| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2007 Location: Bangalore
| Hello Guys, I drive 2002 Accent GLS with about 70000 KMs done. Currently I see different issues but mostly in these 2 categories. 1. Noise from the car. I used to get this mostly from the dashboard. But I'm now at a level I can remove the dashboard and fix everytime I hear some noise from it. Also, I hear underbody noise from steering column and the suspension time to time. Last time Advaith took 6 months to find one rusted nut causing squeaking noise from the front suspension. And now I have same complaint from rear suspension. I do not want to do this again and again. Can we strip it to bear bones and re assemble and fix any issues while doing so? Does this sound ridiculous? Can this be done and if so how much should I be ready to pay? I stay in Bangalore and would like to know a reliable place to have it done. 2. Issues with the engine. This engine is noisy time to time and HLAs were replaced last year. Also, from time to time it feels like it's out of tune. I personally feel that this engine may need a round of overhauling. Now, can this be done and is there any advantage of doing so? How much this may cost? And is there a good alternative to Hyundais in Bangalore? |
| | #2 (permalink) | ||
| BHPian Join Date: Aug 2004 Location: Mumbai
| Quote:
| | #3 (permalink) |
| . It's just that I've a thing about sounds. Not only with the cars but otherwise too, I'm too sensitive to the sounds at home, work and same when driving also.Other than the plastic parts inside, I was wondering if what I suggested would make any difference at all if I open up the car. I was used to more silent cars and I'm stuck with this for now coz of some financial ties. And what exactly is a compression test you're referring to? Should I check with Advaith Hyundai or should I try outside? |
| | #4 (permalink) |
| BHPian | An engine compression test will tell you whether the pistons,rings,bore are worn out or damaged.It'll tell you if the inlet or exhaust valves have failed or seated properly.It is usually done by a compression gauge.
__________________ Forget two things in life. The good you do to others & bad done by others to you. |
| | #5 (permalink) |
| Newbie Join Date: Aug 2007 Location: mumbai
Infractions: 0/1 (5) | why dont you try for decarbornize engine as it took 1100 rs in mumbai .. and that to will clear u r engine ...and may u find some less noise
__________________ great going with imported Ice |
| | #6 (permalink) | |
| Senior - BHPian | Quote:
__________________ Maruti - Everyone comes home with rattles! | |
| | #8 (permalink) | |
| BHPian Join Date: Jan 2008 Location: New Delhi
| Quote:
__________________ Hyundai Elantra CRDi Hyundai Accent 1.6L GLS Maruti Suzuki Wagon R Maruti 800 What's Next?... Yamaha R15 :-) | |
| Thread Tools | |
Similar Threads | ||||
| Suggestions | doniv | Ask the Gurus | 11 | 7th August 2007 21:12 |
| Suggestions please | cooldude1988765 | Hatchbacks | 19 | 3rd April 2006 09:08 |
| modifying hyundai accent like the wrc accent | kausu | Modifications & Accessories | 11 | 26th March 2006 13:20 |
| Accent CRDi or Accent Viva CRDi Looks | abhibh | The Indian Car Scene!! | 4 | 8th November 2005 16:43 |
| Accent CRDi or Accent Viva CRDi | abhibh | Sedans | 16 | 8th November 2005 04:58 |
