| LinkBack | Thread Tools | Search this Thread |
| | #16 |
| Distinguished - BHPian ![]() Join Date: May 2005 Location: KL
Thanked: 439 Times
| For idle rpm adjustment you don't have to fiddle with these two screws. Idle rpm is adjusted using the throttle stop screw on the right hand side of the carb. |
| | #17 |
| Senior - BHPian Join Date: May 2007 Location: Mumbai
Thanked: 154 Times
Infractions: 0/1 (5) | |
| | #18 | ||
| BHPian Join Date: Dec 2006 Location: Kolkata
Thanked: 83 Times
| Quote:
Shall I follow these points for a Carb Zen tuning and carb overhaul? | ||
| | #19 | |
| BHPian | Quote:
| | #20 |
| BHPian Join Date: Aug 2004 Location: Ponda, Goa
| check this linky A PURRFECT M800 - DOES IT EXIST?! |
| | #21 | |
Thanked: 439 Times
| Quote:
![]() When you face the car from the front the throttle cable and throttle links would be to your left under the air filter assembly. | |
| | #22 |
| Newbie Join Date: Sep 2008 Location: goa
| Hello friends! i own a 10 year old carburettor type maruti 800 that has done over 140,000 kms. mileage is still excellent. and its on LPG for the past 8 years. with over 120,000 on LPG. gives around 370 to 400 kms per 14 kg of LPG. just last year, i had to struggle a lot for low mileage on LPG. used to give 280 to 300kms only (per 14kg). after lots of struggle and good advice from Team BHP post regarding the advance retard timing setting to 52 degrees dwell angle sharp, and changing the advance to nearly 9 degrees, mileage increased tremendously ! so to share my experience and make better use of fuel, i am typing out this mail. Check dwell angle correctly ! usually the mechanic does it by guess work ! should be 0.4mm seperation between contacts exactly to give 52 degrees dwell . but when checked for actuals before changing, it was around 40 degrees only ! setting at home is very tedious. keeps slipping between extreme positions. the sparks on contact and seperation are the only guides ! and a simple compass protactor was used to read the angles. crude method. luckily worked. but took over 2 hours for an otherwise 15 minutes job with proper instruments ! distributor angle is recommended to be 7 degrees . one local mechanic suggested higher advance. survey over the net also revealed that LPG requires higher advance timimgs. hence set to around 9 degrees. now absolutely fantastic mileage ! long distance gives over 410kms per 14 kg !! also Nulon engine additive was used. just 100 ml 9as for 2 wheelers) instead of 500 ml as recommended by company. but this too yielded smooth results.gad kit is Star-gas. another fact noticed was that the idling knob of the gas kit should be turned from poor fuel (alomost tight) to loosening till just enough fuel for idling.. from dying engine to just enough rpm. further turning also results in increased rpm and again later lower rpm at still higher rotations. so movement of idling knob should be from highest rpm to tightening to give just enough idling speed. opening up the gas kit will reveal the mechanism of idling knob. good lucks to all car fiddlers like myself. prasanna |
| | #23 |
| BHPian Join Date: May 2008 Location: Mumbai
Thanked: 34 Times
| @star_aqua & gpa, thanks for your valuable inputs guys, sorry for replying late, as i was not in town. |
| | #24 | |
| BHPian Join Date: Apr 2009 Location: Bangalore
| Quote:
I am confused about the correct dwell angle for the F8B engine. The service manual and the Lucas TVS website Lucas TVS website mention - Dwell angle : 62° ± 3° Thats a difference of 10° ! Can you please tell me about the advantages of setting the dwell angle to 52°. The current dwell meter readings are showing a dwell of 66° at idle (@800 rpm) and 63° at higher RPM's. Does this indicate shaft run out? Can this be rectified by overhauling/machining the distributor (if yes, then where can I get this done)? Thanks for helping me out. | |
| | #25 |
| BHPian Join Date: Nov 2004 Location: India
| I am currently havin an issue about my 800. The issue is of reduced mileage. I am getting somewhere around 14 even on highways which at some time used to be 21-22. I drive at moderate speeds. (most of the time constantly at 80 kmph depending on the road condition) The recent changes in the car that I consider to be the possible causes of the reduction in mileage: 1) Since a couple of months, a strange sports car like sound has developed when I accelerate slightly more in 2nd or 3rd gear. Mechanic told theres some prob with the exhaust. 2) Changed my tires from 145/70/R12 to 155/70/R12. I personally do not believe it should bring my mileage down from around 20 to 14. Servicing is due for the car which I hope will solve the problem. I would like to know if anyone of you can probably give some input here. |
| | #26 |
| BHPian | If yours is 5 years old car, get a compression test done and get a decarbonisation done if there is piston ring wear, if its a carb model, do not get the carb fiddled, instead get the points gap adjusted if needed replace. 155/70r12 is a nice set for m800. It suffices all performance and comfort parameters. |
| | #27 |
Thanked: 154 Times
Infractions: 0/1 (5) | (Mods Using a old thread instead of starting a new one) Hello, I have noticed my 800's idle jet always gets clogged and needs cleaning every few months or so. I have noticed this over the period of close 14 years of ownership of the car. I have a k&N installed but the problem was there even before the k&N. So what could really cause the idle jet to get clogged up. I aways fuel up from half tank to full. Also is it necessary for a carb car to have the accelerator pedal punched a couple of times before starting the car cause i sometimes i do not follow this practice. Could this be the reason the jets get clogged up. I also trust my petrol pump. thanks |
Similar Threads | ||||
| Maruti 800 | Gvozden | Modifications & Accessories | 28 | 8th June 2012 23:47 |
| Queries about purchasing a Maruti Eeco | drabhayshah76 | SUVs, MUVs & 4x4s | 17 | 1st May 2011 21:49 |
| Maruti 800 STD & 800 DX..pros & cons ? | shapath | Technical Stuff | 5 | 15th February 2008 12:13 |
| Maruti likely to renew Maruti 800 with a brand new car | askicode | The Indian Car Scene | 32 | 13th February 2007 11:57 |
| 800 Queries | humyum | Technical Stuff | 6 | 14th August 2006 18:14 |
