are bit hard to get rid of.
I see that a lot here in chennai.
In my native cochin its not a problem, what stains ?
If glass cleaners like colin does not help,
try disk washing liquid (be careful not to get that on to the paint)
dampen the glass and rub the liquid (sponge/ cloth/ paper)
If this does not help, use tooth paste (I kid you not)
tooth paste contains a mild abrasive agent.
If that does not help, time for the big guns...
"Rubbing compound" (water based recommended) please don't use too much else you risk making the glass hazy.
yzfrj is offline   Reply With Quote
Old 25th May 2008, 17:14   #59 (permalink)
Tooth paste has long been recommended for polishing small scratches out of glass.
I've tried it on sunglasses, and I guess it requires several hundred times more patience than I have!
Old 25th May 2008, 17:52   #60 (permalink)
The opaque type, chalk based tooth pastes would work better than the gels.
Thread Tools
windshield toyota Technical Stuff 9 25th July 2008 20:06
Windshield leakages fergus Technical Stuff 7 27th August 2007 09:53
Scratches on the Windshield kiranpashtakar Technical Stuff 39 21st April 2007 01:01
Wiper marks on windshield sadnabrina Technical Stuff 18 27th September 2006 11:12
Windshield Wipers. v12 Technical Stuff 21 8th August 2005 16:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
