Closed Thread
Old 6th February 2008, 11:16   #1
Default Diff Engine oils - which to select ?
Team,
Till date i was using Castrol Engine oil in my car, my car has clocked 49k till date, i am happy with its performance, but i came across interesting info in webs which had given rates of oil, its worth looking into it,
1) Mobil 1 (Rs.160 for 1 liter)
2) Shell (Rs.137 for 1 liter)
3) Motul (~Rs.180 for 1 liter)
4) Pennzoil
5) elf (Rs.180 for 1 liter)
6) Castrol (Rs.230 for 1 liter)
7) Servo brand of lubricants from Indian Oil
8) Cool Kendall
9) Veedol
10) HP Mak (Rs.140 for 1 liter)
Normally i requires 4 ltr oil, Does it make sense to look at other options like Mobile 1, Shell ? can somebody change oil brand after vehicle is run for 49k?
My regular oii Change duration is 5k,, but some bhpians suggested to change oil at 10k only Airfiler need to change at 5k , will not loose on performance and F.E.
pls help
nicejits is offline
Old 6th February 2008, 11:26   #2
yogi1771's Avatar
Where do you get Mobil1 or Shell at such rates
yogi1771 is offline
Old 6th February 2008, 11:29   #3
Akshay1234's Avatar
Thanked: 7,243 Times
you should change oil every 10k kms only if your using synthetic.
Akshay1234 is online now
Old 6th February 2008, 11:52   #4
tsk1979's Avatar
Thanked: 16,422 Times
Please use the existing engine oil thread. This question has been asked multiple times before
tsk1979 is offline
Closed Thread
All about Diesel engine oils Tan1959 Technical Stuff 1759 16th July 2018 15:56
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 177 24th May 2018 14:32
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
