| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jul 2007 Location: Bangalore
| I own a Maruti 800 1996 [Carb] model. Its been nearly 1200 kms after i did an oil change. Milage of the Car has increased considerably. I am getting 14 - 18 in city. I had this problem recently that once i lower my gear to 1st or 2nd while taking humps for example, the engine gets off. I suspected Tuning issue. Tuning knob was adjusted twice in diffrent service points and the same issue was there. Finally we removed the knob, cleaned it and put it back and problem got solved. One of them gave a suggestion to do a carborator overhaul. It costs around 1200 it seems. If it increases the milage i would go for the same. Any suggestions to incease the milage even further?? |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Go to a good garage and do a complete engine tune up and carb cleaning. Also check air filter, fuel filter and points spark plug check/cleaning/replace. Rs 1200 for carb overhaul alone is on the higher side, complete tune up should be under 600-800 bucks.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #3 (permalink) |
| BHPian | Carb overhaul at a maruti authorised service station costs 550 bucks+parts.1200 is way too high.Ask them to tune the carburator with a PUC machine strobe in the exhaust.That way u can tune the carb for the perfect air fuel ratio.
__________________ Life is a lemon and i want my money back!!!! |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
__________________ Love your job but Never love your company because you never know when your company stops loving you-NRN | |
| | #6 (permalink) |
| BHPian Join Date: Jul 2007 Location: MUMBAI
| Dear Mr.J.Ramprakash - hello to you. I am giving complete details of work that you "may decide" to do on the Maruti 800 as regards engine tune-up> If you do, you will get exemplary performance. Carburettor: Remove the air cleaner and carburettor from the engine. Open the carburettor (including the venturies), immerse it in new brake fluid and leave it for 24 hours. Then clean it with further new brake fluid, then with petrol and then use a good quality carburettor cleaning spray to clean out gum from each and every miniscule aperture. Assemble with new gaskets between the main body and the bottom cover, main body and the top cover (the size M5*0.8 screws come with the top gasket, use them) and between the throttle body and the intake manifold. Use Maruti Zen's venturies and a Maruti Van idler jet in the primary circuit. It has 8 bleeder holes as compared to the Maruti 800's 4, so you will get better control of progression from the idling circuit to the main circuit. I have used these systems for more than 10 years in all my Maruti 800s and they all run beautifully. Fuel consumption is not affected. Positive Crankcase Ventilation (PCV) valve: Remove the rubber hose and spray some carburettor cleaning fluid in this valve. This way, any gum stuck in this area will get cleaned and you will realise good PCV performance, which corelates directly to idling quality. Air cleaner element: Just remove the old element and throw it out. Use a new Purolator element only. Clean the air cleaner container from inside. Spark plugs: Use only NGK BP5ES spark plugs. Plug gap must necessarily be 0.9 mm (36 thou) only. Distributor: If you have a PMP make distributor, remove it and throw it out. It does not provide spark advance as it should. If you have Lucas TVS or Nippondenso (mostly it will be Lucas TVS), connect a good dwell meter and check for runout of the distributor shaft. If the shaft runs out, dwell will vary. If variance is more than 1 degree, timing and performance will not be realised. Remove the distributor and replace it with a new one having confirmed shaft runout within specifications. The dwell angle must be set to 52 degrees and the static ignition timing must be set to 7 degrees BTDC (before top dead centre) with vacuum advance connected in the circuit. Vacuum hoses: Replace if frayed, hardened, cracked or in any way loose or out of place. Fuel filter: Remove the old fuel filter and throw it out. Use a new Purolator make fuel filter. |
| | #7 (permalink) |
| My reply got posted by some error. I have not finished. I am continuing. Fuel filter: Remove the fuel filter and throw it out. Use a new Purolator make fuel filter. Valve clearence setting (tappet setting): Use a 0.15 mm (6 thou or 0.006 inches) feeler guage for the 3 inlet valves and 0.175 mm (7 thou or 0.007 inches) feeler guage for the 3 exhaust valves. This must be done in engine in absolute dead cold condition (standing overnight without starting). As this is a 3 cylinder engine, you have to ensure that the concerned piston is at the start of the firing stroke at TDC. Use a checklamp connected to the low tension circuit side of the distributor to define individual TDC. Engine idling rpm: 780+/-20 without AC, adjust from volume control and throttle control screws, 1100+/-50 with FICD operating, adjust FICD screw. Intake manifold vacuum: 480 mm of Hg minumum in idling with all circuits connected without AC. Camshaft drive belt: Generally nothing happens but if you experience power drop at @ 50000 kms, just tighten this belt. Results after action: Spark plug insulators light pink in colour Exhaust pipe end cleah in general use and greyish pinkish colour immediately after a long fast drive. Best regards, Behram Dhabhar |
| | #8 (permalink) |
| BHPian Join Date: Nov 2007 Location: Mumbai
| Hi Behram, Believe it or not, the thought of owning a maruti 800 'peoples car' is taking rounds in my mind. initially for trial basis. lets see thereafter. The above reply of yours will certainly be printed and filed. I know it can no-where come close to the experience of PP (infact no car can) but lets see. |
| | #9 (permalink) |
| BHPian | Hi guys i wanted to adjust my 800's carb by myslef for proper idle RPM.Current idle rpm is 1000 as per my tacho.I wanted it to be set to around 800 for better FE. The thing is i dont which screw on the carb is for what. I understand from the current thread that there are 2 screws to be adjusted ,the throtlle and the volume. I have posted a couple of Pics from under the hood of my car. can the gurus please tell me which screw i can use to adjust the idle speed and also what the effect will be adjusting each screw. The 1st image is of the screw on the side and the second 1 is at the back. Let me know thanks
__________________ Your future hasn't been written yet. No one's has. Your future is whatever you make it. -- Doc Brown BTTF III |
| | #10 (permalink) | |
| BHPian | Quote:
I had a 1996 M800 which I bought second hand and recently exchanged for an Alto LXi. The mileage you are getting seems fine in the city. My car also gave a consistent mileage in the 17 to 19 kmpl range in the city. If you drive in the city, the mileage you are getting seems fine. As said by a few other members, Rs. 1,200 is way too high for a carb overhaul. I got my car's carb overhauled for Rs. 600 a year ago. You could try a few tips as mentioned here.Do keep us updated on how this progresses! Cheers, Pritish | |
| | #11 (permalink) |
| Newbie Join Date: May 2008 Location: Mumbai
| Hi Friends, I own M800 - 1997 Model NON-AC-Type-II, i had follwing queries regarding retrofitting AC: 1. What are the modifications needed for retrofitting the AC ? 2. Is there any particular make of AC which i should purchase ? 3. Do i need to get it retrofitted in the Maruti Service Center or any other known Mechanic will be able to retrofit it ? 4. What will be the approximate cost of whole process of retrofitting ? 5. Will there be an adverse effect of retrofitting on the engine or mileage of the vehicle ? Experts please advise... regards Sanjeev |
| | #12 (permalink) | |
| Newbie Join Date: Aug 2008 Location: Bangalore
| Quote:
You can get this work done by a local mechanic preferably an AC mechanic. The work involves the fitment of compressor, additional radiator, refrigerant cylinder uder the hood. inside cabin involves cooling unit, blower and an AC switch in the dashboard. there will no adverse effect on the engine but ofcourse mileage when you use the AC and as well a slight drop in normal running due to an additional belt which keeps running freely on the compressor. atlast you may need to upgrade the battery if you currently have 32amp battery. should be upgraded to atleast 35amps. | |
| | #13 (permalink) | |
| BHPian | Quote:
Rather than retrofit an old model with an AC, I suggest its best you trade in your vehicle for a new M800 which is factory fitted with an AC. You could run up a lot of maintenance costs if the retrofitting job is not done perfectly and also will put a lot of load on your entire electrical and engine components. Cheers, gpa | |
« How to tune M1000 carb?
| Thread Tools | |
Similar Threads | ||||
| Maruti 800 STD & 800 DX..pros & cons ? | shapath | Technical Stuff | 5 | 15th February 2008 12:13 |
| Maruti 800 | Gvozden | Modifications & Accessories | 22 | 15th February 2008 11:58 |
| Maruti likely to renew Maruti 800 with a brand new car | askicode | The Indian Car Scene!! | 32 | 13th February 2007 11:57 |
| 800 Queries | humyum | Technical Stuff | 6 | 14th August 2006 18:14 |
| Maruti 800 | jesal | Shifting gears | 2 | 4th November 2004 19:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
