Old 26th July 2011, 15:49   #91
Tassem's Avatar
Thanked: 436 Times
Default Re: Help With Water Marks on Windshield
@VCheng: I could not try the vinegar trick cause when I got home, there was no vinegar as luck would have it! Will give it a shot tonight and update here..
@kavu75: I guess the best place to try is the 3M Service center.
Tassem is offline   Reply With Quote
Old 17th August 2011, 13:50   #92
Thanked: 193 Times
Infractions: 0/1 (5)
Default Re: A superb Car detailing guide, wish we had this kind of knowledge at home!
Folks, need help with getting rid of the hard water mark on the windshield.
I have tried applying Lemon Juice, Vinegar, CIF, Mr.Muscle, Pril and what not ... but can't get rid of the hard water mark... It has certainly reduced from how it was before but the visibility is no where closer to how it was prior to water marks.. Recently i drove to Chennai and realized how much of trouble the hard-water mark is during night drives....
Can someone suggest a tested method, won't mind trying off the shelf product to get rid of these marks.
harishpr is offline   Reply With Quote
Old 17th August 2011, 15:09   #93
Sathya_sc's Avatar
Thanked: 670 Times
Pls take it to a service center and consult a wind screen expert. I had a similar situation and the water marks didnt go for a couple of days after applying all possible cleaning things that you have mentioned. I went to the Service Center- paid 3k and did a glass cleaning and polish and it went away after 3 hrs of work. Dont leave it for many days as it will result in replacement of windshield itself. they are pretty strong marks that settles down permanently.. so pls take necessary measures asap.
Sathya
Sathya_sc is offline   Reply With Quote
Old 17th August 2011, 16:44   #94
car_crazy1400's Avatar
Thanked: 204 Times
I have tried successfully to remove the hard water marks on my Innova's windshield .
I wore rubber gloves & used a little Harpic (thats right, the Toilet cleaner),rub it over glass & let it spread with the gloves & a wet cotton cloth all over the marks on the glass, carefully avoiding plastics & rubber (as this will discolor the plastics). Let it sit in shade for about 2 mins , then wash it off with lotsa water & wipe dry. You will see immediate results.
Please take care and do not try this on a hot windshield & do use lots of water to wash off as harpic is fairly corrosive & can discolor marble stone.
Hope this helps.
Edit: do not use too much harpic, lest it starts to flow down the windscreen.
car_crazy1400 is online now   Reply With Quote
Old 17th August 2011, 17:06   #95
smsrini's Avatar
Thanked: 272 Times
do a glass polish at the Sparkle car spa in forum mall. costs about 1k for a large car - skoda, safari etc., less for smaller cars.
smsrini is offline   Reply With Quote
Old 17th August 2011, 17:21   #96
mtnrajdeep's Avatar
Thanked: 101 Times
Buy a bar of cleaning clay and clean the windshield with it. I think you can get cleaning clay on ebay.
mtnrajdeep is offline   Reply With Quote
Old 8th March 2012, 21:02   #97
riturajsharma19's Avatar
Thanked: 63 Times
Guys, after a lot of struggle, I have finally managed to crack the riddle. After using Collins, Harpic, Prill liquid, diluted vinegar and what not, I successfully removed all rigid water marks with toothpaste. The procedure I followed was very similar to waxing your car. I first rubbed a thin layer and buffed off the entire toothpaste with a soft cotton cloth, which rendered the windshield crystal clear. However, donot use those gel-types. The ones that are white in colour are the best suited.
riturajsharma19 is offline   Reply With Quote
Old 8th March 2012, 21:12   #98
mercedised's Avatar
Thanked: 177 Times
Instead one can also use Chuna (Lime), spray some water on windshield and then rub the Chuna on windshield, finally wipe it off by water. Done! Removes every possible mark and greasy dirt. I have been using this from last 4 years and my father is using this method from last 20 years.
Old 9th March 2012, 06:46   #99
shankar.balan's Avatar
Thanked: 5,350 Times
Which is the best way for this please?
I ve got these miserable water marks on my Yeti's windscreen and they simply refuse to go.
I dont want to hurt the glass and/ or the surrounding trim so please advise which is the best way?
Old 9th March 2012, 12:48   #100
smsrini's Avatar
Thanked: 272 Times
If the regular cleaners like colin, CIF dont work, then use detailing clay. mask the surrounding trim to protect.
Old 9th March 2012, 12:58   #101
mayankjha1806's Avatar
Thanked: 821 Times
Originally Posted by kavu75 View Post
Same thing i did with my car some 3 years back to remove some hard water marks. Chevy guys did the cleaning with this 3M cleaning clay.
How much did the 3M guys charged you for that. Once i had parked my car near a water sprinkler near garden and over the day it left hard water marks on the windshield. It refused to go with Vinegar, Colin, Surf and what not. Finally tried something called Easy Off Bang cleaner and the marks went off like normal dirt. The full bottle cost me about Rs 150 .
mayankjha1806 is offline   Reply With Quote
Old 9th March 2012, 13:08   #102
ssingri's Avatar
Thanked: 71 Times
If it is water marks for sure then vinegar is the best and I have used it with no damage to the glass. I have used this method when some water was dripping on my windshield from the flat above for a week or two and had left very ugly deposits. My washer guy could not get rid of them with soap etc.
1. Prepare a mix of 1/4 vinegar and 3/4 water
2. Use a cloth to apply all over the water marks
3. Let it soak for 10 mins
4. wash it with water now feel the surface if it feels rough you can use a razor blade(ones the barbers use) to gently lift off the sediment.
5. You can also use toothpaste Colgate white one to polish it down. The best way to polish is to use your fingers.
ssingri is offline   Reply With Quote
Old 9th March 2012, 15:26   #103
Somehow I have greater faith in the natural method - vinegar etc rather than these cleaning agents.
So I shall try what you suggest and we will see if I succeed!
Old 11th March 2012, 20:44   #104
Thanked: 91 Times
I had done this at Chevy service center and they didn't charge me anything at that time (more than 3 years now). Be careful with Easy Off Bang cleaner, i think it's bit stronger.
Nowadays i am using a glass polish "Auto Glym Car Glass Polish" which i got from UK sometime back and it cost around 5.5 GBP. This is doing a decent cleaning.
kavu75 is offline   Reply With Quote
Old 26th May 2012, 02:49   #105
arrowaby's Avatar
Thanked: 51 Times
I have water stains not only on my wind-shield but also on the car body.
The water that comes in my building is perhaps hard-water. The guy uses the same water to wash my car. Now the roof of the car has got ridiculous amount of stains. Too many. How do I get rid of the stains on the car body?
arrowaby is offline   Reply With Quote
Car Accessories - Marks & Glix (Salt Lake, Kolkata) shuvc Other Cities 43 10th August 2016 18:30
My Figo's boot has some crack marks!! anilisanil Technical Stuff 52 18th April 2011 21:57
Wiper marks on windshield & how to get rid of them. sadnabrina Technical Stuff 53 31st August 2010 13:52
Burn marks on DMF and Clutch - Need urgent help! novice Technical Stuff 4 13th September 2009 01:45
Help me with the windshield wiper scratches btirthankar Technical Stuff 1 3rd October 2007 21:26
