Old 8th February 2008, 13:44   #16
Thanked: 103,414 Times
Pretty simple actually. High-revv the car in second gear...If the speedo nears a 100, its an Esteem. If the engine runs out of breath at 70ish (or with the air-con on), its a Maruti 1000.
Old 8th February 2008, 15:10   #17
esteem_lover's Avatar
Thanked: 451 Times
esteem 95 to 97 were as similar as the 1000s. the only exterior difference was in the fuel lid & the only interior diffference was in the steering wheel. the esteem had a different shaped centre with 'esteem' written on it whereas the 1000 had maruti written in hindi. hope this helps.
Old 8th February 2008, 15:25   #18
alabjarus's Avatar
Thanked: 16 Times
Originally Posted by hell boy View Post
1000 has stoped the production in the year 1994 so there is no chance that you will get a 1999 model in 1000
Not right. 1000 was relaunched in 98/99 and was in the mkt for a short while.
alabjarus is offline   Reply With Quote
Old 8th February 2008, 17:03   #19
Thanked: 451 Times
M-1000s are available from 1991 onwards right uptil 1997. It was stopped in 1998 & resumed in 1999 & went on upto 2000 & then buried.
Old 8th February 2008, 18:26   #20
Default Esteem Or A 1000
Hi, just open the hood if the A/C condensor overlaps the radiator by half it is an esteem,other wise it is a 1000
Originally Posted by sidd_city View Post
Guys my friend and I were looking for a 800 but ended bargaining for a 99 esteem vx fully loaded for 1.10 lacs. Now as we know that 1000 was also selling at that time is there any way we can differenciate between them. I may be sounding dumb but I don't want to buy a 1000 thinking its a esteem. the r.c says its esteem. visually it looks like an esteem but just want to make sure. Is there any other way to check like the engine and stuff. And what do you'll think about the deal the condition quite ok. Guys let me know soon cause we are getting the car tommorrow.
alankarmotor is offline   Reply With Quote
Old 8th February 2008, 20:43   #21
Technocrat's Avatar
Thanked: 2,589 Times
Wow I never knew there were so many novel ways to find the difference
Old 8th February 2008, 22:08   #22
Rehaan's Avatar
Thanked: 25,038 Times
.....if the engine runs out of breath at 70ish (or with the air-con on), its a Maruti 1000.
...or an esteem that you probably shouldnt be buying anyway!
cya
R
Old 8th February 2008, 22:36   #23
sidd_city's Avatar
Thanked: 11 Times
Default It actually is an esteem!
Thanks a bunch guys for all your sugestions finally bought the car today. Did all the checks you guys told me and yes it definately is an esteem. condition is quite ok but some minor works r there the RHS drive shaft bearing has to be relaced. there is a slight judder when you quickly release the accelerator and then then accelerate again.Don't know what exactly is the roblem any Inut guys? Mechanic says he needs to check susension bushes. Any esteem owners came across this?
sidd_city is offline   Reply With Quote
Fined 1000 rs for not smiling and talking to traffic cops and 50 rs for signal jump! rajinibm Street Experiences 42 6th April 2011 19:39
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
HONDA to launch CBR 1000 and GOLD WING sathyaprakash Superbikes & Imports 31 17th July 2007 09:25
My new GSXR-1000 (pics and video link) highwayblaze Superbikes & Imports 22 14th October 2006 20:31
wanted gypsy,1000/carb esteem mumbai reg... sparco Shifting gears 0 29th August 2005 00:46
